Page 1 of 4 123 ... LastLast
Results 1 to 40 of 121
    Apr 05 2016
    Portland, OR
    How To: Virtual Dyno
    I've been playing with this for a few months so figured I might as well share the results so others can play with it too.
    Take all the skepticism you have for a normal dyno, apply a few pinches of salt and you come to this: Virtual Dyno
    Setup:
    Download the installer from here: http://www.virtualdyno.net/public/VirtualDyno_Setup.exe
    Install it like any normal application. (Next, checkbox, Next, Install)
    Once it is done installing it will open. Just close it for now.
    Open up a file explorer and paste this in the address bar:
    Code:
    %AppData%\Virtual Dyno\Cars\Audi\S4
    Open up the file: "Audi_S4_08-13.xml" and replace the contents with the following:
    Code:
    <?xml version="1.0" standalone="yes"?>
    <CarDataset xmlns="http://tempuri.org/CarDataset.xsd">
      <CarParameters>
        <CarMake>Audi</CarMake>
        <CarModel>S4</CarModel>
        <CarSubModel>B8</CarSubModel>
        <StartYear>2009</StartYear>
        <EndYear>2012</EndYear>
        <Weight>3850</Weight>
        <TransTypeManual>false</TransTypeManual>
        <TransGear3>1.560</TransGear3>
        <TransGear4>1.180</TransGear4>
        <FinalGearRatio>3.875</FinalGearRatio>
        <DragCoefficient>0.28</DragCoefficient>
        <FrontalArea>22.5</FrontalArea>
        <TireDiameter>26.035</TireDiameter>
      </CarParameters>
      <CarParameters>
        <TransTypeManual>true</TransTypeManual>
        <TransGear3>1.520</TransGear3>
        <TransGear4>1.133</TransGear4>
        <FinalGearRatio>3.680</FinalGearRatio>
      </CarParameters>
      <CarParameters>
        <CarSubModel>B8.5</CarSubModel>
        <StartYear>2013</StartYear>
        <EndYear>2016</EndYear>
        <TransGear3>1.406</TransGear3>
        <TransGear4>1.025</TransGear4>
      </CarParameters>
      <CarParameters>
      </CarParameters>
    </CarDataset>
    If you are OCD like me rename it to: "Audi_S4_08-16.xml"
    Adjusting the Settings:
    Open Virtual Dyno
    Select File>Options from the top
    Click on the Columns and Profiles tab and input the following data:
    Code:
    STAMP
    Engine speed
    Lambda probes actual: bank1
    Accelerator position
    Intake manifold pressure: absolute    (OR a "Boost" field with the bar corrected to PSI)
    Configuring your Profile:
    Select Profiles>Add Profile from the top
    Select your car from the drop down
    Select the Gear
    Adjust the Tire ht field by clicking on the little blue box next to it and inputing your tire information.
    Adjust the Car Weight and Occ Weight if you know them.
    Generate Logs with VCDS:
    Refer to Jran's guide here on how to use VCDS: How To: VCDS Performance Logging
    Only Stamp, Engine Speed and Accelerator position are required. Lambda and Intake pressure are optional.
    Here are the fields I usually use:
    Code:
    TIME	Loc. IDE00021	Loc. IDE00086	Loc. ENG100261	Loc. ENG100449	Loc. ENG100030	Loc. ENG102932	Loc. ENG101741	Loc. ENG101388	Loc. ENG102763	Loc. ENG99738
    STAMP	Engine speed	Accelerator position	Engine torque	IGA_AD_1_KNK[0]	IGA_AD_1_KNK[5]	Ignition angle: actual	Intake air temperature	Intake manifold pressure: absolute	Lambda probes actual: bank1	RFP_AV
    You will want a log of a full 3rd or 4th gear pull. (Put the car in manual mode, get the RPMs as low as you can then gas it to red line) Mine are usually 3rd gear 2,000-7,200 RPM
    Once you have a log prune out all the irrelavent information until you are left with a file like this:
    Save it and you should be good to go.
    Using Virtual Dyno:
    Launch the Program
    Click File > Load Run from the top
    Once the files are loaded Click Profile > Your Profile from the top
    This should generate some pretty graphs for you
    You can adjust smoothing in the top right, I generally have it at 2
    You can also change the dyno type in the Options. I usually use "Virtual Dyno"
    In my experience this has been very close to what I saw on the actual Dyno.
    Example graph:
    Geoff
    Apr 05 2016
    Portland, OR
    Here is my most recent log if you want to use it for comparison:
    Code:
    STAMP,Engine speed,Accelerator position,Engine torque,IGA_AD_1_KNK[0],IGA_AD_1_KNK[5],Ignition angle: actual,Intake air temperature,Intake manifold pressure: absolute,Lambda probes actual: bank1,Boost,RFP_AV
    230.88,1876,35,310.625,0,0,21.375,35.25,1040.53,0.8516,0.5878379602,43.76
    231.07,1981,53,500.625,0,0,17.625,35.25,1696.16,0.8291,10.09694731,0
    231.25,2125,80,564.9375,0,0,18.375,35.25,1875.35,0.8438,12.69587857,1.61
    231.44,2194,91,562.0938,0,0,19.125,35.25,1882.06,0.8457,12.79319889,2.44
    231.63,2338,91,565.875,0,0,19.875,34.5,1890.44,0.832,12.91474052,4.59
    231.82,2466,91,568,0,0,21.375,34.5,1890.35,0.8418,12.91343518,5.56
    232,2606,91,565.6563,0,0,21.375,33.75,1887.87,0.8311,12.87746582,7.25
    232.17,2667,91,572.0313,0,0,21.75,33.75,1898.23,0.8213,13.02772492,8.07
    232.35,2788,91,571.7188,0,0,21.75,33,1900.47,0.8105,13.06021337,9.2
    232.53,2928,91,574.125,0,0,22.125,33,1902.71,0.8193,13.09270183,10.33
    232.71,3055,91,577.7813,0,0,21.75,33,1924.52,0.8037,13.40902914,10.33
    232.89,3190,91,583.3125,0,0,21.75,32.25,1995.58,0.8008,14.43966732,9.15
    233.08,3266,91,584.2188,0,0,21.375,32.25,2061.41,0.8037,15.39445076,7.51
    233.27,3447,91,581.875,0,0,21.75,32.25,2125.92,0.8135,16.33008922,5.1
    233.46,3607,91,586.875,0,0,22.125,32.25,2182.31,0.7949,17.14795704,4.79
    233.64,3745,91,582,0,0,22.125,32.25,2189.27,0.8076,17.2489033,4.95
    233.81,3869,91,592.0625,0,0,22.125,33,2197.98,0.8037,17.37523118,5.1
    234,4028,91,598.125,0,0,22.5,33,2206.44,0.8066,17.4979331,5
    234.18,4097,91,601.9063,0,0,22.875,33,2213.57,0.8174,17.60134501,5
    234.37,4240,91,621.3438,0,0,23.25,33,2244.33,0.8096,18.0474811,4.59
    234.55,4396,91,625.4375,0,0,23.25,33.75,2278.66,0.8203,18.54539566,3.05
    234.74,4543,91,634.1875,0,0,23.625,33.75,2296.65,0.8203,18.80631856,2.13
    234.93,4679,91,646.6875,0,0,23.625,34.5,2319.12,0.8125,19.13221836,1
    235.12,4841,91,631.6563,0,0,24,35.25,2356.27,0.8066,19.67103356,0
    235.29,4995,91,657.5,0,0,24.75,36,2358.67,0.8105,19.70584262,0
    235.47,5086,91,660.9063,0,0,24.375,36,2338.94,0.8145,19.41968316,0
    235.66,5212,91,657.625,0,0,24.75,37.5,2365.47,0.8115,19.80446828,0
    235.85,5381,91,678.9063,0,0,25.125,38.25,2346.57,0.8018,19.53034696,0
    236.03,5518,91,669.75,0,0,25.125,39.75,2341.84,0.8057,19.4617441,0
    236.21,5692,91,682.7813,0,0,25.5,40.5,2371.28,0.8096,19.88873521,0
    236.39,5825,91,684.9688,0,0,25.5,42,2354.94,0.8066,19.65174354,0
    236.56,5894,91,665.3125,0,0,25.875,42.75,2374.84,0.8271,19.94036865,0
    236.74,6019,91,659.2813,0,0,25.875,44.25,2368.21,0.8223,19.84420862,0
    236.93,6181,91,654.6875,-4.125,0,25.5,45.75,2367.79,0.8311,19.83811704,0
    237.11,6302,91,647.9375,-4.125,0,25.875,47.25,2369.78,0.835,19.86697955,0
    237.29,6435,91,650.2813,-3.75,0,26.25,48.75,2358.92,0.8369,19.70946856,0
    237.47,6497,91,645.6875,-3.75,0,26.25,49.5,2362.65,0.8428,19.76356764,0
    237.66,6604,91,587,-3.375,-2.25,25.875,51.75,2386.28,0.8506,20.10629182,0
    237.85,6736,91,589.0938,-3.375,-2.25,24.75,53.25,2371.77,0.8477,19.89584206,0
    238.03,6837,91,536.3125,-3,-1.875,25.875,54.75,2391.59,0.8525,20.18330686,0
    238.2,6985,91,525.7813,-3,-1.875,25.875,56.25,2383.38,0.8691,20.06423088,0
    238.38,7055,91,487.5938,-5.625,-1.5,24.375,57,2400.79,0.8613,20.31674158,0
    238.56,7139,91,488.3438,-5.25,-1.5,24.75,58.5,2402.62,0.8545,20.34328349,0.85
    238.74,6576,91,273.2813,-5.25,-1.125,0.75,60.75,1754.62,0.8379,10.94483794,25.76
    Geoff
    Veteran Member Four Rings kelseysautobody's Avatar
    Mar 03 2009
    Cape Cod, MA
    Nice write up and a cool program! I'll definitely be gathering some data to use this.
    2013 S4 S-tronic - 3.47 PR // EPL DP ECU/TCU tune // PLM hx // APR intake // Jokerz Blower // Headers // Ice box // iABED TB // Autotech HPFP // RS7 LPFP
    11.186 @ 123.35
    1993 URS4 - GT3071R - EFI Express Tuned - Gutted
    Past: 07 S4 6MT ~ 03 A4 3.0 6MT ~ 99 A4 1.8T
    Apr 05 2016
    Portland, OR
    FWIW, Here is comparing an actual dyno to this tool.
    Torque is a bit optimistic but it is still interesting for getting a high-level view of the logs.
    Geoff
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Got around to playing with this Geoff, thanks. Seeing quite a gain between my pump and race maps! I loaded my AFR as timing and Boost as IAT.
    Here is a mustang dyno I ran with this setup. I ran both pump and race maps here, the only difference is that I ran E35 on the pump map rather than 93 like I did in virtual dyno, the DA was a lot lower for the virtual dyno runs too.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Apr 05 2016
    Portland, OR
    Loading timing and IATs like that is clever!
    You can really see how the CW manipulates the IAT signal 🙈
    Jul 05 2014
    Houston
    Included my crappy EPL stg 2 log here too. The EPL setup dyno'd 427hp at the crank, so 357 at wheels is probably pretty close assuming 16.4% drivetrain loss.
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    Used virtual dyno a hell of a lot with my Mazda when I was self tuning. Great tool for looking at power improvement as long as you use the same piece of road every time. I found 1.01 correction factor to be the closest to real world figures.
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
    Jul 01 2012
    14 B8.5 S4, 90 Toyota Supra turbo (575 whp), 02 Subaru Wrx (stock atm),
    North little Rock, Ar
    anyone found any other means for logging for v.d. aside from vcds? seem the app and bluetooth dongle usualy doesnt come out the best
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by skiptowncat View Post
    Same here. I come from Mazdaspeed 3 background (still have that car) and used virtual dyno quite a bit. The benefit of the program is to compare changes in mods, rather than to use it as a "gospel truth" accurate reading. It analyzes data from your datalog to generate the chart. The best accuracy will come from reducing the number of PIDs you are monitoring so that the log contains only those needed for the program to work. You get a better refresh rate and the chart will be better.
    If you are testing on level ground, or as close to it as possible, in the same location and direction, comparsion can be very useful in determining if something is amiss or if mods are improving performance.
    On the Mazdaspeed 3 platform 1.01 correction, as Skiptowncat notes, was very close to chassis dyno numbers for DynoJet. Can't say yet for us and the 3.0T engine.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Veteran Member Four Rings LittleDozer's Avatar
    Jan 21 2014
    C5 RS6, D4 S8, 2016 XC60
    Minneapolis, Minnesota
    I used an OBD reader on the A6 4.2 back in the day that auto calculated this stuff. The car should have been around 375 crank in perfect conditions and the app calculated power at 350. Not bad given the DA wasn't sea level and it was a pull in a hotter month. These things are probably pretty accurate.
    Jan 21 2014
    Quote Originally Posted by MSq5 View Post
    That's what I've been using the VCDS acceleration field for. We found that estimated 1/4 mile is DEAD ON to the track so long as ground is level. Great way to see how mods affect 1/4 mile times.
    Account Terminated Four Rings
    Mar 22 2016
    73 Jimmy 496 BBC
    Pretty cool program. Says I'm running about 400 hp and tq which is where I think I'm around. Will be cool to see the difference when I get this new tb and new meth tune. Fwiw
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    this is what mine says, great thread btw! took me a bit to figure out it though.
    I had to load the profile of the S5 based on internet search, and I averaged out the weight of the car (6mt cars are about 3850 without sport-diff, 7DSG 3900 without sport-diff)
    I think I used a smoothing of 2, but the numbers are SAE corrected above.
    Here are the numbers NOT SAE corrected (using actual weather conditions):
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Mar 22 2016
    73 Jimmy 496 BBC
    Loe do one with a full pull. From like 3k to redline. I just want to see if the numbers are any different. If I use a short pull like that my car shows higher numbers.... I'm at 435 hp and 415 tq now with a full pull.
    Mar 05 2016
    Quote Originally Posted by whiped View Post
    Setup:
    Code:
    Code:
      <CarParameters>
      </CarParameters>
      <CarParameters>
      </CarParameters>
      <CarParameters>
      </CarParameters>
      <CarParameters>
      </CarParameters>
    </CarDataset>
    Open Virtual Dyno
    Code:
    STAMP
    Engine speed
    Select the Gear
    Code:
    Using Virtual Dyno:
    Launch the Program
    Example graph using mine and FromRagsToS4's data
    I’m not a photobucket subscriber, is there a way to view the pics?
    Aug 08 2009
    belgium
    When u use this on a tuned engine you get way to positive results, all the signals are usually altered, especially torque output figures. You can have vcds put out 900Nm on a stock VW Lupo.
    Aug 09 2015
    Sarasota, FL
    This doesnt take altered signals like Nm
    Aug 08 2009
    belgium
    Quote Originally Posted by Loe View Post
    Which signals are used to calculate/input? I thought i saw torque in there?
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by TC_S4 View Post
    I'll fix them later.
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by pedro sr. View Post
    It calculates a virtual powerband based on logging parameters:
    -time stamp
    -engine rpm
    -accelerator position
    -manifold pressure
    -lambda
    Aug 08 2009
    belgium
    -time stamp
    -engine rpm
    -manifold pressure
    -lambda
    It's a bit poor without ignition, iat, airflow and so on. It's a god idea though, it can be pretty accurate when more inputs are used and not manipulated. This program is around for quite some time right? I think i have seen it 10-15 years ago allready.
    Aug 09 2015
    Sarasota, FL
    Why would it need those? Its an acceleration "dyno" which computes time from point A to point B (VCDS time stamp from engine rpm to engine rpm) to derive a virtual powerband based on vehicle .cd of drag, frontal area, vehicle weight, gearing.
    Impacts on IAT, ignition, airflow can be seen in a shortened or elongnated VCDS timestamp A to timestamp B
    Aug 08 2009
    belgium
    Ah. ok. Got the wrong angle of looking at things. I will give it a try. Sorry for my ignorance.
    Mar 05 2016
    That will be awesome!
    Apr 05 2016
    Portland, OR
    Images should be fixed
    Geoff
    Apr 05 2016
    Portland, OR
    Here are the logs I ran just prior to dynoing my car last month.
    Code:
    STAMP,Engine speed,Accelerator position,IGA_AD_1_KNK[0],IGA_AD_1_KNK[5],Ignition angle: actual,Intake air temperature,Intake manifold pressure: absolute,Lambda probes actual: bank1,Lambda probes actual: bank2,RFP_AV
    130.46,1905,44,0,0,19.875,29.25,1512.33,0.8135,0.7529,0.33
    130.63,2035,66,0,0,20.25,29.25,1799.81,0.7988,0.7773,0.08
    130.8,2079,78,0,0,19.875,29.25,1862.33,0.7842,0.79,0
    130.97,2133,80,0,0,21,28.5,1884.05,0.7559,0.7695,0
    131.14,2265,90,0,0,21,28.5,1929.16,0.7852,0.79,0
    131.31,2361,90,0,0,21.75,28.5,1977.91,0.7744,0.7803,0
    131.48,2419,90,0,0,22.125,27.75,2020.62,0.7773,0.7822,0
    131.65,2533,90,0,0,22.875,27.75,2077.58,0.79,0.7793,0
    131.82,2637,90,0,0,22.5,27.75,2114.89,0.7803,0.7852,0
    131.99,2693,90,0,0,22.875,27.75,2152.62,0.7842,0.793,0
    132.16,2809,90,0,0,22.875,27.75,2192.59,0.79,0.8027,0
    132.33,2929,90,0,0,23.25,27.75,2225.42,0.7979,0.7979,0
    132.5,2983,90,0,0,22.875,27.75,2263.9,0.7813,0.8047,0
    132.67,3105,90,0,0,22.875,28.5,2300.55,0.7803,0.8086,0
    132.84,3235,90,0,0,23.25,28.5,2322.6,0.7988,0.8154,0
    133.01,3362,90,0,0,23.25,29.25,2341.59,0.7979,0.7969,0
    133.18,3435,90,0,0,23.25,30,2339.93,0.8164,0.8076,0
    133.36,3567,90,0,0,23.625,30.75,2339.27,0.8135,0.8184,0
    133.53,3681,90,0,0,24,31.5,2353.7,0.8184,0.8135,0
    133.7,3733,90,0,0,24,32.25,2375.17,0.8145,0.8193,0
    133.87,3849,90,0,0,23.625,33,2385.04,0.8164,0.8115,0
    134.04,3975,90,0,0,24,33.75,2401.87,0.8066,0.8125,0
    134.21,4082,90,0,0,23.625,34.5,2405.35,0.8174,0.8086,0
    134.38,4156,90,0,0,24,34.5,2398.56,0.8223,0.8115,0
    134.55,4271,90,0,0,24.375,36,2394.82,0.8213,0.8125,0
    134.72,4391,90,0,0,24.375,36.75,2400.21,0.8125,0.8174,0
    134.89,4462,90,0,0,25.125,36.75,2404.86,0.8184,0.8213,0
    135.06,4555,90,0,0,24.75,37.5,2403.94,0.8154,0.8164,0
    135.23,4685,90,0,0,25.125,38.25,2432.72,0.8262,0.8213,0
    135.4,4740,90,0,0,25.5,39,2425.01,0.8193,0.8193,0
    135.57,4859,90,0,0,25.5,39.75,2418.21,0.8369,0.8184,0
    135.74,4984,90,0,0,25.875,39.75,2419.78,0.8164,0.8252,0
    135.91,5089,90,0,0,25.875,40.5,2439.77,0.8262,0.8164,0
    136.08,5156,90,0,0,26.625,40.5,2428.57,0.8262,0.8096,0
    136.25,5256,90,0,0,26.625,41.25,2431.22,0.8174,0.8018,0
    136.42,5373,90,0,0,26.625,42,2440.93,0.8154,0.7959,0
    136.59,5426,90,0,0,27,42,2448.39,0.8164,0.8115,0
    136.76,5533,90,0,0,26.625,42.75,2437.28,0.8018,0.8027,0
    136.93,5640,90,0,0,27,43.5,2434.62,0.8027,0.8135,0
    137.1,5695,90,0,0,27,43.5,2429.07,0.8018,0.8105,0
    137.27,5818,90,0,0,27.375,44.25,2430.89,0.8018,0.8193,0
    137.44,5891,90,0,0,27,44.25,2425.59,0.8105,0.8164,0
    137.61,5997,90,0,0,27,45,2428.07,0.8018,0.8105,0
    137.78,6042,90,0,0,27,45.75,2427.91,0.7998,0.8145,0
    137.95,6165,90,0,0,27.375,45.75,2423.93,0.8223,0.8164,0
    138.12,6259,90,0,0,27.75,46.5,2428.07,0.8242,0.833,0
    138.29,6315,90,0,0,27.75,46.5,2415.97,0.8213,0.8232,0
    138.46,6418,90,0,0,27.75,47.25,2427.74,0.8252,0.833,0
    138.63,6493,90,0,0,27.75,48,2430.4,0.832,0.8135,0
    138.8,6544,90,0,0,27.75,48,2416.38,0.835,0.8379,0
    138.97,6643,90,0,0,28.125,48.75,2424.18,0.8389,0.8447,0
    139.14,6745,90,0,0,28.875,49.5,2425.09,0.8379,0.8457,0
    139.31,6843,90,0,0,28.875,50.25,2430.73,0.8379,0.8516,0
    139.48,6915,90,0,0,29.625,50.25,2426.5,0.833,0.8398,0
    139.65,7025,90,0,0,29.25,51,2422.6,0.8408,0.832,0
    139.82,7099,90,0,0,29.625,51.75,2429.48,0.8369,0.8398,0
    139.99,7147,90,0,0,29.625,51.75,2441.01,0.8467,0.8418,0
    140.16,7207,90,0,0,29.625,52.5,2438.69,0.8301,0.8369,0
    140.33,7276,90,0,0,30,53.25,2444.91,0.8096,0.8135,0.08
    140.5,7407,90,0,0,30,53.25,2460.83,0.8164,0.8223,1.67
    140.67,6241,90,0,0,6,54,2460.83,2.3975,2.2764,0
    Geoff
    Mar 05 2016
    Yes!, thank you very much. Now I know what to do on my free time😁
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by evil35r View Post
    with a long pull, the VD seems to be off for me, it shows 12xx AWTQ in the beginning at 3000rpm, and then it normalizes back down to 5xx awhp.
    Jul 05 2014
    Houston
    So youre saying its about right?
    Apr 05 2016
    Portland, OR
    Did the car downshift? I know some files if you let the rpms drop too low it will force a shift even in manual mode.
    Geoff
    Aug 09 2015
    Sarasota, FL
    no on the downshift, it was in gear.
    Apr 05 2016
    Portland, OR
    Weird, on the left side under the run details is a slider that shows RPM, you can slide the left one up a bit to cut out the 'junk' data to get a better graph.
    These are even less fair to compare than real dyno sheets but if you consistently log on the same road, the same way it should show you some tangible results between logs.
    I'm excited to see what Pre and Post ported blower will show. I'll likely hop back on an actual dyno the end of March once my car is in summer mode.
    I could go run on the local dynojet instead of the dynodynamics I normally run on if I wanted to see a 5XX dyno
    Comparing it to my old dyno would be worthless but my E-peen would be bigger
    Geoff
    Feb 14 2017
    Gulfport, MS
    Forgive me if I'm an interloper. I have a Q5 3.0T. It has the 8 speed ZF auto. That presents a challenge for Virtual Dyno (VD - I know a bad name). I have another high performance car with a stick shift and have been using datalogging and VD for, gee, maybe eight years, with great results and consistency.
    But, with a slushbox that downshifts at WOT, even in manual mode, I will only be able to capture a small part of the power band. I've set up a VD specific log file and will give it a try, but I doubt I can capture anything under 4,000 rpm.
    Apr 05 2016
    Portland, OR
    One of the other local cars had this issue too, the ECU/TCU likes to force the downshift. This caused issues with this software and when we actually dyno'ed the car.
    Results don't end up being ideal but a pull from 4k->redline will still tell you something about the car. Especially if comparing it to a similar pull of your car.
    Geoff
    Jul 01 2012
    Setup:
    Code:
    Code:
      <CarParameters>
      </CarParameters>
      <CarParameters>
      </CarParameters>
      <CarParameters>
      </CarParameters>
      <CarParameters>
      </CarParameters>
    </CarDataset>
    Open Virtual Dyno
    Code:
    STAMP
    Engine speed
    Select the Gear
    Code:
    TIMELoc. IDE00021Loc. IDE00086Loc. ENG100261Loc. ENG100449Loc. ENG100030Loc. ENG102932Loc. ENG101741Loc. ENG101388Loc. ENG102763Loc. ENG99738
    STAMPEngine speedAccelerator positionEngine torqueIGA_AD_1_KNK[0]IGA_AD_1_KNK[5]Ignition angle: actualIntake air temperatureIntake manifold pressure: absoluteLambda probes actual: bank1RFP_AV
    Using Virtual Dyno:
    Launch the Program
    Hey whipped are the log setup info for the
    " columns and profiles" info" is that info specific to using vcds or general? Being I'm using torque for logging atm moment and trying to dial in virtual Dyno to accurate setting for my car and for possibly other cars
    Sent from my LG-H918 using Tapatalk
    Apr 05 2016
    Portland, OR
    Yes it is specific for VCDS and our car.
    If you delete it the app will guess which might work with Torque.
    If not you will need to look at the log headings and adjust those settings to match.
    Geoff
    Aug 09 2015
    Sarasota, FL
    stickied, I love this thing, it's such a great tuning tool to utilize to let you know which combination works best. I use(d) it, worked out great to let me know how ignition advancement/corrections, and running a car purposefully lean(er) impacts performance
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    My shit fast yo
    FBO B8. ~ 10.95@126 ~ 2.96s 0-60 ~ full weight street tires.
    Apr 05 2016
    Portland, OR
    Here are some logs from my last tune Revision if you want to use them to compare:
    Code:
    STAMP,Engine speed,Accelerator position,Engine torque,Ignition angle: actual,Intake manifold pressure: absolute,Lambda probes actual: bank1,RFP_AV
    217.639,1814.917,90.58823,513,17,1781.4,0.818359,0
    217.733,1888.914,93.33334,524.2188,17,1815.065,0.821289,0
    217.842,1935.911,95.68628,535.9063,18.5,1845.91,0.810547,0
    217.936,2003.908,98.43137,545.9688,18.5,1882.891,0.814453,0
    218.029,2070.905,99.60784,557.8125,18.5,1914.068,0.789063,0
    218.139,2133.902,99.60784,560.625,18.5,1948.147,0.766602,0
    218.233,2208.899,99.60784,573.5,19.5,1985.211,0.78418,0
    218.326,2272.896,99.60784,587.8125,20,2021.944,0.807617,0
    218.42,2339.893,99.60784,599,20,2058.842,0.789063,0
    218.529,2415.889,99.60784,611.1875,21,2104.861,0.78418,0
    218.639,2484.886,99.60784,626.2188,21,2149.637,0.790039,0
    218.733,2561.883,99.60784,634.5625,21,2186.535,0.775391,0
    218.826,2630.88,99.60784,642.1563,21.5,2200.134,0.791992,0
    218.92,2709.876,99.60784,648.1875,21,2228.243,0.801758,0
    219.014,2785.873,99.60784,659.4688,21.5,2259.585,0.770508,0
    219.123,2857.869,99.60784,665.8438,21.5,2289.602,0.833008,0
    219.248,2931.866,99.60784,675.7188,21.5,2326.749,0.820313,0
    219.342,3010.862,99.60784,678.6875,21.5,2339.85,0.822266,0
    219.436,3088.859,99.60784,681.0938,21.5,2384.21,0.801758,0
    219.53,3164.855,99.60784,677.75,21.5,2388.771,0.799805,0
    219.639,3249.851,99.60784,680.6875,21.5,2407.013,0.822266,0
    219.733,3327.848,99.60784,682.9688,21.5,2418.207,0.817383,0
    219.827,3411.844,99.60784,678.625,21.5,2412.651,0.826172,0
    219.92,3492.84,99.60784,677.4375,22,2412.403,0.84082,0.025635
    220.03,3572.836,99.60784,679.4688,22,2415.968,0.823242,0
    220.139,3653.833,99.60784,680.9063,22.5,2416.051,0.826172,0
    220.233,3729.829,99.60784,680.75,22.5,2439.351,0.820313,0
    220.326,3813.825,99.60784,687.4688,22.5,2441.009,0.818359,0
    220.42,3884.822,99.60784,692.8438,23,2452.949,0.84082,0
    220.514,3971.818,99.60784,696.25,22.5,2463.397,0.805664,0
    220.608,4048.815,99.60784,699.875,22.5,2469.781,0.81543,0
    220.701,4131.811,99.60784,700.875,23,2460.909,0.822266,0
    220.811,4204.808,99.60784,702.25,23,2454.027,0.833984,0
    220.92,4286.804,99.60784,703.8125,23,2451.291,0.828125,0
    221.014,4361.8,99.60784,713.8125,23,2462.485,0.821289,0
    221.108,4449.796,99.60784,705.8125,23.5,2465.719,0.836914,0
    221.217,4521.793,99.60784,714.4375,23.5,2481.887,0.823242,0
    221.311,4587.79,99.60784,714.1563,24,2461.241,0.81543,0
    221.404,4683.786,99.60784,719.875,24,2444.989,0.828125,0
    221.514,4752.782,99.60784,717.6875,24,2449.135,0.827148,0
    221.608,4831.779,99.60784,720.9688,24.5,2462.319,0.833984,0
    221.701,4908.775,99.60784,730.1875,24.5,2451.208,0.837891,0.076904
    221.811,4974.772,99.60784,720.4688,25,2463.231,0.842773,0
    221.936,5040.769,99.60784,724.5938,25,2463.646,0.822266,0
    222.029,5138.765,99.60784,719.1875,25.5,2469.118,0.827148,0
    222.139,5208.762,99.60784,715.6563,25.5,2476.249,0.827148,0.128174
    222.233,5268.759,99.60784,719.5313,26,2466.962,0.819336,0
    222.342,5417.752,99.60784,713.5,26,2460.743,0.817383,0
    222.467,5498.748,99.60784,707.1563,26,2474.093,0.821289,0
    222.577,5573.745,99.60784,707.8125,26,2465.635,0.820313,0
    222.671,5628.742,99.60784,711.1563,26,2459.5,0.818359,0.128174
    222.764,5703.739,99.60784,714.7188,26,2473.596,0.822266,0
    222.874,5783.735,99.60784,714.0938,26.5,2459.334,0.818359,0
    222.983,5844.732,99.60784,714.0313,26,2464.309,0.81543,0
    223.077,5929.729,99.60784,719.2813,26,2471.191,0.806641,0.102539
    223.186,5997.726,99.60784,719,26.5,2465.802,0.8125,0
    223.28,6029.724,99.60784,720.0938,26,2469.45,0.819336,0
    223.389,6122.72,99.60784,717.1563,26.5,2469.035,0.816406,0
    223.483,6183.717,99.60784,712.5625,27,2466.713,0.807617,0
    223.577,6246.714,99.60784,708.5625,26.5,2470.942,0.832031,0
    223.686,6311.711,99.60784,702.6875,27.5,2474.591,0.831055,0
    223.78,6393.708,99.60784,699.8438,27,2477.741,0.821289,0
    223.874,6446.705,99.60784,692.5,27,2460.743,0.84082,0
    223.967,6496.703,99.60784,692.375,27.5,2473.098,0.84082,0
    224.061,6561.7,99.60784,685.2813,27.5,2466.713,0.838867,0
    224.155,6626.697,99.60784,693.0313,27.5,2457.095,0.84082,0
    224.249,6626.697,99.60784,691.0938,27.5,2460.246,0.844727,0
    224.342,6686.694,99.60784,683.7188,27.5,2476.829,0.838867,0
    224.436,6743.691,99.60784,685.4688,27.5,2473.596,0.844727,0
    224.546,6865.686,99.60784,681.7188,28,2467.957,0.838867,0
    224.655,6915.684,99.60784,681.5,28,2456.515,0.850586,0
    224.765,6976.681,99.60784,677.5,29,2469.947,0.844727,0
    224.858,7022.679,99.60784,674.2188,29,2482.219,0.848633,0
    224.952,7080.676,99.60784,668.6563,29,2480.478,0.84375,0
    225.061,7123.674,99.60784,660.5938,29,2483.297,0.837891,0
    225.155,7172.672,99.60784,652.4063,29,2458.422,0.827148,0
    225.249,7172.672,99.60784,646.1563,29,2484.541,0.820313,0
    225.343,7253.668,99.60784,648.0938,26.5,2449.467,0.820313,0
    Geoff
