Originally Posted by
Sloth682
1. By reading this thread. The torque steer and spins during launch raised and eyebrow, but I didn't put the pieces together until reading all this. I'm new to FWD/AWD vehicles!
2. 25k(miles), but I suspect this has potentially been an issue for 10k
3. 2016
4. None on the dash. I did just had my 25k service, and they didn't report anything. It is a bit disconcerting that it doesn't light anything up.
5. I have an appointment in 2 days with the dealer to take a look. In the mean time, I took this video today....
Note: I didn't know how to force it to run in slow mo, so you have to change playback speed to 0.25 in the youtube settings.
https://www.youtube.com/watch?v=XujRbz3f8hM
I also noticed that the front wheel lurches forward at the point of launch. Looks scary to me. Thanks again everyone who participated here. Hopefully helps to get my S3 back where it should be!
What did the dealer say?
From your video I can assure you your Haldex is trash and needs to be replaced.
When I had my S3, I've since traded it for an S4, My Haldex went out. They replaced THE ENTIRE Haldex unit.
I scanned and had a C111307 ALL Wheel Drive mechanical malfunction. This happened around 21K miles.
Symptoms where the traction control light would flash with just moderate throttle from take off. There were times I would get what seemed like axle hop followed by a loud bang from the rear. When I did launch control it would completely smoke the front tire.
From what Ive gathered, the 15's and early 16's seem to have this problem. My Haldex revision was an F. If you crawl under the car you can see the Haldex part number followed by a letter then dictates the revision. Mine was replaced with a revision H. I believe I have seen some get replaced with a K as well.
Take your service advisor for a ride along with the mechanic and perform a launch. There is no way they deny that something isn't wrong.
