Results 1 to 40 of 51
    Jan 07 2006
    NNJ
    STFT still 25+....need help diagnosing
    A while back I posted about having a P0171 which I assumed was related to a vacuum leak since I found one. So I started to tear into the system and found a bunch of leaks including the secondary O2 sensor nonfouler. I ordered replacement parts and basically replaced all the check valves the suction pump, breather and PCV.
    I just went out for a ride and noticed the car seemed to be stumbling a little and when I checked the STFT it is still reading in the upper 20's but no code thrown or pending yet. Vacuum is still reporting at over 20mmHg via Torque at idle. So I am pretty sure I got all the leaks in the vac system, is there somewhere else I should look? Searches suggest logging MAF which I think I can do in torque but is that sufficient for someone to help diagnose? Any other sensors to log? Other places to check for leaks? Starting to think it isn't a leak since when I get on it the STFT doesn't go down as the intake should be positive and then leak out not in. Right?
    Work done since initial code.
    New air filter
    Changed oil/filter
    Replaced oil level sensor
    Replaced elbow from SAI to hard pipe
    Replaced all check valves
    Replaced breather
    Replaced PCV
    Cleaned MAF
    New Nonfouler (reinstalled old O2's)
    New turbo to cat gasket
    Jan 07 2006
    NNJ
    Thought of one other thing....I was getting a P0012 for quite a while and ended up replacing the solenoid on the CCT just before these other codes started coming up. I kind of mentioned it in the first thread I linked but didn't say why I changed it. Not sure if this code is somehow related even though changing that did eliminate that code, but then got the P0170.
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    Boost/vacuum gauge? Don't trust torque for your boost or vacuum readings.
    Jan 07 2006
    NNJ
    No stand alone gauge. I thought Torques vac reading was supposed to be accurate but boost was questionable since it is calculated rather than measured. Is that not correct?
    Jan 12 2014
    Fargo, ND
    I've never even gotten it remotely close on my car, no matter what offset I put in. I only use torque to clear codes, never had good results in terms of logging.
    Every B5 should have a boost/vacuum gauge, modded or not.
    Jan 07 2006
    NNJ
    I do have an old laptop with VCDS Lite but the battery barely holds a charge so I have only used it in the garage, not sure if I could do any logs with it. And unfortunately my cable is serial and that is the only machine that has one. But if I get that working, is there a vacuum gauge that the computer sees? I can look to get a gauge but not sure how quick I can find one. Maybe I can snag something from work.
    Jan 12 2014
    Fargo, ND
    What year car? If you're wideband you should be able to get a number off of the map sensor. Narrowband, you're out of luck and need a gauge.
    I recommend getting a gauge regardless.
    Jan 07 2006
    NNJ
    2001.5 AWM engine code
    Jan 12 2014
    Fargo, ND
    Maybe the map doesn't read vacuum, only boost, I'm not sure as I'm DBC.
    Orange County, CA
    You only replaced the solenoid on the CCT? Interesting... I replaced my CCT w/ a new OEM one when I had similar codes and it fixed the issue.
    The aftermarket POS CCT that was in the car when I bought it and the screen fell off it and it threw the codes since the CCT was not working anymore.
    B5 Parts For Sale
    Jan 07 2006
    NNJ
    Yeah just the solenoid, figured it was worth a shot. When I took the old one off I put 12V across it and while it actuated it was weak. The new one made a solid click on activation.
    Jun 30 2008
    Erie, Pennsylvania
    1.8T's do not have an actual vacuum (MAP) sensor at all. The 2000+ cars just have a charge air pressure sensor (AKA: boost sensor). The sensor is located directly on the intercooler, so it cannot possibly see manifold vacuum. Like...ever.
    The only way you can get a vacuum reading is by connecting your own vacuum gauge to the manifold.
    1. Can you find out your long term trims (LTFT) - both the additive and multiplicative (idle and part throttle)? That would be very helpful in determining where your problem may be.
    2. Have you logged the MAF value? Does it run good enough to do a log on a 3rd gear pull, wide open throttle, from 2k-6k RPM?
    Jan 07 2006
    NNJ
    I have a gauge I will hook up tonight and get some vac readings. Car does run but seems to be a bit rough, not sure if I would feel comfortable doing a wide open throttle run but certainly could do 2-6k run. Haven't logged anything and will have to see if my VCDS Lite laptop even works. I left it charging all day, hopefully I can get a few minutes to collect data. As for the LTFT, it was reporting basically the same as the STFT in Torque but I suspect that is because the battery was drained when I finished working on it. I probably left a door open or something. Anyway I figured that wiped old data out and that was why the values were very close.
    Jan 07 2006
    NNJ
    well I underestimated the ID of the tube I planned to tap into, I think I got the clamps tight enough to make it leak proof but I think I want to get a better fit for driving it around. But since it seemed tight enough I did an idle test. Started it up and got a fair amount of smoke at first...don't think I have ever seen that before. While the SAI was on the vac was only 13-15"Hg, and after it shut off and the idle settled it went to about 18. So I guess I must still have a leak somewhere...thoughts?
    After I get the larger T I hope to be able to log a 3rd gear pull and post up. But if you think I should do something else first let me know.
    Jan 07 2006
    NNJ
    No one had the right size parts locally so I tried my luck. Idle vac was not as good this time, more like 15-16 but as I was engine braking while coasting down a small hill I saw a high of 26. During my drive I saw a max boost level of 12psi. After doing this pull I ended up with the following codes: 17536 - Fuel Trim; Bank 1 (Mult): System too Lean P1128 - 35-00; 17544 - P1136 - 35-00. Idle was horrendous and it smelled like crap, mostly WOT felt way smoother than expected but since I was on a rural road I couldn't quite complete the pull I thought I killed it around 5k but looks like the data stopped at 4k. For some reason I can't post attachements so what can I do with the log I have to get some feedback?
    Let me know if this works: https://drive.google.com/open?id=0B5...VdNb3BWejhPOGc
    Jan 07 2006
    NNJ
    I went back out but this time made sure my APR tune was enabled. It felt pretty good, this time the log goes to ~5k and you can see I laid off and shifted. Let me know what the consensus is since I really have no idea what it means, other than the MAF looks like it stumbled at one point in this pull.
    https://drive.google.com/open?id=0B5...nZoMUtGaHBqOUk
    Veteran Member Four Rings ActiveMonkey's Avatar
    Jan 27 2006
    C7.5 A6 3.0T Prestige
    Orange County CA
    Depending on how old your upstream O2 Sensor is I would replace it. Mine had ~128k miles and out of nowhere the car would start knocking under WOT, then under part throttle and then anytime I would create more the 4psi. Point of this is that your upstream O2 Sensor is also your A/F sensor and if it is old or dirty it can cause gremlins and make you chase ghosts. For a while no codes, then a code for "too lean" then P0133 and P0136. I swapped out my upstream O2 and POOF! runs flawlessly.
    Best of luck.
    Current: 2016 Audi A6 3.0t Stage 2+
    Old: 2000 Audi S4 Stage 3 - SOLD | 2000 Audi S4 Stage 3 - Deceased | 2002 Audi S4 Avant - SOLD | 2000 Audi S4 - SOLD | 2003 Audi A4 - SOLD | 2001 Audi A4 Quattro - Deceased | 1998.5 Audi A4 Quattro 5MT - SOLD
    Jun 30 2008
    Erie, Pennsylvania
    I think I'm going to second the O2 sensor. The MAF numbers look great. 5k revs at full load shows 160 g/s. That equates to 200hp, which is exactly what it should be making on a chip tune.
    Assuming your coolant temperature sensor is reading correctly (~90-95C in VCDS at operating temp), then I think your O2 sensor might be lying. Reporting a lean condition that doesn't exist and thus the ECU is dumping in way too much fuel. I would proceed as follows:
    - Check that coolant temp reading is accurate (as reported by the ECU via VCDS or VCDS Lite)
    - After you warm it up and do a good rip, shut the engine off quickly and see what the spark plugs look like. If it is actually lean, they will be light colored. If the O2 sensor is lying, they will be black.
    I would probably proceed with O2 sensor replacement if temp sensor is accurate and plugs are black. There is some further testing you can do on the sensor, but I think you need more than VDCS Lite. This is a 2001, so the primary O2 sensor is a wideband sensor. They have a lot of control over fuel mixture, so it makes good sense that this may be your problem. It will be more expensive than your average sensor, though. About $100. Looks like FCP has a good price on these:
    https://www.fcpeuro.com/products/aud...n-sensor-17351
    If you don't feel confident, I believe I have a known good AWM primary sensor laying around. I changed mine when chasing an ignition timing issue. The new one didn't make a difference, so I'm pretty certain the old one still has some good life left in it. I could send it to you to try if you want.
    Jan 07 2006
    NNJ
    Thanks again for all the help...it is much appreciated. First thing I did when backing out of the garage was to clear the code and immediately the idle went pretty smooth. At least as smooth as it can be with 280k. Not sure why when I previously cleared codes this never happened. Anyway, I wasn't sure how to confirm the temp readings but from what I recall there are two temp senders, one is for the dash the other is for the ECU. So what I did was confirm that when the dash was reading mid point the ECU reported temp was around 90C. I then got on it coming up a hill and it felt good to me, then had to drive about 1/2 mile through the neighborhood before I could shut her down. I pulled the plug and it is light colored on the electrode dark by the threads as you can see in the picture. But when you mentioned dark deposits I remembered that when I removed the cat I noticed the primary O2 was dark. So I pulled that and took a picture of its current condition.
    As a side note, are those vac readings normal? just wondering if something else is still leaking since the plug is light in color. Walky...appreciate the offer but I am anxious to get this thing running again. Thanks for the link though, found my local AAP has it n stock and with a code is slightly cheaper. So if we think it might be that I could throw it in and see. But plug color has me concerned now.
    Jun 30 2008
    Erie, Pennsylvania
    Plug color looks ok. The fact that clearing the codes (which clears learned fuel trims) made it run BETTER, means that its learned adjustments were wrong. This is a pretty good indicator of a faulty oxygen sensor.
    Generally when you have a car with a bad MAF or a bunch of leaks, it is exactly the other way around. The car will be running sort of OK, then you clear the codes and it will barely run. This is because the heavy adjustments were the only thing keeping the mixture right.
    I would feel pretty good about putting a fresh oxygen sensor in it. Even if that is not your entire issue, the car does have tons of miles on it, so it wouldn't be wasted money.
    Jan 07 2006
    NNJ
    Txs for the advice...I will try to pick one up tonight. I hope this works because the wife is getting tired of me working on it and spending money on it. As you said it has lots of miles so she thinks I should just get something new. But I like the challenge, just wish I had your knowledge.
    As for the vac readings, is 15-18 OK at idle and mid 20's with engine braking?
    Jan 07 2006
    NNJ
    Well I was excited for about five minutes. I put the new sensor in started it up and idle was smooth. Went for a quick drive and it felt strong, I saw 15psi or so of boost. Then I get home and notice that the idle is stumbling again, used Torque to pull pending code P0170. Clearing the code evened out the idle again. One other oddity was a noise it made when I shut it off, almost like something was powering down or relieving pressure internally. Any thoughts?
    Jun 30 2008
    Erie, Pennsylvania
    Pressure sound is probably your Air conditioning. Normal.
    I'm sorry the sensor didn't fix it for you. I'm surprised. But at least we can 100% trust the primary sensor data now.
    I would like to see LTFT data from VCDS. And a datalog of Actual vs Target AFR on a 3rd gear pull.
    That will help us make more sense of this. LTFT is block 032 which is not reachable by VCDS Lite unless registered or otherwise unlocked. Actual and Target AFR are block 031, also unreachable by Lite.
    Jan 07 2006
    NNJ
    That presents a problem...I don't have a registered version. Never got it because a buddy had the full VCDS but he has since moved. I will have​ to check around and see if anyone local can help me out.
    Any chance info from torque would be useful?
    Jan 12 2014
    Fargo, ND
    Actually, believe it or not, but I think Torque can measure LTFT and STFT. Don't quote me on that, can't remember.
    Dec 10 2013
    Borden, Ontario, Canada
    Quote Originally Posted by Rodgman15 View Post
    I have it and it can
    Sent from my SM-G935W8 using Tapatalk
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Jan 12 2014
    Fargo, ND
    Quote Originally Posted by Bordom View Post
    Good deal, I have it on the tablet that's integrated into my dash, but I literally only using it for clearing my EVAP code when the CEL comes on lol.
    It may not be as in depth as VCDS (which you should still try to track down), but maybe it'll provide a bit of insight.
    Jan 07 2006
    NNJ
    So I took it out after clearing the codes, today it didn't feel as smooth under power and just like before the idle got wonky after driving. The first pull I also logged RPM but since there is only one scale most data was lost. The second pull starts with me slowing down in third to around 2k RPM then WOT to about 5k. The graph shows a stumble near the end, maybe I laid off a bit because I could feel it miss. Anyway let me know if this has enough detail to be useful.
    https://drive.google.com/file/d/0B5g...w?usp=drivesdk
    Jan 07 2006
    NNJ
    Sorry just realized I could log to a CSV file so I went out again. Log starts in first then I get to third and did a pull. It felt pretty good but in at least one pull it stumbled just under 5k.
    Jan 07 2006
    NNJ
    Sorry...I was on mobile last night and didn't realize those links wouldn't open in a spreadsheet, so here are new links. Really not sure what to think of this data, one shows the rpm going from 845 to 5016 in the next reading. Makes no sense, even at idle if I hit the throttle I don't think it would spin up that fast. Anyway if someone sees something telling please enlighten me.
    https://drive.google.com/open?id=0B5...0M3MV84V2thSmM
    https://drive.google.com/open?id=0B5...kswT04xZXVPMlU
    Jun 30 2008
    Erie, Pennsylvania
    These logs aren't showing both long term trims. There is an idle trim and a part throttle trim. It is hard to pinpoint the problem without those details.
    To gather that data, you will need VCDS and you will need to put some miles on the car without clearing the codes so it can learn. Probably 2 trips where it warms all the way up would be sufficient. Trims are in block 032. Just read them after it learns. No need to log them.
    From your logs, it looks like it's hitting pretty good AFR's. 14.7 and dipping 10.8 at WOT. Pretty much what my AWM does. Coolant temp looks good. Timing looks good. MAF values are wacky (not shown in g/s) so I'm not sure on those.
    Jan 07 2006
    NNJ
    Ok txs I will run it tonight and hopefully get to to a full VCDS tomorrow night. From an earlier post you also suggested block 31 so I plan on grabbing that too since getting to the full version won't be as easy as using mine. So with that said anything else I should get?
    Jun 30 2008
    Erie, Pennsylvania
    Would like to see a log of the MAF with Throttle position and RPM. Then another log with block 031 along with RPM. If you can do all those together, that's great. I try not to log more than 2 blocks at a time because it slows down too much. Would also like to see timing retard (knock control).
    Then grab the trims from 032. Engine does not need to be running for that. But codes must not be cleared for several miles/trips before you view them.
    Jan 07 2006
    NNJ
    So tonight on the way over to do some logging the CEL came on. Before we started logging the code showing was:
    P1128 - 35-00 - System too Lean
    Then after doing some pulls and idling for about 15 minutes the following codes were showing:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-00 -
    16687 - Cylinder 3
    P0303 - 35-00 - Misfire Detected
    17519 - Oxygen (Lambda) Sensor Regulation: Bank 1
    P1111 - 35-00 - System too Lean
    16688 - Cylinder 4
    P0304 - 35-00 - Misfire Detected
    Again the idle felt like crap but the pulls felt relatively smooth though tonight it seemed to feel a little weaker than some other recent pulls. Log can be found here and here. Any thoughts?
    Jun 30 2008
    Erie, Pennsylvania
    Wow. The idle trim is too high, but the part throttle is pinned. One would expect the MAF to be shot, but the numbers look fine for stock power. The numbers from the Wideband o2 sensor don't look normal, though. An AWM should be pretty good at keeping the actual matching the request. Yours is running richer than target almost all the time, and it seems oddly locked at .727 much of the time.
    Some questions:
    - When did it start doing this?
    - Has the car been modified (chip tune of any kind, any go-faster parts in the engine bay, etc)?
    - What is the deal with the "non fouler", exactly? All the details on that, please.
    Possibilities I'm thinking of:
    - Injector size is not correct
    - Fuel pressure is not correct
    - O2 sensor(s) are not getting an accurate read for some reason
    - Software has been modified.
    Jan 07 2006
    NNJ
    Car has 280k on it and has an APR chip since about 10k, so yes programming is different but this is not a new change. At around 150k the stock cat died and we installed a high flow cat, the only way to get the readiness to come up clear (ie not below threshold error) was to install the non fouler. So while I changed the non fouler recently this was because the old one rusted out and I had a leak. Is the secondary O2 only for cat effectiveness?
    So recent history is this...I needed to get the vehicle inspected so I finally did something about the CEL I was getting for the CCT (P0012). I picked up a new CCT but only swapped in the solenoid, this eliminated that code, but when I was trying to get my readiness to come up I got P0170 which I figured was a vac leak. Poking around in there I found several leaks and decided to replace all the parts mentioned above. Prior to this I don't recall having this rough idle but I do remember thinking the car stunk and a buddy driving behind me said it was obnoxious. After changing the parts that is when the idle was most pronounced. Could I have gotten a bad check valve or inadvertantly put one in backwards? I did check them by blowing into them but I can't generate the pressure or vacuum the engine can. I did keep the stock ones since they passed the blow test, would it make sense to put those back in? One other question, my MAF sensor has a spot for a resistor but none is connected or in the housing...are all sensors supposed to have this?
    Jun 30 2008
    Erie, Pennsylvania
    Thanks for the information.
    - Secondary o2 sensor is "mostly" for monitoring the cat. It does have a slight "fine tuning" effect on fuel mixture in some Audi software versions.
    - A check valve is not likely to be your issue. With a 25% multiplicative trim, we are talking a huge correction for tons of air. Not a little vacuum leak.
    Questions:
    - The non fouler: it is installed just on the rear o2 sensor, right?
    - Can you be 100% certain the o2 sensors are in their correct positions? This is critical.
    Jan 07 2006
    NNJ
    Non fouler is only on the rear sensor. Ans I am fairly certain they are in the right spots. The sensor just before the cat has more pins than the rear one. I think it is like 6 vs 3.
    Since this code wasn't coming up before and you think this is a big leak any chance I got a bad part or something that could cause this...like the suction pump? What about the breather I put in,,I had a hell of a time getting the clip in since the o-ring was so tight. Could a damaged o-ring there potentially cause this? Just trying to think what would have caused this shift since the car ran fine before.
    Jan 07 2006
    NNJ
    Not sure what to think here, this morning was the first time I really drove the car for a while. This morning I cleared the codes and started my 40 mile commute, I noticed that the idle was smooth the entire time so when I got to work I checked the codes and there is a pending P0171 but the STFT is reading 0.0 with the LTFT saying 5.5. To further confuse things I noticed my display is saying I averaged around 20.5mpg, normally this would be around 27. So it is definitely dumping more fuel but now that the STFT is 0.0 and a relatively low 5.5 for LTFT I am not sure why it would be dumping that much.
