Results 1 to 20 of 20
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    Question Thoroughly Confused - No start/electrical issue? Magically Fixed?
    TL;DR - Drove car 300 miles. Started twice next morning but third time would not start, just kept cranking. No fuel pump prime, front fans on FULL, and intermittent ECU communication with VCDS. Car sat a month, got trailered home, recharged battery, and started after a few tries and has started and run just fine ever since. Nothing seems wrong but confidence is shot that I won't get stranded 100s miles from home because I did not do ANYTHING other than charge battery and pull/clear codes a few times.
    _______________________________
    Ok, this will be a little long but please bear with me. Problem first started as outlined in this thread. For the last month the car had been sitting in my sister's heated garage. Last weekend, I went with a friend and picked up the car and trailered it home. Couple things to note at time of pickup: Battery was dead, as in it wouldn't unlock or roll windows or anything. When I got it home, I hooked up my battery charger and it wouldn't even charge (I think because the voltage was so low). I jumper cabled it with my other S4 and let it charge that way about 10min, after which my regular battery charger picked it up and began charging. I let it sit that way for 6-8 hours, I think it got to 85% or so. It was outside so I disconnected the charger for the night. The next day I hooked it back up for a few more hours. Then this is what I did.
    1. I pulled all codes with VCDS autoscan. Results from that first pull are below. There is a LOT here I think associated with the totally dead battery. One improtant thing maybe to highlight is VCDS had no issues picking up the engine Address 01 and read it just fine.
    Code:
    Thursday,13,April,2017,16:07:21:29527
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 17.1.3.0 (x64)
    Data version: 20170320 DS267.7
    www.Ross-Tech.com
    VIN: WAUXL68E35A088128   License Plate: REDAVNT
    Mileage: 224560km-139535mi   Repair Order: 04132017scan1
    Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
              67 69 75 76 77
    VIN: WAUXL68E35A088128   Mileage: 224560km-139535miles
    Address 01: Engine        Labels: 079-910-560-BBK.lbl
       Part No SW: 8E0 910 560 H    HW: 8E0 907 560
       Component: 4.7L 93/\P      G   0010
       Revision: 00000000    Serial number: AUZ6Z0D0278584
       Coding: 0007771
       Shop #: WSC 08167 444 83472
       VCID: 2A5B0DFC868C7E1197-5140
    2 Faults Found:
    18308 - Coolant Fan Control 2
                P1900 - 004 - Open or Short to Ground - Intermittent
    18080 - Coolant Fan Control 1
                P1672 - 004 - Open or Short to Ground - Intermittent
    Readiness: 0110 1101
    Address 02: Auto Trans        Labels: 09L-927-760.lbl
       Part No SW: 8E0 910 156 R    HW: 09L 927 156
       Component: AG6 09L 4.2L5V USA  0060
       Revision: --H01---    Serial number:        0051534
       Coding: 0000002
       Shop #: WSC 06325 000 00000
       VCID: 35612E805F3221E90A-5140
    2 Faults Found:
    16946 - System Voltage
                P0562 - 000 - Too Low - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 0
                        Fault Frequency: 2
                        Reset counter: 40
                        Mileage: 224072 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 960 /min
                        RPM: 928 /min
                        RPM: 0 /min
                        (no units): 0.0
                        (no units): 22.0
                        Temperature: 25.0°C
                        T.B. Angle: 0.0°
    18170 - Shift Lock Solenoid (N110)
                P1762 - 000 - Short to Plus - Intermittent
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 2
                        Reset counter: 40
                        Mileage: 224072 km
                        Time Indication: 0
    Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
       Part No: 8E0 614 517 Q
       Component: ABS/ESP allrad      4533
       Coding: 04597
       Shop #: WSC 06435
       VCID: 3663298C12342AF103-5104
    3 Faults Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
                35-00 -  -
    18258 - Powertrain Data Bus
                P1850 - 35-10 - Missing Message from ECU - Intermittent
    01435 - Brake Pressure Sensor 1 (G201)
                35-10 -  -  - Intermittent
    Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
       Part No: 8E0 820 043 AD
       Component:   A4 Klimaautomat   1424
       Coding: 00000
       Shop #: WSC 06325
       VCID: 63C5A0D8F126EF5994-515C
    4 Faults Found:
    01172 - Temperature Sensor; Driver's Heated Seat (G59)
                29-10 - Short to Ground - Intermittent
    00819 - High Pressure Sensor (G65)
                30-10 - Open or Short to Plus - Intermittent
                07-10 - Signal too Low - Intermittent
    01206 - Signal for Duration of Ignition Off Time
                27-00 - Implausible Signal
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  USA 0517
       Coding: 01013
       Shop #: WSC 06325
       VCID: 35612E800F3221E90A-4B34
    4 Faults Found:
    01326 - Control Module for Multi-Function Steering Wheel (J453)
                49-10 - No Communications - Intermittent
    01331 - Door Control Module; Driver Side (J386)
    01317 - Control Module in Instrument Cluster (J285)
                79-10 - Please Check Fault Codes - Intermittent
    00532 - Supply Voltage B+
                53-10 - Supply Voltage Too Low - Intermittent
    Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
       Part No: 8E0 035 593 A
       Component: SDAR XM            0010
       VCID: 275DF4C8C59E437988-5074
    2 Faults Found:
    00003 - Control Module
                37-10 - Faulty - Intermittent
    02635 - Tuner Not Enabled/Activated
                35-00 -  -
    Address 15: Airbags        Labels: 8E0-959-655-84.lbl
       Part No: 8E0 959 655 K
       Component: Airbag 8.4EP        1001
       Coding: 0010607
       VCID: 3F8D4CA86D0EEBB9D0-5140
    3 Faults Found:
    01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
                011 - Open Circuit - Intermittent
    01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
                002 - Lower Limit Exceeded - Intermittent
    Address 16: Steering wheel        Labels: 8E0-953-549.lbl
       Part No: 8E0 953 549 N
       Component: Lenksáulenmodul     0611
       Coding: 02042
       Shop #: WSC 06325
       VCID: 3E7331AC3A04E2B1DB-4B1A
    1 Fault Found:
    Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
       Part No: 8E0 920 981 GX
       Component: KOMBI+WEGFAHRS. RB4 D42
       Coding: 01201
       Shop #: WSC 09211
       VCID: 09199270334A1509BE-5140
       WAUXL68E35A088128     AUZ6Z0D0278584
    7 Faults Found:
    00779 - Outside Air Temp Sensor (G17)
    00562 - Sensor for Oil Level/Temperature (G266)
    01128 - Immobilizer Pickup Coil (D2)
    01176 - Key
    00668 - Supply Voltage Terminal 30
    01314 - Engine Control Module
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760
       Component: Sitzmemory R2 F     0305
       Coding: 00002
       Shop #: WSC 06325
       VCID: 71E9DA903BDA4DC916-4B02
    2 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
                79-00 - Please Check Fault Codes
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.clb
       Part No: 8E0 959 433 BB
       Component: Komfortgerát T7B    1612
       Coding: 12044
       Shop #: WSC 06325
       VCID: 72EBD59C3EDC76D1EF-4B1A
       Subsystem 1 - Part No: 8E1959801
       Component: Tőrsteuer.FS BRM 0205
       Subsystem 2 - Part No: 8E1959802E
       Component: Tőrsteuer.BF BRM 0205
       Subsystem 3 - Part No: 8E0959801A
       Component: Tőrsteuer.HL BRM 0205
       Subsystem 4 - Part No: 8E0959802A
       Component: Tőrsteuer.HR BRM 0205
    17 Faults Found:
    01701 - Dimmer for Interior Lighting
                28-00 - Short to Plus
    01565 - Luggage Compartment Light (W3)
                28-10 - Short to Plus - Intermittent
    00962 - Alarm via. Tilt Sensor
                35-00 -  -
    01369 - Alarm triggered by Hood Switch
                35-00 -  -
    01374 - Alarm triggered by Terminal 15
                35-00 -  -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
                35-00 -  -
    00956 - Key 2
    00957 - Key 3
                35-00 -  -
    01702 - Footwell Lighting; Left (W9)
    01703 - Footwell Lighting; Right (W10)
    01696 - Footwell Lighting; Rear Left (W45)
    01560 - Passenger Door
                59-10 - Can't Unlock - Intermittent
    01332 - Door Control Module; Passenger Side (J387)
    01333 - Door Control Module; Rear Left (J388)
    01334 - Door Control Module; Rear Right (J389)
    Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
       Part No: 4Z7 907 357
       Component: dynamische LWR       D09
       Coding: 00060
       Shop #: WSC 06325
       VCID: 0407834414684861CD-4B1A
    1 Fault Found:
    Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
       Part No: 8E0 035 195 H
       Component: symphony II PM6    0410
       Coding: 01205
       Shop #: WSC 71936
       VCID: 2C570BE4DC78602165-5090
    2 Faults Found:
    01305 - Databus for Infotainment
    End-------------------------(Elapsed Time: 06:09)--------------------------
    2. After this, I still had not tried starting it again. I cleared ALL the codes then re-ran autoscan and got the following:
    Code:
    Thursday,13,April,2017,16:14:59:29527
    www.Ross-Tech.com
    After clearing DTCs, Battery Charger on *12.2 volts* before attempting start
    VIN: WAUXL68E35A088128   License Plate: REDANVT
    Mileage: 224560km-139535mi   Repair Order: 04132017scan2
              67 69 75 76 77
       Coding: 0007771
    No fault code found.
       Coding: 0000002
       Coding: 04597
       Shop #: WSC 06435
       VCID: 3663298C12342AF103-5122
    1 Fault Found:
                35-00 -  -
       Coding: 00000
       Shop #: WSC 06325
       Coding: 01013
       Shop #: WSC 06325
       VCID: 35612E800F3221E90A-4B1A
       Coding: 0010607
       VCID: 3F8D4CA86D0EEBB9D0-515C
       Coding: 02042
       Shop #: WSC 06325
       Coding: 01201
       Shop #: WSC 09211
       VCID: 09199270334A1509BE-515C
       Coding: 00002
       Shop #: WSC 06325
       VCID: 71E9DA903BDA4DC916-4B1A
    1 Fault Found:
       Coding: 12044
       Shop #: WSC 06325
    No Faults Found
      or DTCs not supported by controller
      or a communication error occurred
       Coding: 00060
       Shop #: WSC 06325
       Coding: 01205
       Shop #: WSC 71936
    End-------------------------(Elapsed Time: 06:17)--------------------------
    3. Following that, I again cleared that single DTC. At this point, I tried to start the car again. It cranked, and fired for maybe 1/4 to 1/2 a second. I tried again, and same thing, had a very brief moment where it "started" but then died. I then ran another scan:
    Code:
    Thursday,13,April,2017,16:23:11:29527
    www.Ross-Tech.com
    Third Scan. DTCs were cleared. Tried to start. Turned over, fired twice for maybe 1/4 second.
    Would not start. Turned key to off, then back to On and ran autoscan.
    Mileage: 224560km-139535mi   Repair Order: 04132017scan3
              67 69 75 76 77
       Coding: 0007771
       VCID: 2A5B0DFC868C7E1197-515C
       Coding: 0000002
       VCID: 35612E805F3221E90A-515C
       Coding: 04597
       Shop #: WSC 06435
    3 Faults Found:
                35-00 -  -
       Coding: 00000
       Shop #: WSC 06325
    1 Fault Found:
       Coding: 01013
       Shop #: WSC 06325
       VCID: 275DF4C8C59E437988-5090
    1 Fault Found:
                35-00 -  -
       Coding: 0010607
       Coding: 02042
       Shop #: WSC 06325
       VCID: 3E7331AC3A04E2B1DB-4B02
       Coding: 01201
       Shop #: WSC 09211
       Coding: 00002
       Shop #: WSC 06325
       Coding: 12044
       Shop #: WSC 06325
    2 Faults Found:
    00957 - Key 3
                35-00 -  -
       Coding: 00060
       Shop #: WSC 06325
       VCID: 0407834414684861CD-4B34
       Coding: 01205
       Shop #: WSC 71936
    End-------------------------(Elapsed Time: 05:55)--------------------------
    4. Cleared DTCs a third time, tried to crank it again, it caught I hit the gas a bit and then the damn thing just started up. Idle fluttered briefly but it evened out and stayed running. I let it run a couple minutes then pulled these codes while it was running.
    Code:
    Thursday,13,April,2017,16:35:37:29527
    www.Ross-Tech.com
    Cleared code. Steer sensor came back immediately. Car running entire time.
    ABS light came back on, see new code for brake sensor as well.
    Mileage:    Repair Order: ABS1
    Control Module Part Number: 8E0 614 517 Q
      Component and/or Version: ABS/ESP allrad      4533
               Software Coding: 04597
                Work Shop Code: WSC 06435
    2 Faults Found:
                35-00 -  -
                35-00 -  -
    After that, I cleared the codes, shut the car off, and turned it on again probably 3 or 4 times in a row. I drove it to the gym that evening, then the grocery store the next day. No issues at all. So, basically, I didn't so anything to it and it seems magically fixed?? Which is a bit unsettling and not exactly confidence inspiring. The only thing I really messed with was the battery. But I've had it die in my other S4 without nearly the same issues. And that very first time it wouldn't start a month ago, I cranked that thing for at least 2-3 minutes total while troubleshooting and it was cranking strong nearly that whole time/
    What gives? Loose ground? Flaky ECU? Magic pixies? Wonky battery? I want to use this vehicle but without knowing why it stranded me 300 miles from home it's hard to trust it won't do it again without finding out WHY. Thanks for reading, hopefully someone has some idea...
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Mar 31 2014
    KY
    Update
    Per request of JHM, I pulled the ECU. Here are some pics of the ECU board before and after opening. Can anyone tell if this is in fact a chipped a ECU? My emails with JHM seem to indicate they think it is flashed not chipped, maybe they are confused? Quote: "The file is not a “chip” This is a flash tune." I don't know what to think. Anyone know what the stock vs modified ECU would look like?
    Side note, battery is less than 2yrs old as well.
    Top of ECU Housing
    Bottom of Housing
    Looks like it was opened before? All I did before this photo was take the screw out.
    Top of Board
    Underside of Board
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    The fact that they wrote on the housing makes me think they had it to chip it. Hard to write on it with a flash tune. Unless it was converted from a chip to a flash like mine was.
    Old Geezer, formerly known as Stud Muffin
    Mar 31 2014
    KY
    Yeah, the email they sent back to me was surprising. I replied with a couple questions last night but haven't heard back yet, so maybe he was looking at something else? Or typed his response backwards or something, IDK. Gonna wait for him to reply and confirm I guess...
    When they convert to flashed tune do they remove the chip or leave it?
    Senior Member Two Rings M0ve0ver's Avatar
    Jul 18 2010
    Ft. Hood, Texas
    So I ran into an issue back in September 2012, the day after I installed my JHM tuned ECU. I drove the car that night and the morning after it would crank over but not start.
    I sent the ECU back to JHM for them to check and it had a clean bill of health.
    Turns out the power relay had blown (between battery and ECU). Replaced that and the battery and it fixed the issue.
    05 B6 S4: JHM 93 Tune, Trex DP, JHM 2.5" CB, JHM LWCP, Apikol snub, Bilstein PSS9, 034 Adj Control Arms, 034 Rear Sway + Endlinks, 034 front Endlinks, Team Dynamics Pro Race 1.2's, 034 wheel studs, 034 Strut Bushings, 034 Lower Control Arms, tyrolsport caliper bushings, ECS braided brake lines, Hawk HPS pads, Evo skid plate
    13 8P A3 TDI: Malone Stage 3 Tune, CR170 turbo, Rawtek DP, Malone DSG tune, Darkside Race Pipe/EGR delete, CP3 fuel pump, Panzer skid plate
    Jun 18 2010
    East of Cincinnati
    Quote Originally Posted by badger. View Post
    Y
    They remove it. It would serve no purpose, other than be a possible problem.
    Mar 31 2014
    KY
    Quote Originally Posted by M0ve0ver View Post
    Did the car ever start between the first failure and before you sent it in? That's what is confusing me; it worked, then it didn't; then it worked again.
    Veteran Member Three Rings Velox's Avatar
    Mar 30 2016
    S4
    Oranjestd
    faulty relays can still work intermittently right?
    Jul 18 2010
    Ft. Hood, Texas
    I was stuck in the underground parking garage at the Whole Foods in Austin, TX. I tried over the course of about 2 hours to get it to start but no luck. That's when I had it towed to the shop.
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Sticky relays might work intermittenly yes. So id start with that then check if youre getting fuel and go from there.
    Or problem is with the ecu itself. Why would they open it if it was flashed? Seems odd. If it was chipped before and then flashed i wouldnt want to have that ecu in my car.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Mar 31 2014
    KY
    Update...
    Been driving the car without issue for a few weeks now. Haven't changed anything. I need to take the ECU again at some point and redo the seal between the two halves, but other than that don't plan on changing anything.
    JHM responded about the ECU chip vs flash, so that seems to be clarified:
    "That ECU has been opened in the past and the chip removed and the ECU converted to flash technology. That being said, the only way the ECU would be an issue at this point is if the ECU itself was failing. This is possible but unlikely. I'm not sure where to go on this from here to help you without the car being here."
    My 100% spitballing/conjecture theory at this point is that there is a flaky relay that has low tolerance for voltage differences, coupled with the cold weather and few consecutive quick starts that morning which killed battery voltage enough to piss off the relay. But I don't know haha
    Going to drive it to/from work and around town a few more months and see if anything happens. Not sure what to chase at this point. Ż\_(ツ)_/Ż
    Jul 18 2010
    Ft. Hood, Texas
    that makes sense...
    My battery was on its way out at that time too, so my issue was likely a combination between the weaker battery and degraded relay.
    thanks for the update
    Mar 31 2014
    KY
    JUST KIDDING
    Wife went to start the car this afternoon, same problem.
    Get home, hooked up VCDS. Lots of short to ground/intermittent crap, lots for door locks, automatic seat stuff.. some stuff for no or intermittent communication with engine.. (I'll post up the log once I pull it off my laptop). Battery down to ~8v and 10% (only tried cranking it 5-6 different times, 3-5 seconds ea). Can a short somewhere KILL the battery that fast without fireworks?? Currently have the charger on..
    Where/what the hell is "Supply Voltage Terminal 30 35-00 - " ?
    Mar 31 2014
    KY
    VCDS Auto-Scan
    Code:
    Monday,08,May,2017,13:01:26:29527
    www.Ross-Tech.com
    Mileage: 225040km-139833mi   Repair Order:
              67 69 75 76 77
    VIN: WAUXL68E35A088128   Mileage: 225040km-139833miles
       Coding: 0007771
    1 Fault Found:
    18010 - Power Supply Terminal 30
                P1602 - 002 - Voltage too Low - Intermittent
    Readiness: 0000 0001
       Coding: 0000002
    1 Fault Found:
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 40
                        Mileage: 225046 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 928 /min
                        RPM: 896 /min
                        RPM: 0 /min
                        (no units): 0.0
                        (no units): 23.0
                        Temperature: 34.0°C
                        T.B. Angle: 0.0°
       Coding: 04597
       Shop #: WSC 06435
    1 Fault Found:
                P1850 - 35-00 - Missing Message from ECU
       Coding: 00000
       Shop #: WSC 06325
       VCID: 63C5A0D8F126EF5994-5140
    1 Fault Found:
       Coding: 01013
       Shop #: WSC 06325
       VCID: 275DF4C8C59E437988-50AE
    1 Fault Found:
                35-00 -  -
       Coding: 0010607
       Coding: 02042
       Shop #: WSC 06325
       Coding: 01201
       Shop #: WSC 09211
    1 Fault Found:
       Coding: 00002
       Shop #: WSC 06325
    1 Fault Found:
                06-10 - Signal too High - Intermittent
       Coding: 12044
       Shop #: WSC 06325
    9 Faults Found:
    00956 - Key 2
    00957 - Key 3
                59-00 - Can't Unlock
    01562 - Rear right door
       Coding: 00060
       Shop #: WSC 06325
       Coding: 01205
       Shop #: WSC 71936
    End-------------------------(Elapsed Time: 05:54)--------------------------
    Mar 31 2014
    KY
    Oh and my sedan just threw a belt (thanks JHM autotensioner) and there is oil flung everywhere so I am sure that is good..because fk me, right? When it rains it pours.
    Mar 31 2014
    KY
    Just to update this and tie up some loose ends....
    First, I had started a few more threads while troubleshooting that might help others. Linking them here to bring it all together.
    Relay Diagram Questions
    Fuel Pump/Relay & Bypass Questions
    Engine Speed Signal (G28) Questions
    Anyway, in terms of current situation. Basically JHM made a mistake the first few times when they told me the ECU board did not have the encryption chip. After some help from others not on this forum, JHM finally got on the same page and confirmed it was indeed chipped. They have agreed to remove the chip and convert the ECU back to flash technology (for a fee, of course ). I boxed up and sent out my ECU yesterday, so hopefully I should have it back sometime next week and (fingers crossed) have a reliable avant again.
    I won't be convinced this will be the fix until it's back and running for a few months, but it seems like it should do the trick. I'll try to update here once the ECU is reinstalled.
    Mar 31 2014
    KY
    ECU was returned. Fired up the first try, then now it won't start again.
    PRNDS and EPC are lit up now. Clearing a P1866 (auto trans code) lets the PRNDS highlighting disappear, until I try starting again then it returns.
    So apparently the ECU fix didn't actually do anything. Unless it is good and something got out of whack with the immobilizer (but no codes in immo address, and car won't start - i though immo would let it start at least 2-3 seconds?)
    So frustrated Car still stuck in driveway
    Veteran Member Four Rings MugelloB7RS4's Avatar
    Feb 06 2015
    You might be confused a bit with terminology and thus making it tougher to communicate with JHM. Back in the day, like 20ish years ago, they would physically need to open the ECM, replace the ROM or EPROM with a performance "chip" Now, unless anyone knows otherwise, it's all done by flashing. New software is uploaded to the ECM and it's done. There's no need to change a chip as the new ECM's have re-writable components. Some people still use the term "chip" even though that's not physically done anymore. I have seen some ECU's that can be flashed via the OBD port in the car, but there are also ECM's that need to be physically opened to be flashed. The pictures of your ECM seem to appear that yours was flashed at some point by JHM.
    Doesn't help with your starting issue though
    Jul 18 2010
    Ft. Hood, Texas
    did you check the power relay from the battery?
    Mar 31 2014
    KY
    Which relay specifically is this? I've checked a bunch, I may have checked this one.
    Anyway,
    The PRNDS being all illuminated seems to have gone away. I let it sit a few hours with the battery completely disconnected from the car and a charger on it (was down just under 12v from all the attempts//fans this morning). I tried cranking 5 or 6 more times this evening, key on & key off in between. Still no start, but the PRNDS issue seems resolved..
    Battery light still on when key is on and cranking though, even though it seems nearly fully charged (15+ V). I'm beginning to lean towards a flaky alternator maybe? Sending bad voltage or spikes through the system? I dunno.
    Now its just Check Engine, Battery, and EPC lights on the dash.
    See video of start attempts (its hard to hear over that infernal door dinging, but cranking starts at 0:26 and 0:39). Battery charger was showing 15.7V and 95% prior to attempts.
