I discovered that RS5 "Audi Ceramic" Calipers are half the price of the standard 8 Pistson RS Calipers, while also accepting larger rotors (380mm vs 365mm). So I did some parts shopping, and to me, it looks like you can piece together a 380mm 6-Piston RS BBK for right under $2,000 (excluding tax and pads).
RS Ceramic Caliper (Right)
Part Number: 8T0615108B
https://www.ecstuning.com/b-genuine-...ht/8t0615108b/
RS Ceramic Caliper (Left)
Part Number: 8T0615107B
https://www.ecstuning.com/b-genuine-...ft/8t0615107b/
ECS Stage 4 Upgrade Rotors (380x34) and Caliper Bracket
ECS Kit Number: ES#3221135
https://www.ecstuning.com/b-ecs-part...883ecs01ktkt4/
I'm not even sure the caliper bracket would be needed since the Ceramic calipers are designed to fit 380x34 Carbon Ceramic rotors. They should just bolt up to the hub since the regular RS5 calipers do, no?
Anyone have any idea why this wouldnt work? (Assuming you have wheel clearance)
