Results 1 to 16 of 16
    Jan 15 2017
    B8.5 Taillight Retrofit
    Hello everyone,
    I apologize in advance if this topic has been covered previously, but the only relevant information I found was regarding retrofitting post-facelift tails into B8's.
    Is it at all possible to retrofit B8.5 tails into a B8.5? I have a spare wrecked B8.5 that I'm stripping of usable parts and was considering swapping my halogen tails for the fancy led's
    If only an adapter harness and recoding is needed, would I be able to repin my original wires into the cut off plugs from the salvage B8.5?.
    Veteran Member Four Rings awdconnor's Avatar
    Jun 07 2016
    Portland, Oregon
    you need the trunk lid. the inner tail lights are different. a little more sharp looking.
    [COLOR="#808080"][FONT=System][SIZE=2]2018 Audi S4 P+ | 034 Stage 2 E85 | Airlift 3P | BBS RSii
    Established Member Two Rings MMiklosz's Avatar
    Mar 27 2014
    Berlin, CT USA
    lmk if you find anymore info. i retrofitted my 2010 a4 to b8.5 front end and have been looking at a back swap
    Jan 15 2017
    Ah bummer, the trunk is a bit too mangled to swap over :( Thanks for the information though!
    Oct 13 2015
    2010 Audi A4 Quattro 6 speed manual, 1990 325i E30, 1980 450 SL
    Norcal
    I had found some b8.5 replica ish taillights on eBay that look really good
    Jan 15 2017
    Those look really nice! I'll definitely take a look into them when I get a chance
    Jan 15 2017
    Turns out the B8.5 halogen and LED tails are identical in shape
    and only the connectors are different
    http://imgur.com/a/CY4Ue
    Hopefully the repair manual will have a proper pinout of the cables, so all I will need to do is repin the plugs and be ready to go!
    EDIT: Does anyone have a link to a repair manual for 2013 A4? The one I have for 2011 has different colored wires. Thanks!
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Quote Originally Posted by Reciprocity View Post
    Nope, not that easy. There will be coding involved.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Jan 15 2017
    Is it enough to just flip a toggle to enable LED tails in VCDS or is adaptation coding necessary?
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    I think it's fairly simple IIRC, but mine came with LED tails, so that's just based on the limited info I've seen floating around.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Jan 15 2017
    Gotcha. Thanks for your help everyone! I'll update the thread with more pictures after I complete the swap if anyone wants to do the same.
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    ^There is around 2-3 pages of coding involved. Pretty straight forward really.
    Jan 15 2017
    Turns out this won't be easy. The outside LED tails have 5 cables while stock halogen harness only has 4.
    Jun 05 2009
    Scottsdale Arizona
    I bought the kit from Alex at Europrice.
    Complete kit, no issues at all. Was about 5 hours of work, but very doable if you have mechanical/ electrical skills.
    If not, take it to a dealer, since the retrofit kit is available from Audi as well.
    Jan 15 2017
    I sent an email out to Europrice regarding that 5th cable, hopefully they know what to do with it. The only reason I wanted to swap them since I got the LED tails essentially free, there's no way I'm willing to pay 1300 for new tails haha.
    Jun 05 2009
    Scottsdale Arizona
    You can find the PDF instruction manual for the LED upgrade on the webs
