Results 1 to 21 of 21
    Nov 21 2014
    Montreal
    5x112 19x8.5 et43 Would Fit?
    Hey,
    Got someone selling 19" oem audi wheels from a B8 Sline. They are RS4 style wheels, 5x112 19x8.5 et43.
    How well would these fit on a A4 B7 with stock sport suspension?
    I am running 18" VMR 708 18x8 ET45 with 245/40/18 tires at the moment and while they fit, they are very close to the suspension I can fit only one thumb inside between the wheel and suspension. 2 of them were damaged this winter
    Would the original oem 19" be stronger than VMR 18"?
    Mar 29 2012
    SF
    I was running 19" B8 S4 wheels for awhile but I had H&R lowering springs but that wasn't an issue at all with clearance. Your talking about space between the tire and top of the fender or between the tire and side of the fender?
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by AudiKilla View Post
    Imo 99% of all stock oem wheels are stronger then aftermarket wheels
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    I am running these exact specs on my car on air ride. They will fit fine on your car with stock suspension.
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Nov 21 2014
    Montreal
    What's the max tire sidewall do you guys think I can run with the 19" without any rubbing?
    Nov 21 2014
    Montreal
    I got 245/40/19 tires, hope it fits
    Jun 17 2013
    jersey city nj
    I ed 255-35-19
    Nov 21 2014
    Montreal
    I wanted to have a bit more sidewall because of the bad roads here
    I'll install them in a day or two let's see how they
    Apr 24 2015
    San Diego, CA
    Fyi hub bore is different, B7 is 57.1 mm and B8 is 66.6 I believe. I'm using hub centric rings to run B8 wheels.
    Nov 21 2014
    Montreal
    Yup, got the rings already.
    Oct 03 2016
    Denver Colorado
    I'm running 19x8.5. Et 45. Tires 225/35/19. I use this website called willtheyfit.com. You enter your stock numbers and the aftermarket numbers and it tells you what differences there will be when it comes to inner clearance, outer clearance, overall diameter.
    Veteran Member Three Rings RandyBeanz's Avatar
    Jan 12 2017
    Honda Pilot
    LA
    I'm running these rims I got off an a5/s5 owner and 255/45/19 and I'm only rubbing when I hit dips. Going into body shop soon for a wide fender pull all around soon though.
    Nov 21 2014
    Montreal
    Do you have stock sport suspension?
    Aug 20 2011
    Seattle Wa
    There is no way that is a 255/45/19
    -James
    Jan 12 2017
    Honda Pilot
    LA
    Quote Originally Posted by Solarsuplex View Post
    Sorry typo 35 not 45
    Nov 21 2014
    Montreal
    Quote Originally Posted by RandyBeanz View Post
    Stock sport suspension or something else?
    Jan 12 2017
    Honda Pilot
    LA
    coilovers
    Nov 21 2014
    Montreal
    I tried to put the wheels on, but the front wouldn't fit back were fine. Had to put on 10mm spacers in front to clear:
    Is it because of my tire size (245/40/19)?
    Nov 21 2014
    Montreal
    Do you think 235/40/19 instead of 245/40/19 would have fit or need to reduce sidewall from 40 to 35?
    Nov 21 2014
    Montreal
    They rub, got 235/35/19 tires now let's hope this fits.
    Oct 24 2015
    Perth, WA
    You don't want to change the overall diameter, it needs to be 35 with a 19" rim. They will fit fine.
    People with 255s, are they protruding past the guard/body?
    My respray thread
