Can someone post the proper brake bleeding procedure for a 2004 Audi Allroad 2.7t?
I am seeing a lot of mixed information. I am installing new brake lines, rotors, and pads. I have a motive pressure bleeder and 2 quarts of fluid.
One note, the fluid may have gotten below the reservoir tank as I was replacing one of the rear lines. I hurried and filled it and the new fluid turned a medium amber color as I could see it was able to mix with some old fluid. Hopefully it did not run dry, however I saw the rear hose stopped dripping fluid when this happened.
Now I have been seeing posts saying the pressure is anywhere from 8psi to 29psi. Plus the order is either front to back or back to front.
Any help would be appreciated. I have a vag-com cable showing up tomorrow so I could run the ABS pump if necessary. If you think I should when does that occur in the bleeding process?
Thanks
