Results 1 to 30 of 30
    Jan 05 2017
    Ontario
    A4 B6 rear brake question
    Hi everyone, I'm about to replace the rear brakes and rotors on my A4 Avant. Seems like a fairly simple job. I know there are alot of diy's for this job but I noticed on some of them (and in my Haynes manual) it mentions having to reset the self adjusting parking break. While other step by steps (Pelican Parts for example) don't even mention it.
    Is this step necessary? Or is there a way to know if this is needed after the brakes/rotors have been swapped (symptoms ect).
    Also, I've borrowed one of the piston compressing tools from a friend. The kit comes with a right hand and left hand threaded tool. Do you happen to know which one will be needed? I'm sure I can try them both once I tackle the job but if I can avoid putting pressure on the piston in the wrong direction that would be great.
    Thanks in advance!
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    I swapped full calipers on mine and didn't have to do anything with the ebrake. Just installed the cable ends into the lever mechanism at the caliper. Since the mechanism is self-adjusting, you just pull up on the handbrake a few times and it tightens to proper level.
    If you have the piston tool, it will be fairly obvious what to do. Here's a video showing similar caliper and the piston compression tool in action @ 2:45: https://www.youtube.com/watch?v=85Qan0Co9mc
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Jan 05 2017
    Ontario
    Beauty. Thanks for the reply!
    Feb 27 2011
    Winnipeg
    make sure you don't strip the 8mm allen holding the rear carriers on. If you do its a pain to remove them.
    Senior Member Three Rings A4-Mike's Avatar
    Jun 12 2016
    Melbourne, Australia
    The rear brakes are on a worm screw that's how they self-adjust, all you need is the brake piston tool that screws it back in then the self adjusting parking brake is reset.
    Sent from my E6653 using Tapatalk
    Jan 05 2017
    Ontario
    Managed to get the old rotor off without removing the carriers. The allen bolt is stuck pretty good. Going to have to douse it with penetrant and maybe a few whacks with a hammer. Also pleased to see there is no room to fit a tool in to get to the lower carrier bolt. I've read that if you can get the upper one out you can rotate the carrier out of the way and get a new rotor in. I'm quite confused on why Audi would choose to put an 8mm thats prone to stripping in a spot thats so prone to rusting. Added to the fact I'd need to remove the shock bolt to even get to the lower bolt.
    Anyways, after tearing the whole thing apart, I had to put it back together without replacing the pads/rotors until I have more time to soak the bolt in PB blaster.
    Lots of fun!
    Aug 13 2015
    NS
    My advice is to use a bolt extractor wrench and replace the bolt upon reinstallation with a new one. If you want you still reinstall old bolt with an allen key because using this methid you are only scraping the ouside of it anyway.
    See my steps here:
    http://www.audizine.com/forum/showthread.php?p=11748005
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    Quote Originally Posted by LarJames View Post
    How did you possibly do this?
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Quote Originally Posted by DPDISXR4Ti View Post
    Larger rotors will come off without removing the carrier. On my 3.0, I was able to change the rotors without removing the carrier, they just slid out and the new ones went in. I think if you have the small rears on the 1.8, you need to move the carrier, but the larger 1.8T brakes that were on some cars you don't.
    Sent from my Pixel XL using Tapatalk
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    I got some low profile allen bits and hammered it into the socket head so it wouldn't strip. Still screwed up one bolt before I realized it was an allen and not a torx.
    https://www.amazon.com/Short-Tools-1...ords=short+8mm
    Please Drive Right
    Jan 05 2017
    Ontario
    Hey eljay, I read your post and put a sale alert on this wrench set (I live in Guelph ON so I feel your pain with finding tools in Canada sometimes). These things look like they will do the job nicely. And I don't need to ruin the bolt. I think I have essentially the same car as you so I'm sure you feel my pain.
    Thanks for the tip!
    Larry
    Jan 05 2017
    Ontario
    I watched a Youtube tutorial and saw a fellow do it. Since me rotors are fairly worn, there is enough room on the hub to rotate the rotor most of the way off and you can tap it out with a rubber mallet (mine just came out with some wiggling). Hard part arrived when I tried to put the new one on. Since it was full thickness it wouldn't go in. Its possible if I gave it a few good whacks with the hammer it would, but it will also likely scratch the heck out of the rotor on the edges of the calliper carrier. After getting shut down, and the light failing me, I was able to get the old rotor back on and the whole brake assembly back together and head inside in defeat.
    eljay seems to have pulled through with this bolt extracting wrench from CT. Apparently if I can get the top carrier bolt out I can pivot the carrier just enough to get the new rotor in (ideal since there is almost NO room to access the lower bolt due to the close proximity of the shock).
    Nov 15 2011
    Montreal | I sell in USD
    If not seized, these work perfectly for the lower bolt:
    I replaced the ones on my B7 to regular 15mm bolts. On the B6 I put back new oem dipped in anti-seize.
    *****I sell in USD*****
    Apr 15 2014
    Ottawa/Gatineau Canada
    Larry
    How? I would like to do the same.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Aug 13 2015
    NS
    Just like you, I was able to slide out the rotors without removing the carrier.
    Give that wrench a try. It fits in the space without undoing the shock bolt. Press it onto the bolt with a c-clamp and give it a whack.
    Jun 26 2015
    Tampa, FL
    Just undo the shock. It's not that much work.
    Jan 05 2017
    Ontario
    Quote Originally Posted by rocket1420 View Post
    Shock bolt is quite rusty. Like REALLY looking rusty. If I need these wrenches to get the bolts out anyways then I'll do that. And apparently you don't need to take the lower one off, the carrier will pivot enough to slide in the new rotor (you only need a few mm). So I figured why screw around with the shock bolt AND the lower carrier if I don't need to.
    Jan 05 2017
    Ontario
    Quote Originally Posted by Luxus Panzer View Post
    If you go to the Canadian tire website you have to login/make an account and three days before any product you put in your watch list goes on sale you will get an email. I've used it for oil in the past since I use mobile one and I can save like $25 on a big jug if I wait for a sale.
    Jan 05 2017
    Ontario
    Quote Originally Posted by Axis View Post
    I'm not sure if I'd be able to get in there with something that long. Are they meant to be cut to size? Seems like alot of torque on a long wrench. Recipe for snapping unless I'm missing something. I've ordered new bolts from the VW dealer in my town for like $2 each so I'll just replace them. Thanks for the tip!
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    When I attempted to remove the carriers to upgrade the rears I ended up cutting them off with a cut off tool (die grinder) and got replacement bolts. Brutal.
    Jan 05 2017
    Ontario
    Quote Originally Posted by Gin+ View Post
    I am trying quite hard to avoid this hahah
    Jun 26 2015
    Tampa, FL
    I forgot about rust down here in Florida.
    Nov 15 2011
    The idea is to use something long and insert with an angle from under, hence why they're ball end hex bits. Works well but not on the salt belt seized bolts.
    I use this method now but I originaly had to cut the bolts (carrier too since I was upgrading the B7 A4) in order to remove them, I put back new ones filled with anti-seize. (I'm in the salt belt)
    As mentionned earlier, I found matching bolts with 15mm heads for my B7. Never have issues removing them.
    Apr 15 2014
    Merci mon ami
    Apr 29 2017
    Ontario
    You do not need to remove the lower carrier bolt, just the upper then lightly tap the top of the carrier with a 2-3 lb hammer slightly and the rotors will move in and out.
    I would not use the ball end sockets on this type of bolt as if it strips your in trouble.
    I used a Mac tools 8mm stubby 1/2 socket and it works
    blow the bolt head out with compressed air if you have it if not use a pick.
    get a MAP gas torch and heat the area around the bolt up fairly well, make sure to protect the boot of the axle and the abs sensor.
    then hammer your 8mm in a bit and crack it free pray before lol
    If you want to use my 8mm socket i have for it or want help even with it, im only in orangeville not a far trip from guelph.
    i don't mind spending a few hours helping you do it and gain a b6 contact.
    good luck
    -Mike
    Senior Member Two Rings alimo20's Avatar
    Jan 25 2011
    Philly
    When I did this I used the Irwin bolt extractors. They worked like a charm on the first go. Replaced the bolt naturally. As said, only removed one and moved the carrier out of the way slightly. Highly recommend these extractors:
    https://smile.amazon.com/gp/aw/d/B0000CCXVZ
    Jan 05 2017
    Ontario
    Quote Originally Posted by IndoB6 View Post
    good luck
    -Mike
    Hi Mike thanks for the offer! When I get the chance I may end up heading to brantford to do the brake job since my buddy has impact tools, these extractor wrenches, and a garage :). Thanks for the advice, I'm hoping if I take the dust shield, hose the bolts with PB blaster on both sides and bang them with a mallet for a bit to loosen them up . Ill give you a shout if I want to take a little drive up to Orangeville.
    Larry
    Senior Member Three Rings IndoReef's Avatar
    May 20 2015
    2018 VW GTI Autobahn
    Ontario/Canada
    Larry
    No Problem!
    make a trip to canadian tire and get a bottle of MAP gas and a torch head for it, you can get them for like $20-$30 bucks
    heat the caliper carrier and the Hub/Knuckle while protecting the boots. HEAT is your best friend in this situation and in most.
    And this is my actually account it was just recovered, if your a bit confused lol
    Good luck!
    -Mike
    Winter: 02 B6 1.8T quattro 01A Brilliant Black, Gutted Stock Cat, 2.5" stainless custom exhaust to 4 inch tips,DSMIC's
    USP Front lower Valance, REVO Stage 1, Solo Werks S1 Coilovers,B6 S4 Front Brakes, Forge Hybrid Diverter Valve, SAI & AC Delete
    Summer:2018 MK7.5 GTI AutoBahn
    Jan 05 2017
    Ontario
    Quote Originally Posted by eljay View Post
    Hey eljay, just wanted to say thanks for the tip regarding those ratcheting wrench bolt extractors. Pressed them on there with a c-clamp and a few whacks with the mallet later and they popped loose. I was also able to pivot them out of the way with a few taps as well. Replaced the upper bolts with new ones so I'm good to go! Thanks again!
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    i replaced my pads and rotors and forgot to release the auto tensioner for the hand brake. my driver's side rear pads literally smoked up a storm while driving. make sure you release that as well.
