Results 1 to 6 of 6
    Veteran Member Three Rings 1S32K16's Avatar
    Jul 07 2016
    Rotational squeaking when driving/slowing at low speeds
    I just had my new wheels installed on Saturday and now I get this rotational squeak at low speeds and when braking. I haven't had a chance to have someone else drive the car to see where it is coming from. But wanted to see if anyone else experienced this. The wheels are using metal hub rings.
    Pic for attention
    2019 Quantum Gray SQ5 with black optic package, 20% Rayno Ceramic tint, TAG Motorsports Painted Front Reflectors, BMC Air Filter, JB4, 034 Trans Mount, OEM Black Badges, 21’ BC Forged RZ39, Redstar 200cel DP, ODIS factory lowering
    2016 Monsoon Gray S3 with black optic package, Emmanuele design springs, rear sway bar and endlinks, 19' Forgestar CF5's
    May 20 2010
    I would check the dust shields on the brakes to see if they may have gotten bent accidentally on install or removal.
    Jul 07 2016
    Thanks for the tip. I will take a look tonight and see if I notice anything.
    Jul 07 2016
    So the squeaking is still present. Anyone have experience with metal hub rings causing a noise? I don't know why I have a feeling it's the hub rings. My black optic wheels and spacers never made any noise
    Established Member Two Rings Penti's Avatar
    Aug 12 2014
    CA
    I had this issue from about 8k to 15k mi, before I was able to persuade my dealer to replace the brakes. There was a updated pad available, but as they never change pads only, I got new pads and disks front and rear at 15k.
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    Quote Originally Posted by 1S32K16 View Post
    Cheap fix might be to swap out the hub rings...they might be the issue you are hearing.
