Results 1 to 11 of 11
    Apr 01 2017
    Aberdeen, Scotland
    Dash Cam (Battery Pack)
    Hello Gents, I hope we are all doing well!
    So, managed to hard wire my blackvue 650S 2-CH in line with the power magic pro. But, I do not get anywhere near enough recording time after the ignition is off as the 12V cut off protection hits in pretty fast. So, on the Facebook RS6 page, one guy mentioned the battery power pro (battery pack). Looks great, as does the price!
    However, my question is, do any of you have this and did you manage to hard wire it? I could figure it out myself after probably some considerable time but would appreciate some time saving saviour to be able to help me out!! I don't want the 12V socket connection and therefor cables running about the cockpit.
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    Do you have a link to the battery pack? Is it the black magic power pro ?
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    Quote Originally Posted by B-ry View Post
    Sounds like your battery is not fully recharging if it's dropping to 12 volts in a short time. You can add another battery for the dash cam and isolate it with a diode so the auxiliary battery is powering the camera and not the car. The question is, does the car run long enough to charge both batteries? Maybe the car should be on a charger every so often to top off the car battery.
    My Blackvue PMP is set for 6 hours and I noticed if I'm taking short trip the camera shuts down sooner. I also increased the SD card size to 64GB. The 8GB card only holds 2-3 hours of video before it's over written. I found that out when I tried to review it after the 45K service.
    2012 A7 3.0T Prestige, Ibis white/Nougat/Ash, 20" Sport, ACC, LED, HUD, Ferrada FR2 wheels, AWE Touring exhaust, Adam's Drag II rotors, BlackVue dash cams
    As I've grown older, I've learned that pleasing everyone is impossible,
    but pissing everyone off is a piece of cake
    Apr 01 2017
    Aberdeen, Scotland
    Yeah, it's the magic power pro.
    Apr 01 2017
    Aberdeen, Scotland
    Quote Originally Posted by tenspeed View Post
    I'm not driving very far at the moment, you're right. If I get the magic power pro then I guess I will struggle to charge it fully most times. I have a 64GB card as know from previous cameras how much pace is required. Some good points to note, thanks.
    Aug 29 2013
    Mt Pleasant, SC
    My car is 4 years old, with a a nearly 2000 watt stereo system and blackvue 650 with power magic pro. I'm still on my original car battery. My camera will easily run for a couple of days without draining to battery. I think something is wrong with your battery.
    1 thing.... I do have a CTek charger which I keep my car plugged to from time to time. I'm sure that helps. But I still think something is wrong with your car for the dash cam to be draining so quickly.
    2013 Audi S6 Ibis White, Black interior, LED headlights, 20" alloy wheels, Carbon Atlas inlays, Audi side assist
    Mods Bel STiR Plus, Blinder HP-905, BlackVue dash cams (front and rear), Black Optics grill, Black window trim, XPel Ultimate film, Modesta BC-03 glass coating
    Dec 20 2006
    CAN
    Why not use a USB power brick like you would for a mobile phone?
    Apr 01 2017
    Aberdeen, Scotland
    Looks like the instructions I got differed to the actual unit I got. I have set up the correct voltage cut off and now works fine!!
    Thanks for all the input guys, appreciated!
    Mar 11 2014
    Dallas/TX
    Quote Originally Posted by CanuckRS View Post
    Been planning to do that. One day I will. Lol. Actually there are a few people who have done that to avoid frequent deep cycling of the car battery. Doesn't seem like a bad idea as long as you keep the brick away from the sun.
    Veteran Member Four Rings ebi718's Avatar
    Oct 29 2011
    2009 A8 L
    Brooklyn, New York
    I replaced my Power Magic Pro with a (much better) Vico-Power PLUS Battery Discharge Prevention device.
    Sent from my P01M using Tapatalk
    '10 A6 3.0T Quattro Avant Prestige Phantom Black Pearl Effect (Link)
    '09 A8L Phantom Black Pearle (Link)
    '13 A7 Quattro 3.0T Phantom Black - SOLD
    '07 A6 3.2 Quattro Avant S Line - SOLD
    Dec 12 2011
    Honeoye NY
    Quote Originally Posted by ebi718 View Post
    What did you gain from the replacement?
    The OP's and my camera powers down at 12 volts. It appears that the Vico-Power PLUS will do the same thing.
