    Aug 22 2016
    Louisville
    Bad upper control arm symptoms
    What are the symptoms?
    Sent from my SAMSUNG-SM-J320A using Tapatalk
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    Abnormal tire wear. If you're hearing a lot of noise over bumps its more likely the upper shock mount.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Aug 22 2016
    Louisville
    Well I am bringing this car back from the grave so who knows what it is. But what I'm getting is first I noticed when just sitting parked turn the wheel and clunk clunk both ways. Driving it shakes on acceleration stops at about 30 mph comes back at 50mph let off gas shakes till car stops. Constant shake when braking. Also it shakes and clunk harDre when turning. I love this car and hate it at the same time.
    Aug 22 2016
    Louisville
    It's a 2001 a6 Quattro 2.7t. I will look into it more just seeing if anyone had suggestions or experience with this.
    Sep 11 2009
    NE
    shaking is another symptom of that... Just jack the car up and look at rubber bushings, it is about 5 minutes of your time and it will be obvious if they are work or not.
