For the past few months, my driver side front door won't consistently lock or unlock with the key fob. After the car has been sitting for a few hours, it almost certainly does not work, but seems to work half the time otherwise. All other doors work fine, and the issue door does lock and unlock using the key.
I was thinking it might be the door actuator, but would it make sense if the problem is intermittent? Logically I would think if a door actuator failed, the door would never work with the key fob.
Anyone else run into this issue? From my searches, I'm thinking it could be 3 things:
- bad actuator
- mechanism needs to be cleaned/re-oiled
- someone mentioned it could also be the physical lock/unlock button on the door
