Results 1 to 8 of 8
    Established Member Two Rings lil98civi's Avatar
    Oct 26 2009
    Illinois
    Warm up catalyst code P0421
    So I've been knocking out some problems and I keep getting a code for a bad cat. I decided to do piggies and got rid of that code but code P0421 warm up catalyst bank 1 efficiency below threshold and there's a pending code for bank 2 as well, am I looking at o2 sensors?anyway to test them? Shouldn't need spacers for the o2 sensors if I relocated them behind the main cat right?
    Veteran Member Three Rings my_RS4's Avatar
    Apr 15 2016
    Beach Cruiser
    Venice
    I've gotten this exact same code a few times now. Cleared it, then it came back several weeks later, after extended periods of driving. I'm running a valved Milltek exhaust. Anyone else deal with this reoccurring code??
    On a side note I'm dealing with some hesitation in power issues when WOT above 5k rpm. Replacing fuel pump and fuel filter soon and just replaced MAF sensor over the weekend. If these don't solve the issue I'll look at injectors next. Car was carbon cleaned 4k miles ago with new spark plugs, but not coil packs since they were 20k/4 yrs old.
    IG @myRS4 | 2007 RS4 | Phantom Black | Ti Converted | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed + Citied + CC'd | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | JHM Lighweight Flywheeled | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
    Established Member Two Rings S42RS4's Avatar
    Mar 16 2015
    Tacoma, Wa
    I would try to replace the O2 sensors. I'm on the same boat as we speak. I drop my car off at the stealership to get them change out so hopefully I won't have that code no more.
    Nov 25 2011
    2018 F80 M3 ZCP, 2007 RS4
    Change your rear o2 sensors. I had the same codes, new rear sensors fixed the problem. For me it happened right after I changed to catless DPs. O2 sensors can get damaged easily when you take them out and reinstall them.
    Apr 15 2016
    Beach Cruiser
    Venice
    Quote Originally Posted by AJacksA4 View Post
    Right on... I'll go this route. Thanks for the info.
    Oct 26 2009
    Illinois
    Seems whoever had the car before me had the o2 sensors switched the primary's were on the rear and secondary's on the front haha I got 2 new primary's and a new maf now I'm throwing lean codes and no cat codes
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Quote Originally Posted by lil98civi View Post
    Good piece of info. Never heard of rear's throwing any codes apart from when the pre-cats are "not working" as the rear sensors are passive and don't send any data to the ECU to which the ignition is adjusted.
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Oct 26 2009
    Illinois
    It was throwing codes for bad cats which makes sense because the primary's were monitoring after the cat and the secondary's were monitoring before the cats
