Results 1 to 27 of 27
    Apr 10 2016
    Chicago NW burbs
    Wheel wax/protectant that works on wheels against brakedust buildup?
    Since the Audi produces more brake-dust than my other cars, just wondering if there is a wheel wax or protectant that keeps protecting the wheels for more than 2 weeks?
    Sep 18 2016
    Windsor, CT
    I just applied 2 coats of Dr Beasley's so after I do my summer changeover I'll let you know. Being a milky liquid you spray on and wipe off I'm not too optimistic...we'll see.
    Mar 08 2013
    2013 RS5 Cab / 2015 Q7
    Southern Illinois
    Easiest would be (based on my experience) the Sonax Wheel Rim Shield. Spray on after thorough/proper wheel cleaning & drying, spray on, let it sit, (follow Manuf. suggested dry time is ~ 1hr.) Lasts ~ 4-6 weeks depending on driving/environmental conditions, but YMMV. Longer lasting by far, (again based on my exp.) is a wheel coating like Gyeon Wheel Coating Q2. Super stuff & designed specifically for higher temps generated by braking systems. I have dedicated summer/winters on my RS5, so much easier to apply but fabulous results. Cleaning is much easier & comes cleaner faster & w/ much less effort. Usually only brush The wheel every other time. The wife's Q7 gets the Sonax stuff, brush every time,works well but nothing like the Gyeon. Hope this helps
    Quote Originally Posted by Meadowdale View Post
    Jun 17 2016
    Gaffney/SC/Upstate
    A true wheel coating will help you tremendously. Have the wheels removed, deep cleaned, polished if necessary and then coated. It will last much longer, the true wheel coatings are designed for high temps, and they will be much easier to clean.
    HUMP
    Apr 10 2016
    Chicago NW burbs
    Quote Originally Posted by SC Detailer View Post
    HUMP
    What does qualify as a true wheel coating? Gyeon? Others? DIY possible? I am going ot change to my summer wheels soon. So, I have a good window of opportunity...
    Mar 08 2013
    Southern Illinois
    I coated my brand-new summer wheels prior to installing them. They were factory fresh and had never seen anything other than the inside of the box. When my factory "peelers " Came off I had those professionally stripped,repainted and then coated them as well. All of this was done off of the vehicle, which makes things incredibly easy. The only two true "wheel coatings" I know of at this point are the one I mentioned by Gyeon & (IIRC) 1 by Adams. I believe you can order either through the sponsor of this website, "Detailers Domain" from which I have bought almost every car cleaning product I have. 1st rate sponsor/resource/products, can't go wrong, won't steer U wrong. DIY is definitely possible, not difficult if "new" wheels, that's what I did. Several UTube videos w/good info/details if not familiar w/process.
    Jun 17 2016
    Gaffney/SC/Upstate
    What does qualify as a true wheel coating? Gyeon? Others? DIY possible? I am going to change to my summer wheels soon. So, I have a good window of opportunity...
    Modesta BC-06, BC-09, both are specifically engineered to be applied to wheels. I am sure that Gyeon and the like also have something that you can put on the wheels.
    Sep 23 2016
    So Cal
    Has anyone tried Wheel Guard Max Coat from Chemical Guys?
    Jan 30 2015
    SC
    Quote Originally Posted by auntrout View Post
    I am doing an experiment with this and will update with what I find.
    2 wheels only have a coat of Chemical Guys wheel guard, the other 2 have a coat of the wheel guard and a coat of Sonax PNS on them.
    The wheels were prepped before I put on the wax/sonax.
    Jan 30 2015
    SC
    Quote Originally Posted by Johnson View Post
    So the Sonax definitely outperformed the Chemical Guys wheel guard. It's hard to say if there was a difference in shine between the two but as far as ease of cleaning and water beading, the Sonax was the clear winner.
    2014 S4 Prestige Monsoon Gray DSG / EPL ECU Tune/ EPL TCU Tune / 183mm Fluidampr / CTS 57mm / MercRacing HX / Autotech HPFP upgrade / AWE track 102mm / Modified stock airbox / aFe Pro Dry S / 034 transmission mount insert / 034 rear subframe inserts / CR-15 / H&R OE Sports w/ Bilstein B8 dampers / S5 Rotors / Michelin Pilot Sport 4S
    Mar 08 2013
    Southern Illinois
    Now it will ~ the duration/length of time B 4 U re-coat the wheels. Did U use the Sonax "PNS" or the Sonax "Wheel Rim Shield"?
    Deactivated Four Rings
    Jun 23 2011
    Carbon Collective Platinum wheel sealant. I just put it on some wheels and waiting to see, but I have a bunch of friends running it and they love it. It lasts close to 2 years and it not bad to apply at all. Use CHRISLANE10 at checkout and I think you will get a 10% discount.
    Senior Member Two Rings niedzial1983's Avatar
    Jun 05 2016
    surrey, uk
    Im having my wheels striped and powder coated. I have a bottle of c5 with had many recommendations from forum members , i will be trying
    Sent from my SM-G920F using Tapatalk
    Jan 30 2015
    SC
    Quote Originally Posted by ICU2 View Post
    I used PNS
    Sep 23 2016
    So Cal
    Thanks for the results.
    Dec 27 2015
    Was this the Sonax product you were referencing?
    https://www.autogeek.net/sonax-polymer-net-shield.html
    Aug 06 2012
    Parker, CO
    I use Top Coat F11. Only need a car duster to clear the wheels
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Established Member Two Rings joe biker's Avatar
    Sep 11 2016
    vero beach,florida
    Quote Originally Posted by treginginco View Post
    Second the Top Coat F11
    Jun 17 2017
    Aldie, VA
    I ceramic coat my wheels. I’ve used Opti-coat gloss on my summer and winter M5 wheels (powder coated) and recently used Cquartz UK on my Audi wheels that had been neglected for some time. The Audi wheels needed a very deep clean with Meg’s Wheel Brightener (acid) and Iron-X a few times with lots of scrubbing and rinsing. BMW pads are as bad as Audi pads and on all of my wheels, they wipe right off now. I usually just use regular car shampoo to wash them, no wheel cleaner needed. Now that the pollen is starting to come on strong, I’ll probably just do foam baths and pressure washer rinse for maintenance washes for a few weeks.
    Jan 21 2014
    GA
    I use McKees spray wheel sealant. It protects my rims from dust and dirt.
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Me too. Works pretty good. And very easy to apply.
    Jan 03 2018
    Torrance, SoCal
    Ceramic Akebono Pads!!! Life-changing for brake dust! But yea, I have the Modesta on one of the cars, and it's great.
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Quote Originally Posted by SkyparkPT View Post
    I'm definitely using those when I need new pads.
    Feb 02 2017
    Beaverton, OR
    Quote Originally Posted by BeerBrent View Post
    Mine are hopefully going on this weekend with the new rotors.
    Jan 03 2018
    Torrance, SoCal
    Enjoy! Coat the wheels, and it's easy-street for quite some time
    Quote Originally Posted by chip_ View Post
    Nov 06 2017
    Iowa
    I have pretty good luck cleaning the wheels, and then just spraying detailing spray over the top and not wiping it off. This also works with quick spray wax, but you have to wipe it off.
    Both are great products.
    Another to check out is Ceramic Pro "Wheel and Caliper"
    EcoLuxuryDetail.com
    6-Speed, Neuspeed Chip, Heat Shield, 034 Intake, Euro Jet PCV, 3" Magnaflow, Test pipe, Sport Suspension, RS4 Sway, Snub mount, Apexi super ground, K&N, RS4 Pedals, Podi, Hawk HPS, Super Blue Fluid, Chrome Mirrors, Clear cornered, Laminx, Debadged, Ziza Led, Xexon Interior, Alcantara boot, Infinity 1000W 12", painted markers, VAG's 19" A8 12 Spoke, 10 & 15mm Spacers
