Results 1 to 23 of 23
    Established Member Four Rings limeypride's Avatar
    Mar 18 2017
    Snohomish
    Will 295s fit on 2017 RS7 Performance stock wheels
    Hey guys,
    Per the subject, I'm trying to ascertain whether Michelin PSS 295s will fit on my factory wheels. I've tried to determine the rim width online but with little success. I reverted to measuring an approx. rim width from one of the wheels and it leads me to believe the rim width is somewhere between 9" and 10". For 295, 10.5" would be needed (I think).
    Does anyone know for sure either what these wheels will take or what the rim width actually is?
    If it helps, these are my current wheels riding 275/35/21s all around stock:
    2018 ////AMG E63S in Diamond White/Nut Brown, lowered 20mm front/back, spacers, tints, EuroCharged tune
    Gone but never forgotten
    2017//RS7 Performance in Mythos Black, Audi exclusive Titanium edition w/ Akrapovic exhaust
    Oct 22 2014
    Atlanta, GA
    Here's a handy guide I've been using https://www.pakwheels.com/forums/att...ntitled-35.png
    Mar 18 2017
    Snohomish
    Quote Originally Posted by SpectreGadget View Post
    Thanks. I found something similar which somewhat motivated my question. I've been working on the basis that my rim width is 10.5" but I stumbled across an article that lead me to believe that's not the case for these new 2017 rims. Having dug around online for a while, I could turn nothing up regarding these new rim's dimensions... so I tried to measure it and there's no way the rim width is 10.5". Given that I've already ordered 4 x 295/25/21 MPSSs from Tirerack, it seemed prudent (nay, urgent :-) to find out for sure.
    Veteran Member Four Rings IowaRS7's Avatar
    Mar 22 2017
    69 Camaro SS
    Iowa
    A few places to look:
    1. Window sticker, will sometimes show wheel specs
    2. Owners manual will often show the specs
    3. The wheels themselves are usually stamped with specs on the backside somewhere.
    My stock 21" wheels are 21x9 with 275/30/21 tires. A 295, especially the MPSS would be too much IMO. The MPSS tires are beefier than the typical stock Conti tires Audi uses. I may run those 295s on my new wheels that are 10.5 after the contis need replacing.
    Mar 18 2017
    Snohomish
    Quote Originally Posted by IowaRS7 View Post
    Thanks. I started with the window sticker but no luck there. The owner's manual was a similar story, it seems Audi don't produce model-specific manual variations so it has wheel specs for A7s/S7/RS7s and, worse, none of it references these new 2017 wheels.
    I haven't tried to get to the backside of the wheels but I did measure the width of the mounted tire. These Contis don't protrude much beyond the rim so I used their mounted width as a guide and it's way too narrow for 295s... sigh.
    Dec 20 2006
    CAN
    Given that stock RS7 (non-performance) rims are 9" and tires are 275 that handy chart is incorrect.
    However, as mentioned the pss are a different profile and will probably be too large for your stock performance rims unless they are at least 10" wide imo.
    emilyPay.com - Payment Processing for Professionals
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Healiner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Mar 18 2017
    Snohomish
    Quote Originally Posted by CanuckRS View Post
    Yeah, agreed, it's not perfect. The one I use does indicate that 9" rims will hold 275s at a push but your point still stands... I need to re-think my plans.
    Senior Member Three Rings RSLRS71's Avatar
    Mar 03 2017
    18' SQ5 and WK2 SRT8 Jeep
    Castle Rock, CO
    i personally dont think it woul dwork out too well, especially if there are any plan to lower it....with my 21x10.5 rims and stock tires, there are some issues up front with clearance as is.
    2017 RSL RS7 (1 of 3 stateside)
    Mods:
    Current: APR Stage II w/ HF DPs and KW H.A.S kit , Rotiform 3 piece SPF 21x10.5 wheels, Tag Motorsports Side marker delete and Badge blackout, ...
    Next: looking to be the quickest RS7! ;)
    Veteran Member Four Rings cobrario's Avatar
    Oct 28 2014
    2015 Q5 3.0T, 2019 Toyota Tundra CM Limited , 87 Buick Grand National
    Northern VA
    thats too much tire for a 9" wheel, especially going to a 25 profile which mean the section width and tread width are near identical
    2018 Ara Blue RS3
    IG @cobrario_rs & @audivstheworld
    Nov 18 2014
    Jersey
    I was under the impression that 295/25/21 was used on the stock wheels by a ton of members. I actually am picking my car up tomorrow with that size tire on my stock blade style wheels. I'll report back.
    Oct 28 2014
    Northern VA
    Quote Originally Posted by Rez90 View Post
    I'm not sure it can't be done, I just wouldn't think it's recommended- the min wheel width recommended by Michelin for that size is 10", I'd think you'll be crowning the tire pretty badly on a 9" wheel and probably not get the best wear or performance from them on that size wheel.
    2018 Ara Blue RS3
    Jan 05 2017
    Lakewood, CO
    Its also important to note. I believe the stock 275 is an average all season tire, however not completely sure. The Michelin PSS is a high performance summer tire. I think many people make the mistake in thinking an all season tread and summer tire tread are the same size, however it is well known the PSS has a very wide tread pattern. In reality with the stock 9 inch wheel it would have a 265 or even a 255 with a performance summer tire. Due to this a 295 PSS is going to be HUGE on the stock wheel, that's assuming it would fit on the wheel at all.
    Dec 20 2006
    CAN
    Check out the rubber profile of pss vs stock contis. Left pss, very flat profile vs the rounded one for the conti's.
    Additionally, check out the fitment of the 295/25/21PSS on a 10.5" rim! No way a 9" wide rim will work properly imho.
    Mar 18 2017
    Snohomish
    Quote Originally Posted by cobrario View Post
    The stock wheels on my car are 9"--there's no way I'm gonna try and wedge a 295 on that. Even 275 defies most common guidance. New wheels <-> skinny tires == new wheels it is then.
    Mar 18 2017
    Snohomish
    Quote Originally Posted by Siouxbie View Post
    No mistake here at least--I've had the MPSSs on my past 5 BMW M-cars and I love 'em. The Contis that came with my car are summer performance but as noted in another post, their profile differs wildly; I'm not a fan of their traction so far either.. The MPSSs also have a fantastic rim protector which artificially increases the stature of the tire/car when viewed from the rear (and stops my wife from curbing my rims, too, which is always a bonus).
    Veteran Member Three Rings 3rdBNCC's Avatar
    Jul 18 2014
    2014 Audi RS7
    Vero Beach FL
    I forgot if you already mentioned this before but is your car lowered?
    2014 RS7 Daytona Gray Pearl APR Stage 2
    10.319 @ 131.82 on GT260+
    Video:https://youtu.be/qnqCdZK3KnE
    IG: @Spikes_RS7
    2018 RS3 Mexico Blue Stage 2 (For Sale)
    2017 RS7 Performance Glacier White (Stock for now)
    2016 S5 Cab Black APR Stage 1 (Sold)
    2014 A5 Cab Black APR Stage 1 (Sold)
    2013 S7 White APR Stage 1 (Sold)
    2011 A6 Silver APR Stage 2 (Sold)
    Dec 20 2006
    CAN
    Quote Originally Posted by 3rdBNCC View Post
    ABsolutely! :)
    Jul 18 2014
    2014 Audi RS7
    Vero Beach FL
    ABsolutely! :)
    With Vag? Links? Or a lowering module? Any rubbing on your setup? My MPSS 285 30 21s rub a bit on sharp turns. Currently lowered on VCDS and links but waiting for my new CETE lowering module to arrive.
    IG: @Spikes_RS7
    Dec 20 2006
    CAN
    Links and vcds. No rubbing but maybe i'm not as slammed as you but i think i'm pretty low!
    I think the reason for your rubbing though is that 285/30 has a much bigger sidewall height than 295/25(86mm vs 74mm) and as a result has quite a bit bigger overall tire diameter than mine. (ie., 681mm vs 705mm = 24mm or 2.4cm overall larger diameter)
    I have to say these bathurst rims with 295/25 rubber are friggin perfect, i'm glad i spent months investigating the options out there.
    Mar 18 2017
    Snohomish
    I've asked this a few times to a few folks but I don't think I'm duplicating that question here: are you running those 295s on all four corners?
    Jul 18 2014
    2014 Audi RS7
    Vero Beach FL
    Can you either send me pics or post them. I would be interested in seeing just how low you are.
    IG: @Spikes_RS7
    Dec 18 2014
    DMV
    Quote Originally Posted by limeypride View Post
    I believe he is. I'm running 295/30/20s on all 4 corners and lowered on VCDS no rubbing. I think CanuckRS is on 21s.
    Sold: 15 S4, 16 Tornado Gray S6, 16 Glacier White RS7, 18 White Q5
    Current: Black SQ5, Black V10 R8
    Next: Gemera
    Dec 20 2006
    CAN
    yes, all 4 wheels are the same.
    it looks lower in person than it does in images. i wouldn't want to be any lower mostly because of hitting curbs, bumps etc...
