Results 1 to 24 of 24
    Jul 29 2009
    Austin, Tx
    Valve cover gasket?
    Need to do a valve cover gasket change on the driver side. Are there any DIYs on it. I know it should be simple but just don't want to run into any surprises.
    Also trying to order from ECS but not sure which one to order. It says left or right. Is it from looking at the engine or if as you were sitting in the car?
    Apr 05 2016
    Portland, OR
    The left side is the driver's side.
    Looks pretty straight forward, here is the torquing order:
    All bolts go to 9 Nm
    Geoff
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    Same boat, driver's side leak. I ordered both gaskets from RockAuto a while ago for like $7, but needed torque diagram. Thanks Whiped!
    Anyone know if hardware needs to be replaced, as well?
    Apr 05 2016
    Portland, OR
    Code:
    1. Cylinder Head Gasket
    􀁺 Removing and installing, refer to CYLINDER HEADS 􀁺 Installed position: the part number faces the cylinder head 􀁺 Change the coolant and engine oil after replacing
    2. Cylinder Head
    􀁺 Removing and installing, refer to CYLINDER HEADS 􀁺 Check for distortion, refer to Fig. 8 􀁺 Reworking dimension, refer to Fig. 9 􀁺 Change the coolant and engine oil after replacing
    3. Bolt
    􀁺 Tightening specification, refer to Special Tools
    4. Vacuum Pump
    􀁺 Removing and installing, refer to Removal and Installation
    5. O-ring
    􀁺 Replace
    6. Camshaft Position Sensor
    􀁺 Cylinder bank 1 (right) Camshaft Position (CMP) sensor -G40- 􀁺 Cylinder bank 2 (left) Camshaft Position (CMP) sensor 2 -G163-
    7. Bolt
    􀁺 Tightening specification, refer to Specifications
    8. Bolt
    􀁺 Replace 􀁺 Follow the sequence when loosening Fig. 106 􀁺 Tightening specification and sequence, refer to Fig. 7
    9. Ignition Coil
    10. Cylinder Head Cover
    􀁺 Removing and installing: left, refer to LEFT CYLINDER HEAD COVER, right refer to RIGHT CYLINDER HEAD COVER
    11. Gasket
    􀁺 Replace if damaged or leaking
    12. Cover 13. Bolt
    􀁺 Replace if the seal is damaged 􀁺 Tightening specification and sequence: left cylinder head cover, refer to Fig. 5, right cylinder head cover, refer to Fig. 6
    14. Bolt
    15. Connector Strip
    􀁺 For the ignition coils
    16. Cylinder Head Cover Gasket
    17. Camshaft Adjustment Solenoid Valve
    􀁺 Cylinder bank 1 (right) camshaft adjustment valve 1 -N205- 􀁺 Cylinder bank 2 (left) camshaft adjustment valve 2 -N208-
    18. Bolt
    􀁺 5 Nm
    19. O-ring
    􀁺 Replace
    Geoff
    Oct 12 2016
    Chicagoland
    Just had both sides done at my local shop, they charged 1.5 hrs. Would've done this if I had the universals and tools to get into the tight spaces.
    Jan 26 2015
    2017 XC90, a workbench
    CO
    I'm curious. Are you just replacing because of oil leak around the gasket or are you having symptoms of something?
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Jul 29 2009
    Austin, Tx
    Oil leak.
    Thank for the help.
    Dec 23 2012
    New York
    Hi. Have a valve cover leak as well: the pics don't work in this thread anymore. Anybody know the bolt tightening sequence?
    Jul 16 2012
    Mid-Atlantic
    Quote Originally Posted by ninsei View Post
    Download the extension for chrome to make the pictures work.
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Apr 10 2016
    Reading/PA
    Just an FYI, had my valve covers off last week.. I found the lower rear bolt on both sides was only able to be accessed with a T30 Allen style wrench, and even with that I could only get about a quarter turn at a time.... It was a PITA.
    2011 S4 P+
    Unitronic Stage 2+ ECU / Stage 2 TCU | JHM 179 Crank Pulley | Vogtland Coilovers | CR-15 | Eurocode Intake Pipe | Drilled Airbox | ECS X-Pipe | ECS Rotors | VMR 710 19x9.5 ET45 | 265/35 Pilot A/S 3
    IG: b8_s4thewin
    Nov 12 2016
    Finland
    Dec 23 2012
    Ancaster, Ontario
    Hi all,
    I have a quick question. I've done VC gaskets on my previous B5 A4 and B7 S4 and always used sealant in the corners where the gasket transitions for one plane to another and over the half moons etc.
    I'm about to the the gaskets on my 2010 s43.0T this weekend and i've noticed that there are no corners to speak of so do you use sealant or not?
    If you do use it where? the whole surface? Both sides of the gasket?
    I noticed that ECS sells a kit that comes with sealant.
    Any input would be greatly appreciated.
    Thanks!!
    Jon
    Veteran Member Three Rings $nooze's Avatar
    Jan 02 2012
    in for input as requested from previous post.
    noticing oil around the bolts and want to change mine as well
    '11 B8 S4 6mt
    Dec 23 2012
    Ancaster, Ontario
    Quote Originally Posted by $nooze View Post
    I haven't done mine yet due to the weather but the primary leak location for me is also the bolts.
    Each bolt has its own integrated rubber seal so you might as well replace them all...each bolt is about $7 x 24 bolts = :(
    Dec 23 2012
    New York
    About to change out both VC gaskets as well. This thread is helpful. Thanks. So what's the verdict on sealant? Do we use any sealant anywhere?
    Established Member Two Rings JimmyJamesS4's Avatar
    Sep 08 2011
    Grayslake, IL
    Just changed mine, no sealant used, got elrings gaskets off fcp euro, watched BDT's YouTube video Audi S4 valve cover gasket install. Got a performance tool 1/4 inch drive with a scale at the top that reads in NM from O'Reilly. Biggest PIA is the back bottom bolts on each side.
    Sent from my SM-G986U using Audizine mobile app
    04 a6 2.7t
    mods: APR BiPipe, unitronic stg2 chipped, snow performance w/m, Custom CAI, ST Coilover
    May 07 2020
    Toronto, Ontario, Canada
    Quote Originally Posted by JimmyJamesS4 View Post
    How can I tell if they need changing? Cause I know my car has a really slow leak somewhere under the engine or around there but I never see any active dripping
    Sep 08 2011
    Grayslake, IL
    Age, milage
    Sent from my SM-G986U using Audizine Forum mobile app
    04 a6 2.7t
    Mar 05 2016
    I have everything ready to tackle the job, got a torque wrench, a micro flex bit driver and both cover gaskets of the dealer.
    My only question, how do you torque to 9Nm the back bottom bolts on each side? Don’t think I can fit my torque wrench in the reach of back bolts.
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
    Sep 08 2011
    Grayslake, IL
    Quote Originally Posted by TC_S4 View Post
    By feel, you'll get a sense of what 9 nm feels like from the other bolts.
    04 a6 2.7t
    May 07 2020
    Age, milage
    year: 2010 just over 109891kms
    Oct 15 2019
    Santa jose, CA ,Bay Area
    The best way to do it is to get low profile bits. I will have a DIY when I get mine for Black friday
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    The bolts near the strut towers can’t really be torqued even with low profile bits, will have to go by feel anyway.
    P.S. maybe undoing the engine mount bolt and jacking the engine up on the side you are trying to tighten that bolt near the strut tower might give some extra clearance. Worth trying if you really want to have it torqued with torque wrench.
    Jan 17 2020
    Ingleside, IL
    This how to video is key https://www.youtube.com/watch?v=lJGhqYvp4pA
    I'm a nurse not a mechanic ha but tackled this job with the help of the video. Did crack the pcv hose a bit but nothing JB weld couldn't handle. My tip is that T30 swivel socket is essential before taking this on, the back nuts on either side are horrendous to get to. I ordered one out of spite after finishing the job.
