    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Post Ported OEM exhaust manifold for B6 AMB 1.8T
    My ATP manifold cracked, so I need a replacement.
    Let me know what you have.
    Thanks
    Edit:
    originally, I was looking for a high-flow manifold replacement, but I decided to get an OEM ported manifold.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Aug 13 2015
    NS
    Bump... need one urgently shipped to NS to get my car back on the road.
    I have looked at 3 used OEM manifolds and they were all cracked at the collector. :(
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Are you going to port & polish it yourself?
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Damn, I just picked up an AEB head with OEM AEB exhaust manifold. Would likely do the job for you.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Aug 13 2015
    NS
    Thanks guys. I managed to find a used OEM manifold where the crack on the collector was negligible, so I'm good.... for now. I have an inbound BEX manifold that I will likely port myself and when the time comes, swap it in. Should be a MUCH easier job now that the nuts are easily accessible!
