I've got a b7 w 150k miles that's misfiring on one bank (driver side). Car runs fine in general and idles fine, but misfires / gets flashing CEL at high rpm- 3500+. just about all cylinders on that bank misfire- at different times i get a different mix of cylinders misfiring, but all have misfired at some point.
i'm also getting a p1071, running lean on the other cylinder bank.
Here's what i've done-
- i've swapped the coils from one bank to the other. the problem stays in the same cylinder bank (as i did this, i noticed a bit of oil higher up on the coils coming from a couple of the problem cylinders)
- i replaced the maf
the spark plugs are about 6 months old.
i also hear a ticking right over the airbox.
any help appreciated.
