Results 1 to 7 of 7
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    Exhaust leak after downpipe install
    Darn it!
    After thinking my self install of my APR downpipes went well, it turns out I've got an exhaust leak where the driver's side downpipe meets the midpipe (coming out of the end of the sleeve clamp that holds the downpipe and midpipe together).
    I had smelled some faint exhaust smell in the cabin since the install, and finally diagnosed the issue by using the blower function on my shopvac and hooking it to one of the tailpipes, and sealing off the other tailpipes (engine cold and off of course). There was pretty significant hissing around this connection, while all other connections are air tight.
    I messed with the pipes and sleeve collar several times, and with tightening the heck out of the clamp, the leak is still there. On closer inspection, the end of the downpipe isn't perfectly circular- one side is flattened a bit.
    Any suggestions on a different clamp or heat resistant gasket or wrap that I can try? Other thoughts?
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    You can use muffler sealant .. apr should've included that with the kit for the clamps imo
    https://www.permatex.com/products/sp...ilpipe-sealer/
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Nov 22 2016
    Olympia, WA
    Quote Originally Posted by DGVR6 View Post
    Thanks! I used it last night on both clamps between the downpipes and midpipes- seems to be working well. Is that what you used as well? I thought the clamps would fit snugly on their own without an exhaust leak, but in my case, I couldn't make it work without the permatex. Seems to be good stuff!
    Aug 03 2014
    Queens
    Quote Originally Posted by OlyS6 View Post
    Yea, I seal up whatever exhaust connections that doesn't require a gasket with that paste
    Previous
    Jan 10 2017
    CA
    Oly - I was going to check in how that worked as I'm looking to do my install next week. Good to hear.
    On a related note -- did either of you guys used anti-seize on any on the bolts/O2 sensors or gasket maker on the downpipes?
    2016 Daytona Gray S7. Black optics + sport pkg. Stage 3, eurocode stuff, cosmetic stuff.
    Aug 03 2014
    Queens
    Quote Originally Posted by kpriv View Post
    I have a custom downpipe, so I used a regular exhaust gasket to mate the milltek. The o2 sensor and bolts I left as is, even reused the turbo flange nuts, just don't over tighten
    Previous
    Nov 22 2016
    Olympia, WA
    So the permatex muffler/tailpipe sealant worked great on the sleeve clamps connecting the downpipes to the midpipes. It's rated up to 2000 degrees, so hopefully will hold up over time.
    I did not use any ant-seize or any other products on any of the other connections. A repeat exhaust leak test (using the blower function on a shop vac connected to one of the tailpipes and sealing up the other tailpipes) did not demonstrate any evidence of a leak anywhere else.
    I do have a bit of concern that the O2 sensors relocated beneath the car are exposed to the elements now. I didn't wrap them with anything, as they have a plastic sheath around the bit of exposed cable, but I can imagine that becoming a 'weak link' over time.
    On another note, for the O2 spacers, I used the smallest flow restrictors that came with them. Although there is no check engine light, I did notice yesterday that while running VCDS diagnostics, there was a log for a 'too lean' measurement of the rear O2 sensors after a few hundred miles. I believe this means that it thinks the cats are now 'too efficient'. I reset the code and will check periodically to see how much driving it takes to repeat this error. If it's a frequent occurence, I'll likely switch to the middle flow restrictor and see how that goes.
