Page 1 of 6 123 ... LastLast
Results 1 to 40 of 204
    Apr 05 2016
    Portland, OR
    Autotech HPFP Upgrade DIY
    Parts:
    Your OEM Pump (New)
    Autotech HPFP Upgrade: http://www.autotech.com/mm5/merchant...de=10-127-101K
    Optional:
    Pump O-ring: OEM or 3rd party
    Cam follower: OEM or 3rd party
    Tools:
    VCDS
    Socket wrench
    10mm Socket
    M8 Triple Square Bit
    Crescent wrench
    Some rags
    Bench vise
    90 deg bent nose pliers and the strength of the gods
    OR
    screwdriver and a hammer
    Pump overview:
    Code:
    1. Low Fuel Pressure Sensor -G410-
    􀁺 15 Nm
    2. Seal
    􀁺 Replace
    3. Bolt
    􀁺 Tighten by hand in a diagonal sequence and then tighten to 5 Nm
    􀁺 Final tightening specification: 20 Nm
    􀁺 Do not tilt the high pressure Pump
    4. High Pressure Pump
    􀁺 With fuel metering valve -N290-
    􀁺 Removing and installing, refer to HIGH PRESSURE Pump
    􀁺 Do not disassemble
    5. Threaded Connection
    􀁺 27 Nm
    􀁺 Connectors should not show any signs of damage
    6. Fuel Supply Hose
    􀁺 Low pressure side
    7. High Pressure Fuel Line
    􀁺 27 Nm
    􀁺 Reduce the fuel pressure in the high pressure area, refer to RELEASING PRESSURE IN HIGH
    PRESSURE AREA.
    􀁺 Removing and installing, refer to HIGH PRESSURE LINE.
    8. Gasket
    􀁺 Replace
    9. Housing
    10. Camshaft Position (CMP) Sensor -G40-
    􀁺 Removing and installing, refer to Camshaft Position Sensor -G40- / Camshaft Position Sensor 2
    -G163-
    11. Bolt
    􀁺 9 Nm
    12. O-ring
    􀁺 Replace
    􀁺 Lubricate O-rings with clean engine oil before installing
    13. Protective Plate
    􀁺 For high pressure line
    14. Nut
    􀁺 9 Nm
    15. Double Bolt
    􀁺 9 Nm
    16. Roller Tappet
    􀁺 Can be installed in one position only
    17. O-ring
    􀁺 Replace
    Removing the pump:
    1.
    Start the car and remove the fuse for the fuel pump. It is located in the driver's side fuse box. It was bank 2 fuse 3(25A) on my 13 S4.
    Let the car idle until it dies. Leave this fuse out until you are done. (Letting it die is optional, I'd pull the fuse regardless)
    2.
    Remove your intake, I'm not going to cover this step as everyone is slightly different. Here is what you should be left looking at:
    The HPFP is located on the front passenger side of the engine:
    3.
    Using your 10mm ratchet remove the two bolts holding on the metal shielding. Remove this shielding and set it aside.
    4.
    Wrap the top of the fuel pump in a rag and using a crescent wrench remove the high-pressure line[5] from the pump. There will still be quite a bit of pressure in here so loosen the line then wait a few seconds before fully removing it.
    5.
    Remove the low-pressure line[2] by removing the hose clamp near the pump or by disconnecting it from the quick disconnect near the MAF sensor. (I have an ECA so your disconnects will be different)
    6.
    Undo the two electrical connections to the pump[1 & 6]. They are both located on the bottom. (You can do this after removing the pump if desired)
    7.
    Place a rag under the fuel pump to catch the cam follower and any extra fuel if it comes out.
    Remove the two M8 triple square bolts holding the pump in. To remove the bottom one you will likely need an extension. [Arrows in the above pic]
    8.
    Remove the pump and cam follower. Both are keyed so don't worry about orientation.
    New vs Old
    Installing the autotech upgrade:
    For reference here are Autotech's instructions: http://www.autotech.com/instructions/10127101k.pdf
    Place the pump in a vise:
    Remove the spring by pushing down on the spring rataining clip and sliding it off.
    Removing the retaining ring can be a PITA. I used a hammer and punch to tap it off. Alternatively, Autotech has a tool to aid with this.(It has normal threading)
    Once the ring is removed the internals should slide out.
    Replace the piston with the Autotech upgraded one and reassemble the pump how you pulled it off.
    The internals go like this:
    Take note when tightening back down the retaining ring that it has a flat face (If you used a hammer).
    Reinstalling the pump:
    Follow the pump removal steps in reverse order to reinstall the pump. (Torque specs are in the overview above)
    After everything is installed and tightened down replace the fuel pump fuse you removed earlier.
    Now unlock or open the driver's door to trigger the pump to auto-prime. (You should be able to hear it)
    Do this a few time and make sure there are no leaks.
    Now fire the car, and again make sure there are no leaks. You will likely have a CEL on, use VCDS to do a full scan, save the logs then clear all DTCs.
    This will remove the CEL and reset the fuel trims.
    Go take it for a short drive then park it and inspect for any leaks.
    If you don't see or smell anything you should be good to go.
    Depending on your tune you may get DTCs from time to time for fuel real pressure. This is normal
    Geoff
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    It's a shame that the little piece of metal is $400
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    :slowclap:
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by rtl5009 View Post
    I know right? I got mine for $280 off ebay but still.
    Our pumps are used in the 2.5T, 3.0T, 4.0T, 5.0T and a bunch of other motors. How we don't have a plug-n-play upgraded pump is beyond me.
    Geoff
    Aug 09 2011
    Brooklyn, NY
    Good stuff!
    Can't wait for the Water Meth write up!
    '16 Audi S6 4.0TT Eurocharged ECU - Current
    '12 Audi A6 3.0T Prestige - 187/57 DP Eurocharged ECU /TCU - Trade
    '06 Audi A6 3.2 Prestige - Sold
    '00 VW Jetta VR6 - Donated
    '98 Audi A4 Stage 3 - Gone
    Jul 21 2004
    South Florida
    Thanks taking the time for the writeup!
    2018 Audi S5
    Gone-
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Thanks for the write up, I'm getting ready to install the HPFP. Picked up the O-ring and cam follower.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    +1, thanks Geoff. Didn't even think of the follower and oring. Will get them ordered.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Great write-up! How did your cam follower look like?
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Apr 05 2016
    Portland, OR
    I didn't snap a good picture of it.
    It had a tiny bit of wear but nothing alarming. My car has 30k on it.
    I didn't order an extra one beforehand or I would have swapped it just to be thorough.
    I think I'll add it to my 60k maintenance list.
    Geoff
    Sep 21 2016
    Alberta
    At what power levels is this required at? Or more for running E85?
    Apr 05 2016
    Portland, OR
    Mostly E85 blends.
    Jul 28 2009
    Philadelphia PA
    Are there any documented cam follower failures? It's a much better design with the roller than previous VW designs.
    c8 a6 allroad
    Apr 05 2016
    Portland, OR
    Not that I've heard of.
    Geoff
    Oct 06 2014
    Cleveland, OH
    Awesome write up Geoff! Thanks, it is on my list of things to do, after DP.
    Feb 26 2014
    2019 Ford F-150 XLT zfgRacing 93 tune. 1986 Ford Mustang Gt t-top 76mm turbo
    New York
    Finally had the chance to read it. Great write up Geoff. Did you see a difference in fuel pressures and how’s it holding up. Just received mine and it has a list of things to look out for and warranty exclusions, lol...
    Aug 09 2017
    South Africa
    Quote Originally Posted by whiped View Post
    So just to confirm. I can use the autotech hpfp upgrade from an audi TT/RS3 2.5T?
    Sent from my SM-G955F using Tapatalk
    2011 B8 S4
    Current Mods: 57mm CTS Turbo Upper Pulley | 200mm Custom LW Crank Pulley | Ported Blower by JayTec | Decat |Remus Sport Exhuast | Ported Throttlebody | NX Express Meth Injection | Revo Cold Air Intake with K&N Filter | Triple Pass HX Exchanger | Wulfchiptechnik Stage 2+ Tune
    Mods In Progress: Custom AC Intercooler | Hemi 80MM TB | NX Express Nitrous Kit | Unichip (for meth + nitrous control) | Complete Custom Tune by ATM
    Apr 05 2016
    Portland, OR
    Yeah, the same HPFP is used in a lot of engines.
    Some ads may only list a certain engine but it should carry over.
    Geoff
    Established Member Two Rings tars9's Avatar
    Jun 15 2015
    Schaumburg/IL
    Attempted this instal over the weekend but car keeps springing a leak. At this point, I'm thinking I may have damaged the assembly while in the vice.
    Wondering if anyone knows where to buy components of assembly? Can only find the whole assembly. Also, any common culprits to check? Already did O rikng and cam follower.
    Thanks.
    Sent from my SM-G950U using Audizine mobile app
    2012 Audi B8 S4 | 6MT | Phantom Black | Kohlefaser Luft-Technik Intake l AWE Track Exhaust & Resonated Downpipes l Mertop Long-Tube Cat-Less Headers I EPL Stage II+ l Pulley Ratio 3.28 l PLM HE & Reservoir l ECS Trans and Rear Diff Mounts l CR-15 l P3 VIDI
    Apr 05 2016
    Portland, OR
    Are you leaking gas? I think Chris had his leak where the retaining ring seals.
    You could try pulling it apart again and double checking everything.
    Geoff
    Jun 15 2015
    Schaumburg/IL
    Thanks for the reply. I'll see if tightening that helps.
    Jan 30 2015
    SC
    Just following up cause I'm doing this install fairly soon. Tars, did you figure out your leak?
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by Johnson View Post
    When you do you should take pictures of pulling it apart so I can update the OP.
    I'd suggest grabbing the pump tool 034 makes to make disassembly easier.
    https://store.034motorsport.com/high...-2-5-tfsi.html
    Geoff
    Jan 30 2015
    SC
    Ok I'll take some pictures . Is there a torque spec for this retaining ring?
    Apr 05 2016
    Portland, OR
    No idea, I hit mine with a hammer so it is uhhh... Hammer tight.
    Geoff
    Veteran Member Three Rings Krusty's Avatar
    Sep 18 2012
    long beach
    Sick! Nice job whiped. Somebody put this in the DIYs section.
    2011 sprint blue s4, EC subframe stabilizer, ECS short shifter, Euro Impulse weighted shift knob, custom air intake, RS grille, CR-15, 034 rear diff mounts/rear diff carrier mount inserts, Apikol rear diff mount insert, 10mm(f)/12mm(r), ECS strut tower brace, ECS front adjustable end links.
    Jan 30 2015
    SC
    I found this tool that looks a bit more robust however I'm not sure how this would fit over the spring. It doesn't look very deep from their photo.
    http://autotech.com/autotech-audi-2-...-101k-kit.html
    Veteran Member Four Rings ntsantos's Avatar
    Dec 06 2015
    San Ramon, CA
    It won't fit over the spring. I had to weld a deep socket on top of it, it worked great.
    Established Member Two Rings J.james's Avatar
    Apr 05 2016
    Los angeles
    Nice
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Quote Originally Posted by ntsantos View Post
    You take the spring off and then it works perfect, same tool I used
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    Parts:
    Your OEM Pump (New)
    Optional:
    Tools:
    VCDS
    Socket wrench
    10mm Socket
    Crescent wrench
    Some rags
    Bench vise
    OR
    Pump overview:
    Code:
    􀁺 15 Nm
    2. Seal
    􀁺 Replace
    3. Bolt
    􀁺 27 Nm
    6. Fuel Supply Hose
    􀁺 Low pressure side
    􀁺 27 Nm
    PRESSURE AREA.
    8. Gasket
    􀁺 Replace
    9. Housing
    -G163-
    11. Bolt
    􀁺 9 Nm
    12. O-ring
    􀁺 Replace
    14. Nut
    􀁺 9 Nm
    15. Double Bolt
    􀁺 9 Nm
    16. Roller Tappet
    17. O-ring
    􀁺 Replace
    Removing the pump:
    1.
    2.
    3.
    4.
    5.
    6.
    7.
    8.
    New vs Old
    Take note when tightening back down the retaining ring that it is right and has a flat face.
    Depending on your tune you may get DTCs from time to time for too high of a fuel real pressure. This is normal
    what do you think would be better going from 179mm to 187mm or from a 179mm to a FULL E85 with the HPFP
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
    Jan 30 2015
    SC
    How long did it take for you guys to release the pressure from the high pressure line? I removed the fuse and let the car die but even after 30-45 seconds of loosening the line, it still hasn't stopped spraying fuel.
    Edit: disregard, a couple more seconds and the pressure is released.
    2014 S4 Prestige Monsoon Gray DSG / EPL ECU Tune/ EPL TCU Tune / 183mm Fluidampr / CTS 57mm / MercRacing HX / Autotech HPFP upgrade / AWE track 102mm / Modified stock airbox / aFe Pro Dry S / 034 transmission mount insert / 034 rear subframe inserts / CR-15 / H&R OE Sports w/ Bilstein B8 dampers / S5 Rotors / Michelin Pilot Sport 4S
    Jan 30 2015
    SC
    Does the piece I'm touching rotate or come off? If not, the 034 tool will not work since I can't slide it down to engage the 2 contact points.
    Jan 30 2015
    SC
    Finally got this done yesterday. Definitely wasn't bad at all when you have the right tools (hpfp tool from autotech). Snapped a couple pics that I will upload later. Now just have to wait to get this E85 tune flashed!
    Mar 06 2016
    Knoxville, TN
    Are there any benefits to this upgrade without running E85? I am currenty single pulley but planning to go to a dual pulley setup soon. I run 93 Octane 100% non ethanol.
    2018 Q7 Prestige, APR Stg2, Airmatic Links, Vossen HF-4T 22x10.5
    SOLD / '12 A6 3.0T Prestige / Uni DP 93/e30 tune / p3u tcu tune / Iabed Fluidampr 3.2 PR / Jokerz ported SC / Iabed Porsche TB / Merc HX / 034/AEM intake / JHM v2 test pipes / AWE Touring with modified AWE DPs, Vibrant/GESI cats & MF 11386 / 20 x 9 VMR v702s / Yokohama Advan Sport A/S 275/35/20 / EC sways & Alu Kreuz / 034 LCAs, motor mounts & inserts / LYKT UCAs / RS6 Grill / rear lip spoiler / Bose + Bazooka 10" Sub
    Oct 13 2015
    SoFlo
    Quote Originally Posted by FastLane1000 View Post
    As far as i am aware there is no benefit if you are not using E85
    Jan 30 2015
    SC
    Autotech is sending me a new fuel pump so I will update with results of the new pump. Hopefully this will resolve the issue. So far their customer service has been great. Got a call the same day they received the pump letting me know they are sending a replacement.
    Veteran Member Four Rings Jroyalty7's Avatar
    Jan 10 2016
    Porsche Macan Turbo
    FL
    Hey did you run into problems with their piston? I thought I remember reading about something like that somewhere on here? Glad their helpful... what signs/issues were you having?
    Sent from my SM-G955U using Crapatalk
    Current: ‘21 RS5 Sportback B9.5 Nardo Grey
    Retired: ‘13 S4 B8.5 Phantom Black Pearl
    EPL Stage II DP Tune | EPL 57.60mm SC Pulley | 183mm Fluidampr Crank Pulley | S4Matty Ported SC and TB| Aquamist WMI 375cc Jet @ TB| AMS Alpha Heat Exchanger | Milltek Sport Non-Resonated CBE | ECS Kohlefaser Luft-Teknik Intake | Alu Kreuz | CR-15 | 034 Drive Train & Trans Inserts | Bilstein PSS10 | SPC Upper Control Arms | TSW Bathurst 20x10 | Pulley Ratio=3.177
    Jan 10 2016
    Porsche Macan Turbo
    FL
    Just adding some pics from my install
    Jan 10 2016
    Porsche Macan Turbo
    FL
    Oh yeah and these vise grip pliers do an awesome job of tightening down the retaining ring again after installing the autotech piston
