Originally Posted by
A4x
Are you sure about the EDL (electronic locking differential)?
Is this part of the traction control system? Seems like EDL is just using the brake on one side to lock up that wheel. Not 100% sure tho.
yup, EDL is a part of the braking system but its behavior also integrates with the quattro system
the downside to any open differential is that if one side slips (like on ice or snow), the other side won't receive any power. The old school method of getting around this was to apply a little bit of brakes so the wheel free spinning on ice slows down and transfers some of its energy to the opposite wheel (that has traction). EDL just does as you described (except without using all four brakes) so if one tire from the front and rear are simultaneously slipping, EDL locks those tires up with brakes so the open diff can transfer of power to the wheels that aren't slipping.
for our cars, front and rear are open differentials although other models might use a viscous coupling or a true LSD diff (torsen/audi sport differential)
For anyone still interested, I think this video best illustrates and explains how the systems work
bear in mind the setup for the SQ5 is
front: open diff with EDL
center : torsen
rear: (audi sport differential/torque vectoring)
