Results 1 to 24 of 24
    Active Member Two Rings eclipseballer's Avatar
    Apr 19 2015
    Massachusetts
    S4 Specific Service Manual
    Hey all,
    Did some Googling, and I found it's really hard to locate a service manual specific to the B8 S4. I'm only finding very old forum posts, but they all seem to reference the A4 and people say "Oh it's basically the same car".... Right...
    I also found what appears to be a manual of some sort at alldatadiy.com, but they are pitching a subscription based service, which seems impressively stupid to me.
    So, back to the question at hand; does anyone know where I can locate a service manual, specific to the B8 S4 (2012 if you have to specify), that isn't going to try to sell me a subscription?
    Thanks in advance!
    BLACK 2012 Audi S4
    Premium+/6MT/Sport Diff
    Previous:
    2002 BMW M3 Coupe 6MT: Carbon Black Metallic, Android Dynavin h/u, short shifter, rearview camera, custom exhaust (TOTALED RIP )
    2012 Jeep Wrangler Unlimited Sahara 6MT: Deep cherry red, TeraFlex 2.5" lift, 35" Nitto Mud Grapplers, Smittybilt rock rails, Bestop Trektop, Currie HD steering setup (SOLD)
    2010 Chevy Suburban LTZ 2500: Navy blue, fully loaded (SOLD)
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Some basics - site can be buggy. 2 B8 S4 options, 2010 & 2011.
    http://workshop-manuals.com/audi/
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Mar 21 2015
    There are two sites and you can buy a daily site pass for cheap and download everything you want in that day. I cant remember the sites off the top of my head though.
    Edit
    Try this or Erwin site for the downloads
    http://www.emanualonline.com/Cars/Audi/S4.htm
    Check out this recent thread
    http://www.audizine.com/forum/showth...Service-Manual
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    I have two decent manuals. PM me, and I'll send you a link to the dropbox site.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    Alldatadiy is cheap and pretty good. You'll have to search to find what you're looking for I've found.
    I've had my car a couple months and have removed the S/C and walnut blasted the intake valves, so worth the 40 bucks for 5 years.
    Apr 19 2015
    Massachusetts
    Thanks for the input everyone, got a couple of PMs that should point me in the right direction - I appreciate the help!
    Ford Perfect, kind of O/T but how did the process go? Is that a DIY type task? I'd be interested in doing the same as I just passed 100k miles and I'm sure the valves aren't pretty.
    BLACK 2012 Audi S4
    Previous:
    Jan 20 2017
    RS7
    New Hampshire
    Quote Originally Posted by eclipseballer View Post
    The hardest part of the whole thing was removing the supercharger belt, no kidding. But that's more to say I struggled with that more than everything is easy. You'll need a super long 16mm open end wrench unless your using service position. Even a pulley wrench won't work, there is that little room.
    Valves went smoothly. Four sets where closed. To turn the motor I pulled on the SC belt for half an hour before posting *sigh* and being reminded to put the car and neutral and remove the spark plugs. Check out my post, pretty recent. Where in MA are you?
    Veteran Member Four Rings freeloader700's Avatar
    Mar 23 2012
    '03 A4 1.8TQM
    The Hills, OR
    Can you PM me the link to the manual? Your inbox is full
    2003 A4 1.8TQM // Motoza // GTRS // 550cc // TR18T // Forge Splitter // 034 RSB & End Links // V710 Gunmetal 19x8.5
    →→FrankenTurbo F21 BUILD←←
    May 13 2015
    United States
    Anyone have the link to the manual?
    Sent from my SM-G930V using Tapatalk
    2011 Audi S4 DSG JHM HD Overdrive 179mm/EPL 57mm | AWE Tuning Audi S-FLO | Intake EPL 93 Stage 2 + TCU tune | ECS full drivetrain insert kit | 034 Street Density Motor Mounts
    Jun 06 2016
    Florida
    Please PM me the link! :D
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    Likewise...
    Sent from my MI MIX using Tapatalk
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Hey all,
    Thanks in advance!
    Not sure what’s so stupid about it. It’s a vey in-depth resource that’s like, $30/yr. it’s paid for itself many times over, for me at least.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Go for it.... I'm too lazy to clear out my inbox and I'm rarely on here.
    https://www.dropbox.com/sh/2e10mmubt...ya9LN7TJa?dl=0
    There are 3 folders on the site. The "B8 Manuals" folder has an older manual that is a little funky. You'll need to download all the files to a folder, and run the HTML file to access the contents.
    The ZIP file is a newer manual that seems better, but I haven't spent a lot of time going through it. If it asks for a password, try "notfromme".
    There's also a copy of the study guide on the site which is a good read if you don't have it.
    Jan 11 2017
    Houston, TX - USA
    Erwin has the data for $35 per day of subscription
    Established Member Two Rings Indepth's Avatar
    Dec 28 2017
    OH
    Quote Originally Posted by S4Sanity View Post
    I have all the documents associated with our vehicles from Erwin I can send it to you via google drive. Let me know if you want them via PM
    If you can PM me the link I would much appreciate it.
    Senior Member Three Rings Phil.Lmbrt's Avatar
    Apr 12 2017
    La Sarre, Quebec
    I downloaded all the documents on erwin yesterday and though they say A4, they are mostly for the S4.. I searched by VIN..
    The engine manual says A4, but all pictures show the 3.0T
    2012 S4
    Phantom Black | 6MT | Sports Diff | B&O
    IE Dual Pulley W/ TB | 57/187 Pulleys | Rabbit Hole Motorsport | CTS | USP | 034 | JHM | PLM | BFI | P3cars | Rotiform | CR-15 | Macan Calipers | StopTech | Hawk Performance| SPEC Clutches | Snow Performance | Airlift Performance | Accuair | Kühl Rennsport
    IG : Phil.lmbrt
    May 13 2015
    United States
    Quote Originally Posted by Phil.Lmbrt View Post
    Can you give me a copy?
    Dec 19 2010
    North CA
    Quote Originally Posted by jran76 View Post
    Thank you sir!
    May 13 2015
    United States
    Awesome! Thank you!
    Jan 06 2017
    PA
    Very useful. Thank you -jran76
    Junior Member One Ring
    Jun 25 2017
    Calgary, Alberta
    Thank you!
    Senior Member Three Rings focusaudi's Avatar
    May 02 2012
    Wrangler TJ, 2012 S4
    Denver, Colorado
    that password isn't working for me. help?
    2012 S4 | ice silver metallic | DSG | prestige | AWE Exhaust | AWE S-FLO Intake | Alu Kreuz | eurocode sways and end links | 20% tint
    Established Member Two Rings Dewar's Avatar
    Feb 17 2018
    Michigan
    You can't use Windows embedded zip software. I think you need winzip or 7zip to extract pw protected zip files. Worked okay for me.
    Dec 25 2016
    Austin, TX
    unzipped it on Mac with unarchiver but it's for a 2008 A4... so not sure how helpful that will be
