Originally Posted by
Davdraco1
Ou don't bleed it thru the hose. You bleed it thru the expansion tank. Just leave the cap off and get the motor hot. No need to make a mess.
I'm pretty sure that's why the hose has a hole. For no mess. Either way, going to run a compression test and block test to see if there's any CO2.
B5 Gang
Are you actively losing coolant?
I'm not. I thought I did because I had coolant on my driveway (obviously it has to be low). I went to work one morning and my car became warmer faster than usual. Coolant was definitely low but due to a warped flange. Swapped that out. Topped it off. No leaks found, or at least not yet.
walky_talky20
Video of said bubbling, please.
I would but I'm going to do a block test in a bit and I want the engine cold so I can open the expansion tank before it becomes too pressurized. You can clearly see air going through the small top hose (vent hose?) of the tank. Hopefully you can visualize it
