Originally Posted by
dancsank
The passenger windshield wiper stop working on my car... 0 car knowledge and barely any tools.
First thing you can try is taking a flat head screw driver (or butter knife if you don't have one...) and pop off the black plastic cap at the base of the wiper arm. Then turn on your wipers and see if you can see the nut or the threaded stock turning. If it is then turn off the wipers and tighten down the nut and you should be good to go. If nothing is turning on the passenger side at all then yes you likely have part of the wiper linkage broken.
As you can see in the video linked above, a very basic socket set is all you need to replace the linkage, it can be tedious though if you haven't done it before. One thing you might not have is the appropriate star/torx bit for removing the ECU cover to get access on the drivers side. Watching the video alone should give you all the information you need to at least trouble shoot what is actually broken (if anything) and then judge for yourself if you want to tackle it yourself. BTW you shouldn't need a two arm puller to remove the arm, you just need to have it bent at the right angle to pull it off. Bend the arm up at the hinge (may need to move it under the hood), grab the wiper arm at the base, while pulling straight up give the piece the bolt was threaded on a few taps with a hammer and the arm should pop right off.
