Results 1 to 3 of 3
Thread: Help! P0354
    Established Member Two Rings FergusonHD's Avatar
    Aug 16 2013
    Miami
    Help! P0354
    So I installed new r8 coilpacks and ngk plugs about a week ago and today I go to tune my car and I get this P0354 code after driving for a couple minutes; seeing as my plugs and packs are brand new this would mean I would have a faulty harness? Or do you think I left something loose or did something wrong when I changed my plugs/packs?
    I'm going to switch my coil pack from cylinder D to cylinder C or whichever to make sure it's not a coil pack problem later when I get off work
    May 20 2010
    Could still be the coil pack. Good idea to move it around to see if the problem follows it.
    Veteran Member Three Rings bluefox280's Avatar
    Jul 03 2005
    Broomfield, CO
    * Audi DTC 16738 (P0354) - Ignition Coil (D) Cylinder 4 Primary / Secondary Circuit Malfunction
    The ECU is seeing an issue with the ignition coil on cylinder #4.
    As suggested by Audibot, swap the ignition coil from a different cylinder and see if the same fault returns, or "moves" with the swapped coil.
    - Erik
    PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
