This makes sense to me. It could be the root/major cause of the carbon build up. I'll be reading more of the thread.
Post #84 on page three
http://www.audizine.com/forum/showth...=1#post9887102
"From the latest updates I have received, recirculating carbon species from both the crankcase breather and combustion process are only minor contributory factors. Testing has proved that the primary source is from the valve stem seals. The actual cause of the build-up is interesting but not surprising.
The efficacy of water/methanol injection is very limited because the build-up is primarily composed of very hard and chemically active long-chain carbons (engine oil), which create VERY hard layers of carbonaceous build-up.
I am in the fuel and oil modification business and have been working with numerous parties on this issue for a number of years now. I have written an article on this revealing to exact reason but I am awaiting permission before I can publish it."
edit: I was reading and trying to understand the thread for 3-4 hours. Some very interesting stuff from AndyUK around mid-2014. He summarizes in post #160
"FACT 1: The majority of the build-up is oil from the valve stem lubrication process. This is the first common
denominator and has been known for some time.
FACT 2: The oil is catalysing with the valve because of the nickel and chrome alloys used to harden the valve.
This is the second common denominator and the ROOT CAUSE unforeseen by the manufacturer.
FACT 3: Due to a number of factors that I can’t detail now, the carbon remains chemically active to such a
degree that it becomes a “magnet” for ALL CARBON SPECIES.
This provides us with very valuable information such as WHY the oil bonds so readily (FACT 2) and WHY it won’t
self-manage (FACT 3). Are there other factors? Of course, but the fact remains that all TFSI engines suffer from
build-up. We also know that NA engines are worse off etc., etc. The main variable is mileage."
He mentions using the 502 and 505 types of oil. He wouldn't mention a brand because he's in the business and blends change rapidly and they are different for different areas. He uses a blend in his car.
So there's a guy selling catch can systems that says it will stop 90% of the build up and a researcher in the UK that says that the oil is coming from the valve stem lubrication process. My brain hurts...
