Results 1 to 10 of 10
    Apr 20 2008
    2012 S4, 2003 Passat
    Sacramento, CA
    High Pitched Buzzing Noise Continues After Shut-Off (2016 A6 3.0)
    I just purchased a used 2016 A6 3.0t. I noticed that when parked in my garage (after shutting off the car), it emits a somewhat high pitched buzzing from the engine compartment for about 10 minutes. It's fairly subtle - I had to point it out to my wife for her to hear it. My concern is that not only is it annoying, but the battery was replaced by the dealership before I bought it, and now I'm wondering if it's some sort of power draw issue.
    Has anyone else experienced this with the 3.0 A6, within the same model year range?
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    There's just some things that mere mortals will never understand. It's an Audi and there's all sorts of programming in the electrics that click, clack and, in your case, hum from some unknown reason. Over time, if it's something bad, it will fail and the service department will spin a tale of camtoids and frammisses and caused the vague error messages and a loss of function.
    Every time I open the hood with the engine off, I hear relays and/or valves opening and closing. I don't know what they do and the best guess is that it's doing something as designed.
    2012 A7 3.0T Prestige, Ibis white/Nougat/Ash, 20" Sport, ACC, LED, HUD, Ferrada FR2 wheels, AWE Touring exhaust, Adam's Drag II rotors, BlackVue dash cams
    As I've grown older, I've learned that pleasing everyone is impossible,
    but pissing everyone off is a piece of cake
    Apr 04 2017
    Lawrence KS
    I've got a 2016 A6 as well and my vehicle does the same thing. I've not had any issues arise from it though so I just ignore it.
    Sent from my iPhone using Tapatalk Pro
    Dec 18 2014
    DMV
    Does the A6 have fans to cool down your engine like the S6? if so that is what you're hearing.
    Sold: 15 S4, 16 Tornado Gray S6, 16 Glacier White RS7, 18 White Q5
    Current: Black SQ5, Black V10 R8
    Next: Gemera
    Apr 29 2016
    2021 Q7 Prestige
    Los Angeles, CA
    There are two batteries on the A6/S6. What you hear, I believe is the rear battery that controls things like the lights that come on when you unlock, the fan up front, i think the stereo that works even when the car is 100% off, the air suspension etc. Walk out in the morning...and either unlock the car or open the door...and you will hear that battery power up certain functions. Press play and see the screen pop up and start playing ... Audi has a dual battery system. If you look at the maintenance schedule...it clearly calls out on the 15 and 30 services that the rear battery be checked.
    Dec 17 2013
    Ireland
    Where's this second battery you speak of?
    Sent from my Pixel using Tapatalk
    2012 a7 3.0 TDI 245hp quattro s-line RHD
    Senior Member Two Rings Tidefan73's Avatar
    Sep 16 2016
    2014 Beetle R (Wife's), 2005 Nissan Titan LE
    F'Burg, VA
    Quote Originally Posted by parkstr8 View Post
    The maintenance schedule I have says that's only for Q5 hybrids:
    First at 15,000 miles (25,000 km) or two years, whichever occurs
    first. Thereafter, every 20,000 miles (30,000 km) or two years,
    whichever occurs first.
    ♦ 12 volt (small) side battery located in the trunk compartment
    on left side - check for clean terminals (no corrosion), properly
    mounted housing and no damage; replace if necessary (Audi
    Q5 hybrid only)
    Took delivery 12/05/2016:
    2017 S6 Prestige | Daytona Grey Pearl | Black Optics | Sport Package | Comfort Seats | Carbon Inlay | EPL Stage 1 ECU/TCU | CETE ASC v2 | Signature SV304S 20x9.5 ET35 w/ 275/35/20 | BlackVue DR650S-2CH
    "I love this car!!" -Me
    Insta: Tidefan73_S6
    Veteran Member Three Rings bpd's Avatar
    Feb 01 2017
    Seattle WA
    My '17 makes the same noise. Pretty normal.
    Apr 20 2008
    Sacramento, CA
    Thanks, I'll ignore it.
    Senior Member Three Rings dc2002's Avatar
    Jan 29 2007
    Roswell GA
    Likely the aux electric water pump that can run for a few minutes after shutdown.
    2012 A6 3.0T Prestige
    EPL Stage 2
