Results 1 to 24 of 24
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Who has had their T stat or PCV valve replaced?
    Also, at what mileage and at what cost if it was not covered by warranty. Here is my problem. I have 72k on my 2011 6MT. I have silver level extended warranty from Fidelity that will expire on 4/20/17. The car is consuming about 1 qt of oil /2000 miles and I suspect it is the result of the PCV valve. I also expect that if an oil consumption test were to be performed, my car would not use enough to meet the artificially set high limits that Audi uses to determine excessive oil consumption. I expect the t stat to fail at some time in the next year or 2 but probably after my warranty expires. My plan is to replace the PCV valve when the SC is off, if and when the t stat fails. My car does not fall under the TSB for PCV valve replacement. Trying to decide whether to just keep putting oil in it, proactively removing the SC and replacing the T stat and PCV valve, or extend my warranty for a longer term. OR trade my car in fro a newer certified S4. However, my specs for a repalcement car have not ben easy to find and I would much rather keep the car I have. Thanks in advance for your thoughts
    Specs fora 2013 or newer Certified S4 under 40k miles would include:
    Red color preferred including Brilliant , Misano and Volcano. Would consider Estoril and Sepang Blue. Black as a last resort but not Brilliant Black
    Black or Magma interior. Prefer not to have Alum trim but that is not a deal breaker.
    6MT, Sport dif, B&O Nav, 19 " wheels(I realize those can be changed if necessary). Don't want Black optics package and like Alu optics.
    Veteran Member Four Rings MKGIY's Avatar
    2012 S4, 2012 GMC Acadia
    New Jersey
    The dealership quoted me $1,400 to replace the PCV as it is an 8 hour job with the removal of the supercharger. If they do replace it, it would come with a 12 month/12,000 mile part warranty.
    Thanks,
    Jan 26 2015
    2017 XC90, a workbench
    CO
    I paid $1400 all in for my PCV replacement. Mine was done at an independent shop.
    Just a quick question, but how does Audi measure oil consumption? Do they fill it up then have you come back in when the light goes off? If that is the case, you could, maybe, you know...draintheoilin500milesthentakeitbackintothed ealership. just sayin. because it is your PCV, audi has stupid high limits to oil consumption and you have paid for that warranty.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Doesn't, the audi extended warranty specifically exclude repairs " the correction of oil comsumption" I have platinum plan and there is an exclusion for repairs relating to oil consumption. I wonder if PVC valve replacement would be excluded. I would hope not, bad PVC valve cause oil comsumption, think they are concerned with bad rings , not PVC VALVE.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I was told that they weigh the oil. You then drive it for 625 miles. They drain the oil and weigh it again. Whole procedure cost about $ 400 which will be reimbursed nous the deductible IF . They find a problem . You can buy a lot of oil for $400. Doesn't seem reasonable to have it done
    Senior Member Two Rings Sudz's Avatar
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    Just think how much oil you could buy for $400.
    Especially if you buy on line and pour into the motor yourself.
    Or maybe buy and install a catch can.
    2004 A4 Avant USP 6mt, Motoza Tuned
    2015 BMW M4, 6mt, Mineral White Metallic, BPMSport Tuned
    2016 Z06/Z07 Vette
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    Do it on your own. Taking the blower off is easy.
    '18 S5 - BBS / EPL
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Like I said in the other thread, I think it's just cheaper to add oil. I mean, unless you're going to replace it yourself. It's a little of a hassle to add oil, but I use the #2 computer and GasTracker to record how many miles it's been since I last topped off. So, I know basically down to the week when the light is going to come back on.
    Quote Originally Posted by jsh139 View Post
    I'm in the same boat as you. If my thermostat fails, I'll have them change the PCV. But, for now, I'll just top off every couple of months.
    With 5K oil changes and having to add a quart in between changes, that's 20 quarts of oil per 100K miles (if my math serves me right). 20 quarts of Mobil 1 0W-40 is like $100. That's cheap. Most of us will get rid of our cars before that $100 is spent anyway.
    Veteran Member Four Rings 4RCFED's Avatar
    Aug 27 2014
    12' Audi S4 (sold), 18' Discovery HSE (V)
    Sandy Springs, GA
    Thermostat @ 37k not covered. My shop did it for 580.00
    2012 S4 (sold)
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Although the oil consumption bugs me, I am more concerned with the T stat failing. I can live with adding oil. That costs me $25 for 5 qts of Mobil 1 European formula @ Walmart. T sat will cost much more. I will only address the PCV valve if and when there is another reason to remove the SC. I also assume it will cost me more than $1400 to extend the warranty. But I will explore that option.
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    My local Indy Audi mechanic did the Labor for $200. The replacement ventilator cap and spring was less than $20 from ECS
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Veteran Member Three Rings blackjak's Avatar
    May 21 2008
    11 Phantom S4
    St. Louis, MO
    Had T Stat fail at 65k Miles local shop didnit for 600 flat I provided T Stat from ECS. Just replaced it again at 125k miles. 2011.
    Established Member Two Rings pfft's Avatar
    Jul 24 2014
    '05 Nissan 350z
    Grand Rapids, MI
    Had my PCV valve replaced at around 40,000 miles for just under $1300. Running on original t stat with about 43,000 miles now. I'm sure it will fail tmrw due to this post.
    Veteran Member Three Rings USAF_Danny's Avatar
    Mar 05 2015
    Supercharged E92 M3, A3 E-Tron
    Orange County, CA
    For those of you who replaced the T-stat, how did you determine that it failed?
    I'm stuck where my coolant temp is starting to rise and my fans run a lot higher (louder) as well. But, with the heat on, I can keep the temps down and drive with no issues. Maybe mine is stuck slightly closed/open?
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by USAF_Danny View Post
    That is exactly the symptoms that occur just prior to it failing. The T stat almost always fails closed. You can wait for it to fail, but it could leave you stranded on the side of the road.
    Mar 05 2015
    Orange County, CA
    Quote Originally Posted by Dr GP View Post
    Will I know if it fails closed ?
    YouTube: DV Motions | Instagram: @danny.vuu @undisclosedm3
    []SQ5
    Senior Member Two Rings Wreckm's Avatar
    Oct 30 2013
    San Gabriel California
    Over heating while stopped, Fans over working themselves, stuck closed.
    Heater just robs the coolants heat and slightly cools.
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Your water temp will go up and stay up
    Mar 05 2015
    Orange County, CA
    Quote Originally Posted by Wreckm View Post
    If the heat's on, the coolant never spikes at idle and a stop.
    Replacing the T-Stat though and all other gaskets and O-Rings while I'm at it.
    []SQ5
    Jan 26 2015
    You never reach operating temperature = stuck open
    However, this is more of an emissions issue. Your car will run fine, but you'll likely pollute more.
    Changing both PCV and or t-stat can be done if you're mechanically inclined. I did the t-stat with my buddy in 3 hours. Total cost, including t-stat, coolant (make sure you drain it before you start), and the rubber-band-looking seals for the intake inlets was about $120.
    Mar 05 2015
    Orange County, CA
    Quote Originally Posted by Strikered View Post
    That's super quick. Is the PCV something I have to order online or can I get it at my local auto store ?
    []SQ5
    Jun 08 2005
    Lexus RX 350
    SE, PA
    ECS Tuning or dealer. You have a choice of either buying a new PCV valve or a small kit to refurbish it.
    Jan 26 2015
    What Dr GP said is correct. Get the part number and price compare the dealer to an online retailer.
    We followed a DIY that's here somewhere. I'm not saying it was easy, but you'll need 2 sets of hands for taking the supercharger off/on. Navigating around the hard plastic piping surrounding the t-stat was definitely the most difficult part of it, but loosening the clamps and the piping itself is the trick. We didn't remove the front bumper. Oh, and one more thing, you'll need some string attached to a wrench to torque the belt tension-er (hard to reach otherwise).
    Good luck!
