Originally Posted by
Gusman1
My understanding is that it really comes down to the install. If you install the system correctly, you shouldn't really have any issues. I know several people that have been on air for years without issue.
Look at all the semi-trucks, they run on airbags for hundred of thousands of miles.
Airlift is the other company that offers great air suspension systems. The ride quality of an air setup is great and a lot better than a lot of people think.
Went from KW V3 to AirLift 3H with AirLift Performance struts (we used the Accuair sensor brackets though... they are nice). The AirLift struts ride just as nice as the oem from a comfort perspective, and just as solid as my coilovers (although I can't adjust rebound anymore). And with dampening control, I dialed the ride in exactly how I want it. Most of what I've read out there suggest that AirLift has better struts. Accuair management is slightly better, but not enough to make me pay the extra over the AirLift.
Install is the key like Gusman says. My local installer hasn't had any catastrophic failures, and he's been bagging for a very very long time. If course he does a full system test over day after install.
I've seen other installs that are so bad, they just waiting to fail.
If you have the budget, I'd recommend bagging. It's not a fad for me, I use it to air up over bumps and steep driveway access all the time. Rough patch of road? No problem. Air up to factory height, cruise for a couple miles, then drop it back down to ride height.
And like Gusman said, air bags are used in seriously heavy duty applications that log millions of miles. Big rigs, Fire trucks, million dollar motorhomes and even our high line Audi's
Watch this video about this "fad" that's been going on since the 50's:
http://www.speedhunters.com/2014/05/...ir-suspension/
And another on how they did what they do:
https://m.youtube.com/watch?v=8e-pw8DEr2M
Air ride isn't just for hellaflush, they are also for performance.
Anyways, good luck with your decision.
