Results 1 to 10 of 10
    Oct 30 2012
    Oxford, MS
    P0491 & P0492 Secondary air injection system bank 1 & 2: insufficient flow
    Recently ran out of my CPO warranty and now I have a check engine light. That's how the world seems to work.
    Thought I'd ask if anyone has ever seen or dealt with this one before. If it something I can easily fix then I'd rather do the work. Suggestions?
    Active Member One Ring Miro's Avatar
    Feb 09 2015
    Etobicoke, ON
    In Canada Audi has extended the warranty until 193000km for carbon build up in the secondary air injection system. USA should be the same. This is a known issue with the 3.0T. It's emissions an emissions issue, no damage to your car will happen while driving with the CEL. In addition to carbon build up the codes could be thrown for a faulty sensor or a sticky valve which Audi would not cover.
    Sent from my SM-G930W8 using Audizine mobile app
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    extended warranty covers it. take it to the dealer.
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Oct 30 2012
    Oxford, MS
    Quote Originally Posted by Miro View Post
    Thanks for the info. Sounds like a trip to the dealership. Yay.
    Established Member Two Rings jnicho1's Avatar
    Jan 17 2012
    Baltimore, MD
    Just had mine done. Zero cost. Hope they give you a nice loaner. :)
    Oct 30 2012
    Oxford, MS
    Covered under warranty. They're working me in next week. My last loaner was an A6 and I wouldn't mind that again.
    Established Member Two Rings Idtrav's Avatar
    Sep 08 2016
    Prince George, BC Canada
    Check the small vaccuum hoses near the back of the engine around the firewall. I've had it happen in my A4 and now the S4 and was a cracked line. Cut it where the break is and reattach.
    Assuming that is what's throwing your secondary air injection code.
    2014 S4 6MT PBP-TITANIUM-SPORT DIFF-BLACK OPTICS
    H&R COILOVERS/VOSSEN 20X10 CV2/ROCEURO/AWE TOURING/CR-15/ECS BUSHINGS/ECS CF DECK LID/ RS4 GRILL/ECS SKIDPLATE/BFI AlCANTRA/LED KIT/3M
    Oct 30 2012
    Oxford, MS
    Quote Originally Posted by Idtrav View Post
    I'm out of my CPO warranty. It is being covered under the additional warranty mentioned above for the known issue. It is carbon build up. I just have to wait for them to get loaners back from other repairs.
    Feb 09 2015
    Etobicoke, ON
    I just had mine done. Picking up the car now. It took them 1.5 days to finish.
    Feb 21 2021
    edmonton
    Hey Miro, im also in canada do you have any information with the extended warranty for this job? my local dealer here in alberta is saying theres no such thing
    Thank you
