I am looking for some advice to try an fix an intermittent problem I am having with the parking aid on my wife's 4L Q7.
Specs of the car:
'06 4L Q7 V6 TDi
MMI 2G high
Parking system plus (front and rear sensors with graphical display)
Tools available:
Full Vag-com software with genuine Ross-tech cable
Elsa
Tools to physically remove/replace parts
Description of issue/things tried:
- When selecting reverse I get a long beep and the parking aid does not function
- It sometimes works, and when it does it will work for a couple of days
- I can talk to the Park Assist module (J446) through vag-com and can activate/test all functions through Meas. Blocks option.
- I have tested the MOST bus through vag-com and all comes back clear
- I get a communication intermittent fault at the Control head in vag-com
- I have physically unplugged and plugged back in the park assist module (J446), the Control head module and the data bus diagnostic interface (J533)
Thoughts:
It seems the CAN-bus communications are working ok as I can communicate with the parking aid module. I can't pin point any of the three modules themselves as being faulty as they are either talking to vag-com (parking assist module) or doing everything else they should be doing (control head and J533). I do have one faulty parking sensor, but when the system intermittently works I just don't get any feedback from that one sensor; everything else works as it should. The vag-com makes it look like the parking assist module isn't talking to the control head, but the CAN and MOST buses appear to be working fine and J533 appears to be working too. There is a dension gateway plugged into the MOST bus, but I'm I don't think this would be causing this specific issue. I guess I could try unplugging this and see if the problem goes away.
Below is a full vag-com scan.
Any advice/guidance would be greatly appreciated.
Thanks in advance.
PHP Code:
Friday,14,April,2017,16:49:27:35988
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WAUZZZ4L27D027898 License Plate: DMD899
Mileage: 135280km-84059mi Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 36 3C 42 46 47 4F 52
56 61 62 69 6F 72 76
VIN: WAUZZZ4L27D027898 Mileage: 135280km-84059miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4L0 910 401 M HW: 4L0 907 401
Component: 3.0L V6TDI G000AG 0010
Revision: --H03--- Serial number:
Coding: 0011779
Shop #: WSC 00020 824 81311
VCID: 2C5717F88F87A32165-8078
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FK HW: 09D 927 750 FK
Component: AL 750 6A 0940
Revision: 00H52000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 7CF7E7B83F67F3A1B5-8028
Address 03: ABS Brakes Labels: 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H21001
Coding: 0033921
VCID: 285FEBE89B7F8F0181-807C
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0210
Revision: 27120501 Serial number: 10601000455643
Coding: 0000147
VCID: 63C5BCC4A2D92C5994-8036
Subsystem 1 - Part No: 4F0 910 131 A
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 729 S HW: 4E0 035 729
Component: Interfacebox H43 2830
Revision: 00000000 Serial number: 386FT067514614
Coding: 0002002
VCID: 3F8D50B46EF128B9D0-806A
Subsystem 1 - Part No: 4L0 910 609
Component: E0380 BedienteilH02 0060
Subsystem 2 - Serial number: 00000000446807
Subsystem 3 - Serial number: 0119.06.060000000100011435˙
Subsystem 4 - Serial number: 011435˙
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 3
Reset counter: 73
Mileage: 135284 km
Time Indication: 0
Date: 2017.04.14
Time: 15:51:34
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 E
Component: KLIMABETAETIGUNGH05 0040
Revision: 00---008 Serial number: 00000000043368
Coding: 0001110
VCID: 61C9B6CCB8C53E4986-8034
1 Fault Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 135284 km
Time Indication: 0
Date: 2017.04.14
Time: 15:35:34
Freeze Frame:
Temperature: 22.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0010101
VCID: 3169068CA8A5CEC956-8064
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H07 0030
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 111 A HW: 4L0 035 111
Component: CD-Changer H41 0100
Revision: 00000000 Serial number: AUZ5ZBF3025203
Shop #: WSC 00000 000 00000
VCID: 1E33CD30C93B41B1FB-804A
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 B HW: 4L0 959 655
Component: 30 AIRBAG AUDI8RH38 0120
Revision: 05H38000 Serial number: 0037GD069LUJ
Coding: 0013104
Subsystem 1 - Serial number: 6332QSME0F2333719
Subsystem 2 - Serial number: 6342QSME0F53236BL
Subsystem 3 - Serial number: 6352QSME107B291FN
Subsystem 4 - Serial number: 6362QSME10081877A
Subsystem 5 - Serial number: 63734SME0E160F330
Subsystem 6 - Serial number: 63834SME0E16324D2
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026061690234
Coding: 0102042
VCID: 66C3A5D051EB597173-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 900 C HW: 4L0 920 900 B
Component: KOMBIINSTR. M73 H11 0070
Revision: 00100000 Serial number: 4ZN7A6F66
Coding: 2561843
Shop #: WSC 60308 067 57207
VCID: 204FF3C8F34F7741C9-8074
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 B
Component: Heizgeraet H07 0050
Revision: 0000000D Serial number: 00000009011043
Coding: 0000002
VCID: 60CFB3C8B3CF374189-8034
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D066078307
Coding: F7DB9E57340202
VCID: 6CD7D7F84F07632125-8038
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0091138
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 A HW: 4L0 907 566 A
Component: J0769_SWA_MasterH06 0060
Revision: 00H06000 Serial number: 6PZ 009 014-00
Coding: 0001101
Subsystem 1 - Part No: 4L0 910 568 A
Component: J0770_SWA_Slave_H05 0060
Subsystem 2 - Serial number: 6PZ 009 014-20
Subsystem 3 - Serial number: 3F27.06.0600H0500000010014˙
Subsystem 4 - Serial number: 010014˙
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00000000 Serial number: Hir
Coding: 0002779
VCID: 2F6D00F4BE91D83940-807A
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01015007270000
Coding: 4219121
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177 s
Component: Innenraumueberw.H01 0020
1 Fault Found:
01699 - Motor for Central Locking; Hatch/Trunk (V53)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 33
Mileage: 135284 km
Time Indication: 0
Date: 2017.04.14
Time: 16:07:40
Address 47: Sound System Labels: None
Part No SW: 4L0 910 223 C HW: 4L0 035 223 B
Component: DSP-AU716 H40 0100
Revision: 02S00001 Serial number: 03105060286069
Coding: 0000003
Shop #: WSC 00020 824 999999
VCID: 2447FFD8E7576B61AD-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000001011
Coding: 0011101
VCID: 5EB38D3089BB01B1BB-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00000000 Serial number: r
Coding: 0002779
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 M HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 388F+067534298
Coding: 0000001
VCID: 2A5B11E08573BD1197-807E
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000023225
VCID: 64C7BFD8A7D72B616D-8030
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2606171920
Coding: 344630393135313035442056413032363036313731393230
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0002058
Address 69: Trailer Labels: None
Part No SW: 4L0 910 383 HW: 4L0 907 383
Component: ANHAENGERELEKTR 003 0020
Coding: 0000003
VCID: 68DFABE85BFF4F0141-803C
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 HW: 4L0 907 290
Component: ILM HINTEN 2 H05 0040
Revision: AAH05044 Serial number: 001735391-----
Coding: 0000001
VCID: 65C1A2DCACED52697A-8030
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0002058
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
Component: Parkhilfe 8-Kan H12 0060
Revision: 00H12000 Serial number: 06320616504073
Coding: 0211046
1 Fault Found:
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 135284 km
Time Indication: 0
Date: 2017.04.14
Time: 15:30:56
End-------------------------(Elapsed Time: 02:30)--------------------------
