Originally Posted by
Dondbg
How are the JOM ? I see they come with 2 years warranty? And priced reasonably , reviews are good ....
~30mm is what I'm after may a bit more :) I see some sets comes with 40/30mm drop. I understand the front of the B7 is a bit higher , going with 40/30 will make it even, what is the downside of doing that ?
Audi A4 B7 avant 2.0T Quattro 2008 - 94K km
I dropped mine from stock non sport suspension height to pretty damn low with the JOMs. You can play with the adjustment to make it even and level.
As far as the JOMs go, if you go in with the mindset that they will be total shit, like I did, you will be pleasantly surprised that they are not
absolutely horrible however after being on only about 15 months I was replacing a control arm the other day and they look like hell. Good amount of corrosion and rust. However for what I needed to do (ditch 4x4 status) they did the job perfectly and honestly I can live with the ride quality. Nevertheless, still swapping to ST's. If you want a good deal on some Ill sell em to ya real cheap
