Originally Posted by
TCHUN003
Seems like there are increasing cases of haldex failures.
If you've had haldex issues, post your:
1. How you discovered you had the issue
2. Mileage
3. Model year
4. Any error codes
5. What was done to fix it, and was it under warranty? I hear they are replacing the units with the ones from 2017's?
1) Took the car to an AutoX event with paper tags on it. Used LC at the start and experienced prolonged front wheel spin (5-6 seconds). Replicated it multiple times to make sure it wasn't a fluke.
2) I bought my S3 with roughly 16600 miles on it (CPO). I'm assuming this issue was not found during the CPO inspection (but then again other things weren't either but that's another story).
3) 2015 S3 2.0T Premium Plus
4) No error codes present, never ran a VAGCOM scan either but obviously something was up.
5) Covered under warranty by replacing the entire rear differential.
Note: Car is on stock ECU/TCU tune and hasn't had a problem since.
I'll edit this later with a video (for those wondering what the symptoms are) and my invoice from the warranty work.
Edit:
