Results 1 to 10 of 10
    Established Member Two Rings TXautobahn's Avatar
    Jan 17 2017
    Houston
    Help - VCDS Fault Code: 00716 Air Recirculation Flap Positioning Motor (V113)
    Upon recently scanning my car, a code for the HVAC came up: 00716 Air Recirculation Flap Positioning Motor (V113). I have searched around and have not been able to find much information on this. Looking for help identifying the faulty part and its location. Wondering if it can be accessed by removing the glovebox or if the whole dash needs to be removed.
    Any info would be helpful. Thanks!
    Jan 17 2017
    Houston
    Nothing? Is this a unique issue? Bueller?
    Aug 12 2015
    Minneapolis MN
    Quote Originally Posted by TXautobahn View Post
    Per Ross Tech:
    Possible Causes
    Wiring/Connectors from/to Air Flow Flap Positioning Motor (V71) faulty
    Positioning Air Flow Flap Positioning Motor (V71) blocked
    Positioning Air Flow Flap Positioning Motor (V71) faulty
    Possible Solutions
    Check Air Flow Flap Positioning Motor (V71)
    See Measuring Value Blocks (MVB)
    Perform Output Test
    Perform Basic Setting
    Check/Repair Wiring and Connectors
    2017 Audi RS7 Glacier White w/ Black Optics
    2014 Porsche Panamera Turbo Executive Amethyst
    Aug 12 2015
    Minneapolis MN
    You can always try clearing the fault codes and see if it throws the same code again. If so you might actually have a faulty motor
    Jan 17 2017
    Houston
    Many thanks for the info. I did clear the codes and they immediately came back.
    Any chance you could tell me / have a diagram of the specific location of the motor?
    Aug 12 2015
    Minneapolis MN
    I believe its under the glove box....not very easy to access. Might be a job for the mothership (dealer)
    Jan 17 2017
    Houston
    No warranty and being Stage II means I will actively avoid a trip to the dealer, if at all possible. There are a couple of local Audi repair shops I know, will probably pay them a visit. It sucks that this is more of an electronic B.S. problem than a more straightforward mechanical one.
    I haven't noticed a problem with the HVAC system, I only found out about it by scanning the car.
    Aug 12 2015
    Minneapolis MN
    Think it has to do with the "Recycle Air" feature....there is a motor that opens and closes the air intake so if it goes bad it can get stuck open or closed etc. Also if your outside your warranty there inst really a reason to worry about getting flagged.
    Jan 17 2017
    Houston
    At the advice of an old Audi tech friend, I went by my local shop and they plugged the car into their Ross Tech VCDS (I really need to get one of those). They ran a sweep / test mode / recalibration of the HVAC system. It seems to have worked to clear the code and keep it from coming back.
    Aug 27 2008
    Houston Area
    Mind saying what shop? I'm always on the lookout for a good audi fluent independent... Glad you got your issue fixed.
