Before the N6, I was running a Mk2 RNS-E with AMI, OEM Bluetooth, and a newer satellite receiver. It looked good, sounded great, and everything functioned like it should. I was only missing one thing... Good A2DP. I wasn't happy with any available option to get bluetooth streaming on the RNS-E, so I started to look elsewhere.
After shooting some emails back and forth with Jeff at J&T Distributing and browsing some BMW forums (Dynavin is much more popular with them), I decided to pull the trigger. I sold my RNS-E setup and bought the N6 for $749. I even made some money switching, woo!
Here's what came in the mail:
- The box!
- Radio
- Manual
- Stylus (Neat! I've never used it..)
- Removal keys
- Antenna adapter
- CAN box (allows MFSW to work with the HU/radio info to display on the DIS)
- iGo Primo on a MicroSD card along with a full size SD adapter
- Microphone (I just tapped the microphone I had up in the stock location instead of using the included one)
- GPS antenna
- Ground loop isolator (I didn't use this, didn't need it)
- Wiring harnesses for both the Quadlock style and ISO style connectors
- RCA harness for connecting external a/v sources/playback devices and backup cam, etc
- USB cable
I'm not going to do an install DIY because it was easy. Remove old radio, install new one, run wires to where you want them, enjoy. There, best DIY ever.
Here's some installed shots of the unit. I just made a little panel in my glovebox with some couplers I had laying around. I already had a hole cut there for the AMI to sit in there. RIP AMI... Also, a shot of the reverse camera I used (I know it's no longer available at that link, but you can find the same one all over the internet - I paid $15 for that camera and it actually produces some great video and does nicely in the dark). Also, I know my car needs a bath.
Now here's a video of the magic and a few notes on the video sequence:
- Radio (reception is definitely better than the RNS-E but still not totally amazing, make sure you select phantom power in the radio settings - the little cog on the bottom of the radio screen)
- Bluetooth phone (not much to explain here, it works. You can also set the MFSW left thumb wheel click to activate Siri or Google Now, so voice activation works great)
- iPod (forgot to show this in the video, but it works great and displays album art as well. You can search, list by artist, song, album, playlist, etc - full functionality)
- A2DP (sweet, sweet A2DP functionality. No album art, but the track info and skip buttons work, such happiness)
- Navigation (the unit comes with iGo Primo loaded on a MicroSD, works great! The version they send doesn't have any voices that read out the street names, so I modded the software to do that. I also modded the speech library to say "northbound" or "southbound" for things like "turn left onto I-15 SB." It originally would just say "SB." That's just me being picky though. Other than that, the nav system is waaay more capable than the RNS-E.
- The OBC (onboard computer) screen doesn't display anything, this only works for the BMW guys
- Sound settings
- You can set individual speaker delay times if you want for sound staging, I don't bother with this.
- I found the bass output to be a little weak at the original levels, so you can see everything turned up in the video
- You can adjust the levels on each source, I have them all turned down because I like to have the most versatility with low volume levels for when people are in the car
- System settings
- Brightness can be configured to adjust manually or automatically. I have mine on auto/use built-in light sensor, seems to work just fine.
- SD Card (plays music, video, pictures, pretty straightforward)
- Reverse camera (works great!)
- Second video shows the DIS working
Now for some notes and bugs with the N6:
- Cold boot starts when you unlock the car with the remote, takes about 15 seconds or so. Cold boot only happens when you've been away from the car for awhile. The reverse camera works during boot.
- Bluetooth connects to you phone whenever a door is opened instead of when the car is actually powered up. I have to turn off BT on my phone when listening with my garage speakers, so it doesn't try to start playing on the car when I open doors.
- The "Loud" setting disables itself after making a BT call. The checkbox is still checked under sound settings, but I have to uncheck and check it again to get it activated again. "Loud" isn't needed though - using the equalizer I've matched what my RNS-E sounded like.
- All of the default source levels are a bit high for me (I like more control of low volume levels for when other people are in the car) so I have them turned down all of the way.
- I've modified my iGo navigation software to be able to announce road names, this is just my personal preference.
- There is an Apple CarPlay add-on you can purchase, I don't know much about it but you can read up on it here
- The N6 supports dual zone control (external displays) - I don't use this
- It plays DVDs, also don't use this
- MAJOR NOTE: Dynavin has released the N7. New features include built-in Apple CarPlay, Android Auto, Capacitive Touch Screen, etc.
Overall:
I've been happy with the N6. It does everything I want it to and most of all A2DP works perfectly. Now I can stream/control Spotify from my HU and steering wheel. Life is good. I initially had more issues with it when I got it, but Dynavin was good about responding to emails and fixed pretty much everything in new firmware updates. The "Loud" setting is the only thing that I haven't seen fixed yet. With my current sound settings, it sounds pretty much the same as my RNS-E did. Low volume bass levels are a bit lower (because I have the "Loud" setting is disabled) but this is by no means a deal-breaker for me and I'm hopeful that they'll get it fixed in a firmware revision. The N6 looks at home in the A4, not quite as OEM looking as the RNS-E, but most people think it's the original HU when they get in my car. The buttons click nicely, and everything runs smoothly. If anyone has questions, feel free to ask them here!
I'll finish out with the specs for the N6 from Dynavin's website.
Tuner
Memory Presets: Preset Stations (FM:15 / MW: 15)
Memory: Auto Memory
RDS Functions: AF, TA, TP, PTY, NEWS, RADIO TEXT
Bluetooth
Built-In Parrot Bluetooth Module
Hands Free Calling
Phone Book Transfer
Phone Book Search: Alphabet Search
Favorite contacts
Wired Microphone Included
Redial Function
Call History Display
Adjusting the volume when receiving a call
Made for iPod/iPhone
USB Connection
Compatibility with iPod / iPhone / iPad with 30Pin or lightning connector
M.I.X. (Shuffle) Capability: Song, Albums, All
Music Control: Song Up/Down, Fast Forward/Backward, Repeat
Available Selections: Playlist, Artist, Album, Song, Podcast, Genre, Composer, Audiobook
Alphabet Search Function
Information Display: Album Art, Song (Title, Album)
Direct iPod/iPhone Control Function
Disc Player
DVD/CD Player
Disc Playback Type: DVD Video, DVD Audio (2ch mix down), CD, CD-R, CD-RW, DVD+-R/+-RW, DVD-VR
Compressed Media Playback: MPEG/ AVI /RM/ FLV/ ASF/ WMV/ MP4/ MKV/ OGM/ DivX/ MP3/ WMA/ AAC Playback
24bit-DAC
Sensor: Music Sensor Scan, Repeat
Playback Control: Play/Pause, Fast Forward/Backward
DVD Direct Menu Control
M.I.X. Mode: One (Folder) / All (Random Play) / Random (CD Only)
USB / SD Media Connection
USB Connection (USB Cable Included)
Cover Art Display
Music Playback: MP3/AAC/WMA Playback
USB Class: Mass Storage, Play from device
Sound Tuning
Subwoofer Level Adjustment
Dyna-Bass level adjustment
Bass Level Adjustment
Treble Level Adjustment
Source Tone Memory
Time Correction Adjustment
Equalizer: 5-Band Parametric Equalizer Feature
General
Power Output: 4 x 50 W High Power Amplifier
High Grade Audiophile Design
SD Card: Video Playback
PreOut: 2 PreOuts (4V) and 1 AV Output
PreIn: 2 PreIn (Front / Rear) Ready
AUX-In: 1 AV Input
Steering Wheel Control Ready (Adapter Required)
Auto Dimmer
Power Antenna Output
Amplifier Remote Turn-On Output
Audio Interrupt
Camera Guide Line Adjustment
Dual Zone Control
Connection
Power & Speaker : ISO 16pin
Radio: Single Fakra / Dual Fakra
GPS: Fakra
Steering wheel control: Universal Analog steering wheel control
