Anyone have experience with one of these? Put in my AMS Alpha Heat Exchanger last night, but when I do the vacuum test I appear to have a slow leak somewhere since the vacuum won't hold and very very slowly returns to atmospheric pressure. Is there an easy way to test out different areas of the coolant system with this device (like soapy water etc...) or should I just fill it with coolant and see if I can find a drip anywhere? I guess it's possible it was there before the install also since my coolant level was slightly below minimum but I haven't found any evidence of a leak prior to this. TIA
Sent from my SM-G935V using Crapatalk
