Results 1 to 11 of 11
    Aug 08 2016
    San Diego
    Cabriolet Roof Problem
    Hi guys!
    I've been trying to figure this out without posting a new thread, but nothing I've done has worked.
    We had a guy do some work on our 2004 Audi A4 Cabriolet and since then our convertible top no longer works automatically. I can do it manually - but obviously that's not preferable.
    Whenever I pull the switch it says "please close boot" - but the trunk is obviously closed.
    I pulled the codes and I got two:
    00470 - company comfort databus in Single Wire
    000 - -
    02024 - Perform adaptation
    005 - no or incorrect basic setting/adaptation
    I performed the Reset adaptation, which I believe worked (I restarted the car and the code didn't seem to return), but that first code persists. Whenever I pull the switch it's still saying "please close boot"
    Any idea what's up?
    Regarding the guy who did work on our car:
    The back window was falling out and it seems that we got a lot of water that flooded into the car. Our comfort control module was totally corroded. We got a new one and he installed that, dried out the carpeting, and reinstalled it.
    Relevance?
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    The CAN bus for the comfort system is having problems, in failsafe mode. I'd guess that new CCM isn't, or wiring is faulty somewhere.
    Though as far as the trunk bring open i'd imagine that's just a problem with the switch in the latch, or the wiring to it. Unless that's on the comfort bus, then...
    Jan 24 2010
    Paramus,NJ USA
    I would say your single wire mode is directly related to water damage to the wiring in the floor.Did you pull both sides of the carpeting passenger and drivers side???Something tells me you probably have water on the passenger side as well.With the fact that it says boot open.I would say you probably have the wrong module installed.Make sure the part number is the same as the one that came out of the car.
    Ziddy Autowerks
    Senior Member Two Rings f4i-pilot's Avatar
    Feb 22 2016
    Hampton, VA
    Quote Originally Posted by Uhlmanr12 View Post
    Hi guys!
    000 - -
    Any idea what's up?
    Relevance?
    Don't know if its relavent, but my Cabby showed the same "please close boot", check the wiring around the latch, the top will not work if its showing the trunk open. mine became intermittant and it would stop my top in mid process. cleaned the terminal and reconnected, worked ever since
    Aug 08 2016
    San Diego
    I'm trying to communicate with him (the mechanic) to see if he still has pictures of the old CCM we pulled out. I thought we tried to ensure the same model went back in, but it's possible that a slightly different one was put in. I've got a whole host of issues with the car, which pretty much all started around that time - so it could be that we did put in the wrong CCM, or that the wiring wasn't done right. I believe he pulled out both driver and passenger side before replacing, but again, I'll need to check with him to be sure.
    I'm actually not too familiar with what the CAN BUS actually is...does that mean the internal wiring in the CCM? Or the wiring going in to it?
    I'm going to try and pull the trunk apart and do what I can to inspect wiring/clean the terminal. Hopefully that'll fix it.
    I'm going to post the rest of my scan, showing only the areas that threw fault codes, incase it may help shed light:
    Code:
    Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
       Part No: 8E0 820 043 AM
       Component:   A4 Klimaautomat   2731
       Coding: 00100
       Shop #: WSC 00672
       VCID: 6C82CE310F902A57E2D-513C
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
                30-00 - Open or Short to Plus
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  RDW 0517
       Coding: 00011
       Shop #: WSC 00000
       VCID: 35342B551C5AAB9FCD3-4AE0
    1 Fault Found:
    01800 - Light Switch (E1)
                27-00 - Implausible Signal
    Address 0F: Digital Radio        Labels: 8E0-035-593-SIR.lbl
       Part No SW: 8E0 035 593 D    HW:
       Component: SDAR SIRIUS
       Revision:             Serial number: AUZ4Z7E4006326
       Shop #: WSC 00000 000 00000
       VCID: 2A0E0829C0D4F467501-5160
    1 Fault Found:
    02635 - Tuner Not Enabled/Activated
                000 -  -
    Address 15: Airbags        Labels: 8H0-959-655-84.lbl
       Part No: 8H0 959 655 D
       Component: Airbag 8.4EC        0015
       Coding: 0010105
       Shop #: WSC 00672 785 00200
       VCID: 3B203D6D3F7E7DEF3B7-5160
    2 Faults Found:
    01218 - Side Airbag Igniter; Passenger Side (N200)
                001 - Upper Limit Exceeded - Intermittent - MIL ON
    01217 - Side Airbag Igniter; Driver Side (N199)
                001 - Upper Limit Exceeded - MIL ON
    Address 26: Auto Roof        Labels: 8H0-959-255.lbl
       Part No: 8H0 959 255
       Component:  VSG  B6 CABRIO     6389
       VCID: 73B0D54D57AEF5AF237-5160
    2 Faults Found:
    00470 - Company Comfort Databus in Single Wire
                000 -  -
    02024 - Perform Adaptation
                005 - No or Incorrect Basic Setting / Adaptation
    Address 36: Seat Mem. Drvr        Labels: None
       Part No: 8H0 959 760
       Component: Sitzmemory EE H06   0010
       Coding: 00002
       Shop #: WSC 00000
       VCID: 74B2D6515790F2973AD-4B1E
    2 Faults Found:
    01317 - Control Module in Instrument Cluster (J285)
                49-10 - No Communications - Intermittent
    02010 - Left Entry Assistance Control Module (J572)
                79-00 - Please Check Fault Codes
    Address 37: Navigation        Labels: None
       Part No SW: 8H0 035 192 B    HW: 8H0 035 192 B
       Component: RNS-E US        H52 0020
       Revision:      02S    Serial number: AUZBZ7E1700023
       Coding: 0419137
       Shop #: WSC 08057 444 54080
       VCID: 2616FC19D4CCD007749-5160
    9 Faults Found:
    00532 - Supply Voltage B+
                002 - Lower Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 7
                        Fault Frequency: 6
                        Reset counter: 95
                        Time Indication: 0
                        Date: 2006.04.04
                        Time: 18:07:04
                 Freeze Frame:
                        Voltage: 12.70 V
    00446 - Function Limitation due to Under-Voltage
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 21
                        Reset counter: 95
                        Time Indication: 0
                        Date: 2006.04.04
                        Time: 18:07:02
                 Freeze Frame:
                        Voltage: 12.70 V
                        Mileage: 655350 km
                        Count: 65535
                        Clock: 255:255
    02261 - Data Medium
                014 - Defective - Intermittent
                 Freeze Frame:
                        Fault Status: 00101110
                        Fault Priority: 5
                        Fault Frequency: 2
                        Reset counter: 78
                        Time Indication: 0
                        Date: 2014.11.28
                        Time: 12:18:11
                 Freeze Frame:
                        Mileage: 655350 km
                        Count: 2506
                        Clock: 03:00
    00856 - Radio Antenna
                011 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00101011
                        Fault Priority: 5
                        Fault Frequency: 10
                        Reset counter: 89
                        Time Indication: 0
                        Date: 2006.12.04
                        Time: 14:24:10
                 Freeze Frame:
                        Mileage: 655350 km
                        Count: 2206
                        Clock: 07:20
    00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 5
                        Reset counter: 88
                        Time Indication: 0
                        Date: 2006.12.04
                        Time: 14:24:10
                 Freeze Frame:
                        Mileage: 655350 km
                        Count: 2206
                        Clock: 00:10
    00857 - CD Changer Unit (R41)
                004 - No Signal/Communication - Intermittent
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 5
                        Fault Frequency: 3
                        Reset counter: 88
                        Time Indication: 0
                        Date: 2006.01.20
                        Time: 12:50:40
    00466 - Control Module for Steering Column Electronics (J527)
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 65
                        Time Indication: 0
                        Date: 2004.06.22
                        Time: 00:14:54
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 65
                        Time Indication: 0
                        Date: 2004.06.22
                        Time: 00:14:49
    01316 - ABS Control Module
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 33
                        Reset counter: 95
                        Time Indication: 0
                        Date: 2005.05.12
                        Time: 19:32:14
                 Freeze Frame:
                        Bin. Bits:     0000
                        Mileage: 655350 km
                        Count: 1512
                        Clock: 14:24
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
       Part No: 8E0 959 433 BB
       Component: Komfortgerát T7B    1311
       Coding: 11788
       Shop #: WSC 63351
       VCID: 72BED0492DB4FCA7281-4AE0
    9 Faults Found:
    01134 - Alarm Horn (H12)
                49-00 - No Communications
    00962 - Alarm via. Tilt Sensor
                35-00 -  -
    01368 - Alarm triggered by Luggage Compartment Switch
                35-00 -  -
    01374 - Alarm triggered by Terminal 15
                35-00 -  -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
                35-00 -  -
    01572 - Alarm triggered by Door Contact Switch; Passenger Side
                35-00 -  -
    01366 - Opened Due to Crash Signal
                35-00 -  -
    01333 - Door Control Module; Rear Left (J388)
                80-10 - Single-Wire Operation - Intermittent
    01334 - Door Control Module; Rear Right (J389)
    Address 56: Radio        Labels: None
       Coding: 0419137
    9 Faults Found:
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 6
                        Reset counter: 95
                        Time Indication: 0
                        Date: 2006.04.04
                        Time: 18:07:04
                 Freeze Frame:
                        Voltage: 12.70 V
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 21
                        Reset counter: 95
                        Time Indication: 0
                        Date: 2006.04.04
                        Time: 18:07:02
                 Freeze Frame:
                        Voltage: 12.70 V
                        Mileage: 655350 km
                        Count: 65535
                        Clock: 255:255
    02261 - Data Medium
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 2
                        Reset counter: 78
                        Time Indication: 0
                        Date: 2014.11.28
                        Time: 12:18:11
                 Freeze Frame:
                        Mileage: 655350 km
                        Count: 2506
                        Clock: 03:00
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 10
                        Reset counter: 89
                        Time Indication: 0
                        Date: 2006.12.04
                        Time: 14:24:10
                 Freeze Frame:
                        Mileage: 655350 km
                        Count: 2206
                        Clock: 07:20
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 5
                        Reset counter: 88
                        Time Indication: 0
                        Date: 2006.12.04
                        Time: 14:24:10
                 Freeze Frame:
                        Mileage: 655350 km
                        Count: 2206
                        Clock: 00:10
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 3
                        Reset counter: 88
                        Time Indication: 0
                        Date: 2006.01.20
                        Time: 12:50:40
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 65
                        Time Indication: 0
                        Date: 2004.06.22
                        Time: 00:14:54
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 65
                        Time Indication: 0
                        Date: 2004.06.22
                        Time: 00:14:49
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 33
                        Reset counter: 95
                        Time Indication: 0
                        Date: 2005.05.12
                        Time: 19:32:14
                 Freeze Frame:
                        Bin. Bits:     0000
                        Mileage: 655350 km
                        Count: 1512
                        Clock: 14:24
    Address 63: Entry Assist,D        Labels: None
       Part No: 8H0 959 760 A
       Component: EasyEntry F M H13   0010
       Coding: 00006
       Shop #: WSC 00065
       VCID: 35342B551C6AAB9FCD3-4B1E
    1 Fault Found:
    Address 73: Entry Assist, P        Labels: None
       Component: EasyEntry BF  H13   0010
       Coding: 00005
       Shop #: WSC 00065
    1 Fault Found:
    End----------(Elapsed Time: 06:58, VBatt start/end: 12.3V/12.3V)-----------
    Aug 08 2016
    San Diego
    OK!! Update, finally. The mechanic finally got back to me and says that he's pretty sure he installed the correct part and that he definitely took out all the carpeting and dried out both the passenger and driver side.
    I used vagcom, though, and it looks like the CCM that was installed may be the wrong number. In my car, I have 8EO 959 433 BB.
    A quick internet search indicates that it should work on my 05 A4, B6 body...
    When I called Audi, though, they said the correct part number is 8H0 959 433L. I also verified with a realoem search. Edit: Seems that the correct part number can't be had for anything less than $500 - see why he may have gone with a different model.
    I have found no problems with wiring in the trunk itself.
    Do we think that CCM part # may be behind all these problems? I was doing some more research on all the different error codes I have, and they pretty much all seem to come back to electrics and ross tech indicates checking wiring.
    I think my next step will be pulling the carpet up and looking at the CCM and the wiring connected to it. If that's not corroded though...
    Aug 08 2016
    San Diego
    Alright, managed to pull the CCM out today and have a look at it. None of the wires seem corroded, however the connectors that plug into the CCM itself definitely had some corrosion. I went at it for a bit with a wire brush and cleaned them up before putting everything back in and reattaching the battery (was considering messing with airbag too, but ran out of time)
    I drove the car home and then later tonight hooked up VagCom and got a new scan. There are defintely way fewer fault codes than there used to be - specifically reduction(s) or elimination of fault codes in addresses 36,37,46,56,63, and 73. There's a new one in address 3, possibly unrelated? (EDIT: Definitely seems related) The roof code, though, is still there. I'll post the full scan beneath.
    Again, when I had it out I verified that the 8EO 959 433 BB CCM is installed in my car. The 8E is the chassis for an A4/B6 of my year - but not the cabriolet (which is what I have). I'm leaning more towards thinking that the incorrect CCM is responsible for the roof not working. But would it explain all the other fault codes?
    Code:
    Mileage: 127560km-79262miles
    Address 01: Engine        Labels: 06C-909-559-ASN.lbl
       Part No SW: 8E1 909 559 B    HW: 8E0 909 059 A
       Component: 3.0L V6/5V      G   0030
       Revision: 00000000    Serial number: AUX6Z0D0465580
       Coding: 0013754
       VCID: 35342B55195AAB9FCEF-5160
    1 Fault Found:
    18010 - Power Supply Terminal 30
                P1602 - 002 - Voltage too Low - Intermittent
    Readiness: 0000 0000
    Address 02: Auto Trans        Labels: 01V-927-156.lbl
       Part No: 8E0 927 156 AB
       Component: AG5 01V 3.0l5VT USA 0505
       Coding: 0001002
       VCID: 6E86C4393C8CD847CF5-5160
    No fault code found.
    Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
       Part No: 8E0 614 517 A
       Component: ABS/ESP allrad      4529
       Coding: 04497
       Shop #: WSC 00672
       VCID: 2616FC19D1FCD007775-51A8
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
                35-10 -  -  - Intermittent
       Coding: 00100
       Shop #: WSC 00672
       VCID: 6C82CE310F902A57E11-513C
    1 Fault Found:
       Coding: 00011
       Shop #: WSC 00000
       VCID: 35342B551C5AAB9FCEF-4AE0
    1 Fault Found:
       VCID: 2A0E0829C0D4F46753D-5160
    1 Fault Found:
                000 -  -
       Coding: 0010105
       VCID: 3B203D6D3F7E7DEF38B-5160
    1 Fault Found:
    Address 16: Steering wheel        Labels: 8E0-953-549.lbl
       Part No: 8E0 953 549 N
       Component: Lenksáulenmodul     0611
       Coding: 02041
       Shop #: WSC 00672
       VCID: 3E263479296C68C71F5-4AE0
    Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
       Part No SW: 8H0 920 980 Q    HW: 8H0 920 980 Q
       Component: KOMBI+WFS 3     H12 0020
       Revision: 0020        Serial number: AUX6Z0D0465580
       Coding: 0001231
       Shop #: WSC 08212 444 85874
       VCID: 3D243375216A73DF06F-5160
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8E2.lbl
       Coding: 0001231
       VCID: 73B0D54D57AEF5AF20B-5160
    1 Fault Found:
                000 -  -
       Coding: 00002
       Shop #: WSC 00000
       VCID: 74B2D6515790F297391-4B1E
    1 Fault Found:
                79-10 - Please Check Fault Codes - Intermittent
       Coding: 0419137
       VCID: 2616FC19D4CCD007775-5160
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.clb
       Coding: 11788
       Shop #: WSC 63351
       VCID: 72BED0492DB4FCA72BD-4AE0
       Subsystem 1 - Part No: 8H1959801B
       Component: Tőrsteuer.FS BRM 3020
       Subsystem 2 - Part No: 8H1959802B
       Component: Tőrsteuer.BF BRM 3020
       Component: Tőrsteuer.HL BRM 0002
    4 Faults Found:
                29-10 - Short to Ground - Intermittent
    Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
       Part No: 4Z7 907 357
       Component: dynamische LWR       D09
       Coding: 00070
       Shop #: WSC 00672
       VCID: 045286910730C217091-4B1E
       Coding: 0419137
       Coding: 00006
       Shop #: WSC 00065
       VCID: 35342B551C6AAB9FCEF-4B1E
       Coding: 00005
       Shop #: WSC 00065
    End----------(Elapsed Time: 06:37, VBatt start/end: 12.3V/12.3V)-----------
    Aug 08 2016
    San Diego
    Any advice?
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    That might be a clue, considering the car is a coupe.
    Aug 08 2016
    San Diego
    Quote Originally Posted by Gin+ View Post
    Gin+, you're absolutely right - I didn't even realize that. I'm afraid my problems are rooted in having the wrong CCM installed...
    Guess I need to go shopping
    Aug 08 2016
    San Diego
    Ok, so I swapped out the CCM for the correct model (as verified with the dealership) - still pulling up a bunch of codes. Despite that, the roof now works. I love that it works, the original problem is fixed - but now I'm wondering what the heck is throwing all these codes.
    Most of them seem to indicate its with wiring - which I cleaned off the contacts and replaced the CCM, so I was hoping that would take care of it.
    Code:
    Mileage: 129000km-80156mi   Repair Order:
    Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
              63 65 67 73 75 76 77
    VIN: WAUDT48H35K017507   Mileage: 129000km-80156miles
       Coding: 0013754
       Coding: 0001002
       Coding: 04497
       Shop #: WSC 00672
    No Faults Found
      or DTCs not supported by controller
      or a communication error occurred
       Coding: 00100
       Shop #: WSC 00672
    1 Fault Found:
       Coding: 00011
       Shop #: WSC 00000
    2 Faults Found:
    01503 - Bulb for 3rd Brake Light (M25)
                57-00 - Electric Circuit Failure
    1 Fault Found:
                000 -  -
       Coding: 0010105
    1 Fault Found:
       Coding: 02041
       Shop #: WSC 00672
       Coding: 0001231
       Coding: 0001231
    2 Faults Found:
    02000 - Switch Position
                000 -  -
       Coding: 00002
       Shop #: WSC 00000
       Coding: 0419137
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 96
                        Time Indication: 0
                        Date: 2017.06.06
                        Time: 08:10:31
                 Freeze Frame:
                        Mileage: 655350 km
                        Count: 606
                        Clock: 10:46
       Part No: 8H0 959 433 L
       Component: Komfortgerát T7B    5542
       Coding: 06666
       Shop #: WSC 00000
       VCID: 3D243375246A73DF06F-4AE0
       Subsystem 3 - Part No: 8H0959801A
       Subsystem 4 - Part No: 8H0959802A
       Component: Tőrsteuer.HR BRM 0002
    2 Faults Found:
       Coding: 00070
       Shop #: WSC 00672
       Coding: 0419137
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 96
                        Time Indication: 0
                        Date: 2017.06.06
                        Time: 08:10:31
                 Freeze Frame:
                        Mileage: 655350 km
                        Count: 606
                        Clock: 10:46
       Coding: 00006
       Shop #: WSC 00065
       Coding: 00005
       Shop #: WSC 00065
    End----------(Elapsed Time: 06:36, VBatt start/end: 12.5V/12.3V)-----------
