Results 1 to 9 of 9
    Active Member Four Rings
    Nov 12 2013
    '01 S4 Tip '91 200 20VTQA, '01 A6 2.7TA, VW Rabbit GTI truck.
    SanHo, CA
    K04 Turbo Compressor and Turbine Size Variations
    I purchased a set of CHRA's from a guy on AZ last week and they arrived on my doorstep Saturday. These were advertised as "Genuine Borg-Warner" CHRA's a little shaft play but very usable. He said they were in a set of "Genuine Borg-Warner" K04 turbochargers and would fit any standard Borg K04. I have a set of low mileage Borg K04's I purchased some time ago that ingested some bits of hard crap that dinged up the compressor wheels so a set of "usable" CHRA's would be perfect for these turbos. My dinged up CHRA's have zero shaft play but the fouled up compressors makes them unusable.
    The CHRA's had the promised "minimal shaft play" and looked pretty good. Pulling my old units apart was easy as pie (right, getting the hot side apart was pretty challenging) and everything cleaned up nicely. Unfortunately, the "new" CHRA's have compressor and turbine wheels of much larger diameter. Here's how the dimensions vary:
    My K04's: Compressor, 40/51mm; Turbine, 42/49mm
    Used CHRA's: Compressor, 42/56mm; Turbine, 44/50mm
    The seller is sure his turbos are standard Borg K04's and has sent me pictures of the Borg tag on the compressor housing. I have not seen a pics of the size of the turbo inlets or outlets. He is standing on his "as is" disclaimer and refuses to discuss an equitable return based upon his insistence that he bought Borg CHRA's to replace these and by God, they'll fit Borg-Warner K04 turbos.
    I've got a set of other Borg CHRA's that were given to me with what was thought to be excessive shaft play. They came in the boxes the replacement units from Borg were delivered with. Those match up with my units exactly.
    It has been difficult to find real data on wheel size in the various turbos used on our beloved B5S4 platform other than the RS4 K04 turbos which seems to match up with what I've got in my turbos.
    Now that you're slogged through all that BS, the questions are:
    1. Are my turbos "Real" RS4 K04's?
    2. Are there other size RS4 K04's?
    3. What are the used CHRA's supposed to fit really?
    4. Have I been sold up with river with these CHRA's?
    5. Anybody interested in buying them?
    Here's my compressor housing:
    Here's the Borg turbo label:
    Here's my compressor wheel complete with dings:
    Here's the used compressor wheel:
    Here's the seller's "compressor label":
    Oct 23 2010
    2004 Atlas Gray A4 Avant
    Cranberry TWP, PA
    42/56 4+4 is a 2275 compressor wheel, aka RS6.
    2004 Atlas Gray B6 Avant, built 2.7T w/ BB K24's on E85
    2005 Touareg 4.2 gas guzzling daily
    2002 Triumph Daytona 955i
    1997 BMW M3 Coupe (sold, sad reacts only)
    Apr 07 2011
    Home of the mighty beaver
    I concur. I have the same ones in my housings.
    they require machining to fit.
    If you can find someone to have the work done, its well worth it. Ive got over 10 years/100,000km on mine, and no issues with them still. Very solid combo that served me well.
    I'll rebuy them from you
    Sent from my HTC331ZLVWPP using Audizine mobile app
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    RS6 turbine size also.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    It might be worth sending or getting those housings machined out instead of reselling the CHRA's.
    Senior Member Two Rings milehighkid24's Avatar
    Oct 25 2013
    Nardo Grey B8.5 S4, Casablanca White B5 S4
    Scottsdale, AZ
    Those are RS6 sized turbines. Are they from SRM? I ran into the same sizing issue when replacing my turbos last summer because my car has K04's with RS6 compressor and RS4 exhaust turbine wheels.
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    Yea sounds like u got rs6 k04 instead of rs4 k04 - so technically everyone is correct
    U know it's a blessing in disguise bc u can machine the housings to accept a full rs6 cartridge and have improved performance
    Established Member Two Rings bruddha's Avatar
    Apr 20 2012
    Tulsa/Ok/USA
    Revisiting for future build option! Who has successfully used either 2283 or 2275 CHRA in K04 housing?
    Did you have to modify the K04 housing to fit or will they go in without issue? Prefer to hand upgrade what I have vs. Buying new
