You either want to have money-to-spare, or wrenching skills.
I absolutely love my car - but I'm not afraid of jack standing it in the driveway and solving whatever problem comes my way. (did full timing service solo on jack stands for instance).
Depending on the condition of the car, you might consider some preventative maintenance just to settle your mind and drive without worry.
If you pay someone to do work on this car, it's expensive because you're paying audi shop rate or working with a non-audi specialist (not suggested). But I wouldn't waste my money and would suggest learning and doing the work yourself. There isn't anything scary on the car and enough DIY's out there that you can do pretty much anything you need without concern.
The car is a joy to own, a joy to drive and a treat to mod. I've loved the journey but am not one of those people that buys a car and expects to be able to beat on it and have it just keep running flawlessly. I expect it to break, I've done enough research to know where it's weak and where it's strong. I also know what to expect in the weak areas. I understand each fluid in the car and know when I see something on the ground how to figure out what the problem is. Power steering Fluid - Bad line or rack, Oil - Bad seal or PCV, Water/anti-freeze - water lines / radiators, brake fluid - MC or brake lines... it's not hard to love on this car but it will get pretty expensive pretty fast if you have to put it in the shop every time a little thing goes wrong.
Also, if you're buying a car - there are a few rules for shopping for an S4.
1. Know the history (if you don't it's more risky)
2. Know the milage (under 75K prepare for some services to come and maybe do some preventative maintainance)
3. listen to it at start up from cold (check oil level before starting it) if it rattles, then you learn something, if it doesn't then you learn something...
4. state of the rotors, feel of the clutch when you drive the car, how it smells when it gets to temp all tell you about the car and it's history/condition.
Hope that helps.
Have a car you're looking at?
