Results 1 to 35 of 35
    Veteran Member Three Rings socialpro's Avatar
    Sep 26 2013
    2023 RS6 || 2022 XC60
    scottsdale, az
    Can somebody explain the Air Suspension auto lowering feature? (RS7)
    Does anybody fully know about the auto lowering in the RS7 ?
    1. What does the car do and when? So lets say you have it set to 'comfort' - does the car lower to 'dynamic' ride height at a certain speed? So only the 'height' is affected - but not the dampers or stiffness correct?
    2. What is that speed when the car 'auto lowers'? I've seen 30mph mentioned , I've seen 70mph and I've seen 75/80mph. Does the car 'auto raise' when the speed drops below 30? So is the car constantly raising and lowering when you drive it in the city?
    3. If you set the car to 'dynamic' - none of this auto lowering goes on correct? The car does not lower even further from dynamic mode?
    4. I've read through some VCDS instructions where you can turn of auto lowering. Have any of you done that? No issues given?
    Any help and insight is appreciated!!
    Dec 20 2006
    CAN
    Quote Originally Posted by socialpro View Post
    afaik auto/dynamic/comfort relate to the dampening/rebound of the suspension system. this translates into how firm the suspension is rather than height.
    yes, the vehicle auto-lowers at 130km/h but that's it in terms of lowering at speed. it doesn't go up and down while you're driving as you mentioned. it will auto-adjust/level if you add/subtract weight from the vehicle as well. you can hear/see this when you park and people get out of the car or you take packages out and it'll lower back down to where it's calibrated.
    you can also raise it if you need to when going over big bumps but you have to dig into the menu system to do this.
    emilyPay.com - Payment Processing for Professionals
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Headliner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Sep 26 2013
    scottsdale, az
    Quote Originally Posted by CanuckRS View Post
    afaik auto/dynamic/comfort relate to the dampening/rebound of the system. this translates into how firm the suspension is rather than height. yes, the vehicle auto-lowers at 130km/h but that's it in terms of lowering at speed. you can also raise it if you need to when going over big bumps but you have to dig into the menu system to do this.
    So there is no change in height between comfort and dynamic in drive select / car menu?
    Dec 20 2006
    CAN
    i don't believe so, but i could be wrong. :)
    i think those settings only relate to dampening/rebound. i've never noticed a difference.
    Sep 26 2013
    scottsdale, az
    OK - I was under the impression the car sits a tad lower in 'dynamic' mode. I might be wrong as well -- gonna see if anyone else can chime in.
    I would also like to know the correct answer to this as this will/might affect my decision to lower and how much based on what mode I drive the car in mostly (dynamic at the current time).
    Dec 20 2006
    CAN
    i'm lowered with vcds and links and i drive in dynamic 100% of the time. even >130km/h no issues although some report problems but maybe they are lowered too much.
    Senior Member Two Rings InvigR8's Avatar
    May 18 2009
    Audi R8 (2017 V10+, 2008 V8), RS 7, B8 A4 Avant, A6 Allroad 4.2, C6 S6 5.2, Ur Quattro
    Los Altos, CA
    In a stock RS7 while stopped, changing between comfort and dynamic absolutely raises and lowers the car (over about 10 seconds)
    Veteran Member Three Rings arrivalanche's Avatar
    Jun 08 2014
    Placentia, CA
    The ride height is a 2 stage deal. You can raise and lower through the MMI and it will also do it automatically around 60-70mph. This is the majority of the ride height adjustment. It also has a secondary height adjustment going from dynamic to comfort. If you leave it in comfort, it wont go any lower than the first setting. Put it in dynamic and it will go a little lower.
    -AARON-
    2018 S4 Black Optic
    2017 S6 Black Optic - Sold
    2016 S6 Black Optic - Sold
    2014 A6 3.0T Black Optic - Sold
    2014 S4 3.0T Black Optic - Sold
    2012 A6 3.0T - Sold
    2008 A4 2.0T - Sold
    Nov 18 2014
    Jersey
    Quote Originally Posted by InvigR8 View Post
    I literally tried this two days ago. nothing happened.
    2018 Jeep GC Trackhawk
    2022 Audi SQ7
    2017 R8 TT. 1370whp.
    2007 Porsche 911 Turbo...Bolt On's
    Nov 13 2016
    Houston, TX
    On my s6 it definitely lowers when putting it in dynamic mode compared to comfort. I can tell a big difference when I park and look at it. The difference is so big I think something is wrong with the suspension when I park in comfort mode. As for the speed I don't know. The car doesn't tell you anything and normally it changes height over such a long period of time that you don't really notice it
    Sent from my SM-G935V using Audizine mobile app
    Senior Member Two Rings Tidefan73's Avatar
    Sep 16 2016
    2014 Beetle R (Wife's), 2005 Nissan Titan LE
    F'Burg, VA
    Quote Originally Posted by mihneagabriel View Post
    Mine does the same. When parked, changing modes, I can feel/see it moving.
    As for at speed, I'll take people's word for it.
    Took delivery 12/05/2016:
    2017 S6 Prestige | Daytona Grey Pearl | Black Optics | Sport Package | Comfort Seats | Carbon Inlay | EPL Stage 1 ECU/TCU | CETE ASC v2 | Signature SV304S 20x9.5 ET35 w/ 275/35/20 | BlackVue DR650S-2CH
    "I love this car!!" -Me
    Insta: Tidefan73_S6
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    Quote Originally Posted by Rez90 View Post
    RS7s can be had with the standard air suspension or DRC - AFAIK, DRC-equipped cars don't raise/lower...
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Feb 25 2014
    Texas
    The air suspension absolutely changes ride height between comfort and dynamic settings. If you don't believe so, put your car in comfort, wait 30 seconds, put in dynamic and jump out of your car quickly and watch it adjust
    Quote Originally Posted by zcd2.7t View Post
    The DRC setup is obviously spring loaded so it does not adjust ride height between settings. However, it does adjust dampening
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Established Member Four Rings limeypride's Avatar
    Mar 18 2017
    Snohomish
    As I understand it, RS7s with Prestige alone have air suspension. RS7s with Performance Prestige have Audi dynamic ride control. While I can't speak to the former since I don't have one, I can to the latter since that's what my car has... so presumably no clever lowering trickery for me... bummer.
    2018 ////AMG E63S in Diamond White/Nut Brown, lowered 20mm front/back, spacers, tints, EuroCharged tune
    Gone but never forgotten
    2017//RS7 Performance in Mythos Black, Audi exclusive Titanium edition w/ Akrapovic exhaust
    May 18 2009
    Los Altos, CA
    It's really easy to see it raise and lower if you just stare at a stationary object right in front of the hood (if you have the air suspension, per the OP's topic). You will see the object raise and lower as it will raise the front and back separately (and vice versa).
    There was a second suspension option available which might be forced on you if you have the RS7 Performance, but I believe it was also an option with the 2014.0 RS7.
    May 18 2009
    Los Altos, CA
    I think the non-air suspension is called the sport suspension with DRC or something like that. That is an upgrade option that gets rid of air but improves handling on the track and maybe also raises the top speed? A quick search shows a lot of this vs that threads.
    That said, I am unaware how it chooses to raise and lower. Interestingly I hear the suspension doing _something_ usually about 20 seconds after turning off the car.
    Sep 26 2013
    scottsdale, az
    Yes - I did confirm the car sits lower in dynamic. I am strictly inquiring about the air suspension - NOT the drc.
    I am still puzzled on 'when' -- on what speed the car actually auto lowers - and if it happens in both dynamic and comfort mode.
    Dec 20 2006
    CAN
    1. how did you confirm the car is lower in dynamic vs comfort?
    2. it auto lowers above 130km/h. you believe it lowers at different speeds as well?
    Feb 25 2014
    Texas
    Mine was very visibly obvious. But I suppose to know for sure you can measure the gap between the top of the tire and the bottom of the wheel well in comfort then dynamic
    10.65 @ 129mph
    Nov 08 2010
    MD
    interesting read, might be helpful to some ... obviously air suspension operation does not apply to your cars with DRC ... i.e steel springs.
    Adaptive air suspension is an electronically controlled air suspension system at all four wheels with a continuously adaptive damping system. It unites sporty handling with a high level of ride comfort. In addition, the air suspension allows for speed-dependent lowering of the body – a change in ride height that results in a low center of gravity and significantly increased directional stability. The vehicle’s aerodynamics are improved at the same time.
    The vehicle has air suspension struts on all four wheels. The data from sensors on the axles and acceleration sensors on the body is evaluated in the adaptive air suspension's central control unit. This computer controls the adjustment of the individual shock absorbers in milliseconds, depending on driving situation. Provided no higher damping forces are required – for instance, when driving straight ahead on good roads – the damper settings remain comfortably soft.
    Controlled changes to the damping force at individual wheels help to eliminate body movements at any time which could reduce occupant comfort. The adaptive damping system automatically reduces rolling or pitching movements when cornering, braking or driving off-road. Adaptive air suspension moreover offers the advantages of a traditional self-leveling suspension system. The vehicle's suspension height remains constant irrespective of the load it is carrying.
    The adaptive air suspension generally also allows the driver to influence the suspension characteristic – and thus the operating dynamics – as individually preferred. The damping characteristics and ride height can be adjusted in a single process via the MMI "CAR" menu system.
    2021 SQ8 Prestige - Daytona Gray Pearl
    2018 Q7 Prestige - Samurai Grey
    Past: '19 Cayenne S | '15 S8 | '17 Q7 | '17 Macan S | '14 S6 4.0T | '14 Q5 3.0T | '13 RS5 Coupe | '13 Q5 3.2 | '11 S5 Coupe | '10 Q5 3.2 | '05 allroad 2.7t | '02 A4 3.0 | '00 A6 4.2 | '99 A6 avant 3.0
    Dec 20 2006
    CAN
    Quote Originally Posted by AudiS4B8 View Post
    That's what i'm thinking. To be convinced, i'd like to see a video of the height difference between the two with someone actually measuring it. Most accurate way is to measure from center of fender lip to the ground
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    not sure why you're so skeptical? i work for audi and am 100% confirming for you that comfort mode in all air suspension applications(not just the c7 platform) sits higher than dynamic
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Sep 26 2013
    scottsdale, az
    You have air suspension - correct? It is a very obvious difference between the two when I looked at it. I will take pictures and/or measurements shortly and post back with the results.
    Feb 25 2014
    Texas
    Why the skepticism? It's a fact. Multiple people in this thread confirming
    Quote Originally Posted by richib86 View Post
    This.
    10.65 @ 129mph
    Nov 13 2016
    Houston, TX
    Exactly. Like I said in my post, Its a large noticeable difference to the point where I normally leave it in Dynamic mode just for that. Even though I am lowered with VCDS, I still feel like its too high in comfort mode.
    Nov 08 2010
    MD
    I've read it is a 20mm delta through the normal range though never measured. I've dropped 12 mm and Dynamic now gives me "one-finger" clearance. Auto and Comfort are about two-fingers so I'm thinking it probably is very close to 20mm.
    May 18 2009
    Los Altos, CA
    I can 100% confirm because when sitting idle the car raises and lowers immediately after you switch between comfort and dynamic (although over about 15 seconds). As I said above, just look at a stationary object beyond the hood and you will see it go up and down as the front and rear separately raise or lower, depending on the selected mode. I've also measured from the tire and yeah, it raises and lowers :). In fact, some people have used VAGCOM to lower their cars over an inch vs DRC.
    Oct 21 2009
    OC CA
    Sorry about jacking this post, but with DRC, do I lose anything by installing coils?
    Nov 05 2006
    Fair Lawn
    Quote Originally Posted by TTGTOVR4 View Post
    ride height
    Senior Member Two Rings FourRings115's Avatar
    Sep 28 2016
    Hoboken
    This is correct. I can also see the high speed ride height changes often driving home. My route is a highway that ends with a traffic light, so I go from the lowered/over 70mph height to stopping suddenly. I can see the ride height change compared to the stopped car in front of me. My two previous A8's did the same.
    '16 S6
    ‘14 Porsche Cayman S
    '18 Subaru Forester (company car)
    '11 A8L 4.2 (sold)
    '07 A8L 4.2 (sold)
    '04 A6 2.7T (sold)
    Dec 20 2006
    CAN
    To all the naysayers out there who don't think comfort/dynamic changes ride height, well think again ladies! ;)
    Haha, i was way off base, doesn't happen often but i'll admit when i'm wrong.
    Difference between comfort and dynamic. Looks like a 12-13mm difference. Wow!
    Dynamic
    Comfort
    Sep 26 2013
    scottsdale, az
    Dynamic
    Comfort
    Yes - that def looks about right - I'm happy you put a number to it 12-13mm
    So is that the same 12-13mm that the car LOWERS once at speed (70mph?) in comfort mode?
    Feb 25 2014
    Texas
    Nice ride!
    PS looks better in dynamic
    10.65 @ 129mph
    Dec 20 2006
    CAN
    Nice ride!
    Thanks and yes i agree although it is pretty low in dynamic ;)
    Dec 20 2006
    CAN
    I would like to know if the car lowers below dynamic level when above 100km/h or whatever speed it does that.
