Results 1 to 18 of 18
    Deactivated Three Rings
    Oct 07 2008
    Santo Domingo, Dom. Rep.
    B7 BI XENON HEADLIGHT Question
    If I have non AFS Bi xenon headlights, can I replace the headlight for a Bi xenon with AFS and vice versa? Can I do the same with auto leveling and non auuto leveling lights? B7 headlights have so many different part numbers, just wanna be sure. Thanks.
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    I think the ballasts will allow the projectors to move. Besides that your car must also have the sensors and wiring installed to allow any of this to begin with.
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    Senior Member Two Rings OliNix's Avatar
    Oct 22 2014
    London, UK
    The ballasts have nothing to do with it.
    If you have xenons already they should be plug and play and just need coding from VAGCOM. I'm pretty sure the steering position sensor is default on all cars. Will have to check which control unit you need to make them steer...
    You could fit non auto levelling lights they will fit fine, they will not be xenon though and the plugs will be different so will need some wiring adaptation. (Look for posts of people doing xenon conversion and do the reverse!)
    I'm worried when you say headlight.... if changing the spec you would need to change both, otherwise you need to keep the same spec as your other side.
    Oct 07 2008
    Quote Originally Posted by OliNix View Post
    Thanks, but in this case, my question is for all bi xenon. Im guessing if the headlights are bi xenon, the plugs will be the same, right?
    Sent from my EVA-L09 using Audizine mobile app
    Oct 22 2014
    London, UK
    I would assume so, I have AFS and my headlights are out so I will take a picture of the plug when I am next near them
    Oct 07 2008
    Great, thanks
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    Hmmm I wouldn't assume it simply because there needs to be extra wires to control the extra functions
    Although the plugs may be the same the wiring could be different
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Nov 15 2011
    Montreal | I sell in USD
    If you put afs headlights on a non afs car you will have a dipped healight mil.
    *****I sell in USD*****
    Veteran Member Four Rings ballinb5's Avatar
    Jan 16 2011
    CA
    Quote Originally Posted by Axis View Post
    So I just got AFS bi-xenons for my halogen car. Got the kufatec harness, will I be good after I vagcom it properly? I don't care about the adjustability, just don't want the MIL.
    2021 SQ5
    2008 A4 Avant 6 speed
    Nov 15 2011
    Quote Originally Posted by ballinb5 View Post
    Coming from halogen you can put what you want while using and harness adapter. That comment was for the op.
    Jun 17 2013
    jersey city nj
    Yes...After you the lites. You must vcds to the Bi-Xenon codes. Or else they will flicker and the high beams will not . Also the DRL will lite up when you try to use the high beams. I sold a extra set of Bi-Xenon's to another member on here and the shop that ed them didnt code them. This was the results he got
    Active Member Three Rings lowestA4's Avatar
    May 08 2005
    hanover germany
    If you have factory bixenons then AFS and non-AFS are not exchangable (HID will work though but Auto levelling will through Errors).
    If you upgrade from halogen to bixenon via adapter harness it makes no difference if using AFS or non-AFS.
    lowestA4 -- Germany based parts collection & experienced overseas shipping since 2004. German engineering meets passion.
    Jul 25 2016
    new hampshire
    Okay so who knows how to retrofit the AFS then? Lol
    Every corner I go around I wish I had it :(
    Eric
    May 08 2005
    hanover germany
    Kufatec has an AFS retrofit kit.
    Jul 25 2016
    new hampshire
    Quote Originally Posted by lowestA4 View Post
    I meant the whole shebang lol. All the sensors and everything
    Oh and for a halogen to AFS
    Every corner I make I dream of what it would look like if I could actually see where I were turning >_> <_<
    Eric
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by pezgoon View Post
    I have the AFS option. Not to rub it in your face... BUTS ITS AWESOME............
    Jul 25 2016
    new hampshire
    Quote Originally Posted by vce1232000 View Post
    Lol you bastard
    Eric
    Nov 15 2011
    I have a friend in Europe that did the afs retrofit a couple times. By law you have to retrofit the headlight washers and afs feature when retrofiting Bixenons there so its a more common retrofit than on this side of the Atlantic.
    If I'm not mistaking, all you need is the conversion harness, the height leveling module, F&R sensors and he also needed the steering module but I think thats only for European cars since some dont have mfsw controls and probably have the same steering module our B6's have..
    I might tackle that retrofit once I'm out of things to do on the B6.
