Results 1 to 38 of 38
    Established Member Two Rings kwstantinosk89's Avatar
    Oct 01 2016
    isuzu pickup 1989
    cyprus
    Headlights chips
    anybody have the same issue with headlights lenses? too many small chips! can i do anything to make them look clear? maybe tint them?
    Sent from my SM-G900F using Tapatalk
    Veteran Member Three Rings bluefox280's Avatar
    Jul 03 2005
    Broomfield, CO
    Wet sand, plastic cleaner abrasive and buffing compound - that all you can do.
    - Erik
    PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    Aug 06 2012
    Parker, CO
    I clear bra'd my headlights after buying my allroad - no problems
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    X2 follow both of these reccomendations. I did that on my last audi and they came out excellent.
    Sent from my SM-G935T using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    To prevent!.. xpel when new... Then replace xpel every year and half or so depending on driving millage
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Aug 17 2015
    California
    Where can I buy the xpel from? Or do I have to use an installer?
    My headlights are pretty bad. Need to polish them then apply some protection. I'm getting sick of this.
    Veteran Member Four Rings Zach L's Avatar
    Feb 23 2010
    Austin, TX
    Buy new housing lenses ($170) then put lamin-x aka xpel on them.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Aug 17 2015
    California
    Quote Originally Posted by Zach L View Post
    OK I found the link to Lamin-x on ECS, but do you have a link or part number for the housing lenses?
    https://www.ecstuning.com/Audi-B8_A4...ights/Lamin-X/
    Jan 16 2011
    Earth
    I highly reccomend having it professionally installed.
    Oct 01 2016
    isuzu pickup 1989
    cyprus
    Thank you bros for the answers! I bought the car used from England last May..so many chips first time i see on a 2years car wtf 🤐
    The only thing i can do now maybe its clear bra d my headlights but i think the chips will look the same at night ...
    Aug 17 2015
    California
    I've started to research this. It might help to buy a headlight restoration kit and use the various grit sandpaper to gently remove some of the factory clear coat (be sure to wet sand very gently!). Then polish them up and apply protection like Lamin-x. I might try this.
    To the poster above who recommended to have Lamin-x professionally installed. Why?
    It doesn't look like it would be too difficult to do the headlights. I would not want to do a full bra tho.
    Oct 01 2016
    isuzu pickup 1989
    cyprus
    Quote Originally Posted by A4x View Post
    Or maybe if we try a clear coat spray paint maybe the headlights will look better...
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    I'd be very hesitant to sand the lenses. It can look better in the short term, but once that protective layer is removed they can turn yellow. Just my 2 cents. Film would be your best bet, but all headlight lenses do this over time unless they're immediately protected so I wouldn't sweat it.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    Here's a link for lenses - pre-facelift only though - haven't came across a set for the B8.5 yet...
    http://m.ebay.com/itm/Audi-A4-2009-2...%257Ciid%253A2
    Cheers,
    Ry-man
    Aug 17 2015
    California
    Are these headlights plastic or glass?
    I'm hesitant to wet sand as well, but after reading online this can help to remove the rock chips. Then if you cover with Lamin-x it should help to protect from UV light and yellowing, right?
    The Sylvania headlight restoration kit comes with a finishing compound that is a UV protectant.
    Veteran Member Three Rings Roadtrippn's Avatar
    Sep 15 2011
    Hilton Head Island
    Quote Originally Posted by CONative View Post
    Yup i have those new lens coveres ordered via ebay. He took my offer for -10$ from the list price. Damn you guys are bad for my wallet cause my I'm thinking I'lll protect them with lamin x. And yup they're plastic. The fog lights are glass, and mine are all fogged up. Anyway to restore those?
    18' RS3 Stage II and all the Fixn’s
    21' SQ8
    2011 A4 2.0TQ 6MT Stage III
    2001 A4 Stage II
    Oct 10 2012
    Zionsville and Saint John IN
    Find someone selling cheap halogen headlights and swap lenses.
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
    Aug 17 2015
    California
    How hard is the lens swap? It involves baking and cracking open the glue? Then re-gluing?
    Might be worth it to try a polish first. Then if they mess up or yellow after a year, replace with those lenses above.
    Either way once you get a cleaned up lense, I'll be sure to cover it with Lamin-x immediately.
    Sep 15 2011
    Hilton Head Island
    I've never tried the oven way, a heat gun works pretty well. They're like 15$ on amazon prime. Lots of DIYs on here.
    21' SQ8
    2001 A4 Stage II
    Aug 17 2015
    California
    Quote Originally Posted by Roadtrippn View Post
    Yea I just read a few DIYS and this does not look fun at all. They say the oven will damage other parts of the headlight, so yes a heat gun is way better. But still doesn't look fun and you risk damaging them.
    I'don't prefer to just go with the polishing method. If it messes up, or yellows, then I suppose I'll buy a heat gun and replace the lens.
    Anyone have experience with the wet sanding/polishing? There are a lot of DAYS for various other models. It looks like a good solution as long as you protect from UV rays after (re: Lamin-x)
    Oct 01 2016
    isuzu pickup 1989
    cyprus
    Here are some lences for the b8.5 that i can save some money and buy them, but who has the balls to change them?!?! when the headlights are $1000 and you risk to damage them
    Feb 23 2010
    Austin, TX
    I just ordered a set yesterday morning, and they accepted my -$20 offer. Thanks for posting last week about them taking your offer. I had tried -$40 several months ago and they denied it, so I think -$20 is getting near the max. I'd suggest someone else to try a -$30 offer.
    I also ordered some Xpel protective film to protect against sand pitting and add an extra layer of UV protection. Planning to swap in ZKW-R clear projector lenses, Osram CBI bulbs, and possibly modify the protector's cutoff shield as well.
    I usually do the oven method then also use a $10 Harbor Freight heat gun for difficult areas. Works great.
    Oct 01 2016
    isuzu pickup 1989
    cyprus
    For b8.5 here
    Sep 15 2011
    Hilton Head Island
    No problem. Wow -$20, shoot i overpaid! Wow that'll look awesome. I'm planing to remove the vinyl on my headlight corners while I'm in there. its bubbling badly and ill just paint them. I'm dreading the job it's a pain in the butt.
    21' SQ8
    2001 A4 Stage II
    May 06 2015
    @Lambda13 maybe can chime in on lens removal - I think he's done this a dozen times or so now and bakes the housing versus using a heat gun.
    I'll put in for -$30 and let you guys know if the seller accepts or not.
    Cheers,
    Ry-man
    May 06 2015
    And he accepted. -$30 is the new best offer.
    Cheers,
    Ry-man
    Mar 24 2014
    B8 fog lights do that cloudy thing, I don't know why. Pull them out, remove the bulb, and wrap a paper towel around the eraser end of the pencil. If you stick that into the fog light you can wipe off the cloudy grime and they'll be good as new. While they're apart you can wrap them with clear vinyl as a protectant or yellow to look cool.
    Have seen, can confirm. I witnessed him open and perfectly reseal 3 separate sets of headlights in one afternoon last fall.
    Senior Member Two Rings mecg's Avatar
    Apr 12 2016
    Readfield, Maine, USA
    I'll be sanding my lenses this coming week. Starting out with 1500, then 3000, then 5000 grit, followed by compound then polish, then a UV protection layer. Should look awesome.
    2013 Audi A4 quattro Prem, ZF8, APR Stage 2+ 93/E85 Tune + Cast Downpipe/HFC, R8 coils, aFe Dry Pro, Eurocode Intercooler pipe, Turbo Muffler Delete, Fitch Fuel Catalyst, RS Grille, Tinted windows, Audi logo puddle lights, Interior LEDs, VCDS tweaks, 18x8 Andros R9 Wheels w/ Michelin Pilot Super Sports
    2008 Saab 9-5 2.3T BCB², K&N, Fitch Fuel Catalyst, Interior LEDs
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    I agree when you start to wet sand the UV coating on the oem lens it will start to go a bit yellow after a year.
    Dec 01 2011
    if you sand them you also have to clearcoat them again, they turn yellow if you don't.
    new headlights - put some xpel/laminx or good quality (3m, etc) clear vinyl on them, and change every 2 years or so.
    old headlights - get them sanded and polished, then apply new clearcoat over them, let that new clear fully cure for a month or two and then you can do the above on those to keep them fresh.
    IG @theshawon
    Feb 23 2010
    Austin, TX
    Quote Originally Posted by mecg View Post
    ...for six months. Then plan to do it again. New lenses will last 4+ years easy. Refinishing just isn't worth the time it takes, and that's not even counting the money you'll spend on materials. It's a temporary fix that needs attention every year or more often.
    Dec 01 2011
    well it will last long term if you get it painted with actual clear at a paint shop, not just the off the counter clear or the one in the headlight kits. for those not comfortable with opening up and swapping lenses, you can get them properly restored by a paint shop. probably for less than the cost of new lenses, not even counting the effort to open and reseal them, and if not done properly you risk not sealing properly and open yourself up to condenstation and more headache.
    IG @theshawon
    Sep 15 2011
    Hilton Head Island
    When I open mine up in a few weeks to swap the lenses, I'm going to remove the crapppy black vinyl I have on my corners and paint them. Any suggestions on what paint to use?
    21' SQ8
    2001 A4 Stage II
    Feb 23 2010
    Austin, TX
    Quote Originally Posted by Liquid Smoke View Post
    At that point you've spent more than you would on new lenses... for a end result that will come close but never be as perfect. Plus you've got the cost of the sand paper, polishes, compounds, applicator pads, and time equals money too. Replacing lenses is super easy, even for headlights that use permaseal epoxy. Our B8 lights don't use permaseal so they're even easier. Plus I'm opening up my lights to throw in clear glass ZKW-R projector lenses, so it's absolutely zero extra work and zero extra time. The end result will be superior to e-codes.
    Feb 23 2010
    Austin, TX
    I'd use a high temp flat or satin black. The satin may match the black plastic inside the headlight that's visible.
    Aug 17 2015
    California
    I'm debating doing this as well. Please follow up with your before and after results!
    Quote Originally Posted by ducati View Post
    Wouldn't wet sanding and finishing with a UV protectant, plus a film like Lamin-x, be enough to keep the yellowing away for a few years?
    Apr 12 2016
    I already have all of the materials I quoted, plus the DA polisher needed to make quick work of it. Shouldn't be more than 15 or 20 minutes per lens, start to finish. I'll let you know how they turn out.
    Sep 15 2011
    Hilton Head Island
    Alright I finally got my headlight plastic after waiting over a month. About to tackle the job. Any specific brand of paint? And where can I pick it up?
    21' SQ8
    2001 A4 Stage II
