Originally Posted by
walky_talky20
I'm not understanding what the scope of work was, exactly. Why was the intake manifold removed for an ECU upgrade?
Did you remove the valve cover as well?
Please post all 7 codes with the code number and description.
I bought new injectors for it with the intention of putting them in and getting a tune straight after but this never happened.
When I had the injectors out a small amount of dirt got into the intake manifold (rookie mistake I know) so I had to remove it and vacuum out the dirt with a small concentrated hose. This is why all of the intake side was removed and cleaned.
VCDS-Lite Version: Release 1.2
Thursday, 27 April 2017, 23:42:19.
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56 ,57,65,67,69,75,76,77
Address 01: Engine Labels: Redir Fail!
Controller: 8E0 909 518 AK
Component: 1.8L R4/5VT G 0003
Coding: 0016711
Shop #: WSC 63351
VCID: 79856EE770C1
12 Faults Found:
17700 - Map Controlled Engine Cooling Thermostat (F265): Open Circuit
P1292 - 004 - No Signal/Communication - Intermittent
16684 - Shareware Version. To Decode all DTCs
P0300 - 001 - Please Register/Activate
16688 - Shareware Version. To Decode all DTCs
P0304 - 008 - Please Register/Activate - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 001 - Upper Limit Exceeded
18010 - Shareware Version. To Decode all DTCs
P1602 - 002 - Please Register/Activate - Intermittent
16687 - Shareware Version. To Decode all DTCs
P0303 - 008 - Please Register/Activate - Intermittent
16840 - EVAP System: Very Small Leak Detected
P0456 - 002 - Lower Limit Exceeded - Intermittent
16685 - Shareware Version. To Decode all DTCs
P0301 - 008 - Please Register/Activate - Intermittent
17769 - Shareware Version. To Decode all DTCs
P1361 - 004 - Please Register/Activate - Intermittent
17772 - Cylinder 4 Ignition Circuit: Open Circuit
P1364 - 004 - No Signal/Communication - Intermittent
17881 - Shareware Version. To Decode all DTCs
P1473 - 004 - Please Register/Activate
16486 - Shareware Version. To Decode all DTCs
P0102 - 002 - Please Register/Activate
Readiness: 0010 0001
