For all engine builders out there, you may know that I was in progress of building my engine. I have finally finished the project and I cannot wait to do it again on future motors. I will have to update my thread with more photos of the build process. When measuring my bores without the torque plate, I noticed that the numbers were way off. With the torque plate, most of my measurements were within .0001-.0002 of each other which is damn near perfect. Here is an example cylinder showing how much a cylinder head can distort a bore, expanding it at the top when all the bolts or studs are torqued down.
CYLINDER #1. It was measured in six places, three of which were executed longitudinally and the other three 90 degrees in the other direction. The numbers were negative because when the head bolts are torqued down the block actually stretches to the final bore size. Going from top to bottom:
[LONGITUDINALLY]
-.0007
-.0003
-.0001
[ACROSS 90*]
-.0015
-.001
-.0004
This can give you an idea of how much the head pulls on the cylinder block, especially a puny 4 cylinder block like ours. Noticing some things: the pull on the block is greater across the block then longitudinally (data across multiple cylinders confirms this). The final bore size was meant to be 3.268 (with the torque plate on almost all of these values were spot on to the final bore size), and in the place of largest distortion without the torque plate it was .0015". Though it may not seem like much, it is definitely something to think about.
