I have now tested both of mine
K03-29 Turbo's and both of them had a cracking pressure of ~
0,2 Bar / ~
2.9 psi
( both with connected wastegate flapper. )
According to technical specifications from BorgWarner the factory setting cracking pressure for
K03-029 should be ----->
0,37 Bar /
5.366 psi
Is it ok to just adjust the nuts on the actuator rod until it reaches
0,37 Bar /
5.366 psi
From the testing:
Stroke length of the actuator arm: (measured from the time it starts to move until it does not move any more)
~16 mm. / ~0.629 in.
Cracking pressure:
~0.20 Bar / ~2.9 psi.
Maximum open pressure:
Old: ~0.6 Bar. / ~8.7 psi.
But if I adjust the position of the nuts on the actuator arm, so does the total range of motion for the actuator arm also change !?!?
and it's not good, or is it ok
