Results 1 to 12 of 12
    Established Member Two Rings goblues38's Avatar
    Aug 14 2016
    STL
    "please recharge remote battery" message in center stack?
    is this just a generic message telling me to replace the battery in my key fob?
    me = 2018 Ford Raptor, 1990 944 Cabriolet
    wife = 2022 A6 3.0
    daughter #1 = 2015 GTI
    daughter #2 = 2020 GTI
    Jan 09 2009
    1of50
    Just plug the key into the key hole while driving and u'll be set. Mine did that a while ago, but recently I got the replace battery message instead.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    I've never placed my key anywhere in the vehicle other than my pocket, and never got a recharge notice.
    I did get the replace battery message last week. They use a standard 2032 battery, so it was a piece of cake.
    So, you're saying that the slot in the dash will charge the fob??? I did not know that.
    Jan 09 2009
    1of50
    Info from my dealer, but then again they tell u a lot of B$!!
    But for me, that charging message went away...so who knows
    Just change the battery...it's like what #SQive said...POC!
    Registered User Four Rings
    Jun 25 2016
    DMV
    Hahaha wtf. I just got this yesterday too.
    Mar 13 2013
    Chicago Western burbs, Il
    Same thing here, "replace battery"..... one of the fob's that's not used a lot - battery dead.
    '21 Atlas 2.0 AWD, Stg1 93/Stacked JB4 E25, Eibach Springs, AFE Catback
    '18 mk7.5 Golf R STG 2 E30, TCU, IC, Milltek DP/HFC, AW SwitchPath
    '12 Golf R APR S2 93 HPFP W/iABED RCF, IC, UM Haldex, Milltek HFC, SMF STG2, Fluidampr, RVC, PSS10, PolarFis
    '08 R32 UM ECU/DSG, Schrick 268/264,Milltek Headers/HFC, Corsa Catback , RNS 315/RVC, PolarFis
    Apr 26 2014
    DFW
    I must say though, I do appreciate the warning.
    It would suck if it just went completely dead.
    Surprise!
    Feb 15 2007
    The battery in the key does not recharge by putting it in the ignition. The battery is a standard 2032 button battery. I just replaced mine not too long ago. Pretty easy to do. Found a youtube video that explained how to. But the battery DOES NOT recharge by putting it into the ignition slot.
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
    Apr 26 2014
    DFW
    Quote Originally Posted by cheewy16 View Post
    goblues38, are you and cheewy16 sure you saw it say "recharge" and if so, were you on your way home from the bar?
    Aug 14 2016
    STL
    positive it said recharge. which is why i axed the question here.
    wife = 2022 A6 3.0
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    I find it hard to believe the fob and ignition slot have what would amount to as wireless charing. Also, the standard CR2032 batteries are not rechargeable (but you could use a LIR2032 if you had a way to recharge them). If your fob battery is dead, you need to place it in the slot so the car can read it, as opposed to the fob emitting a single to the car.
    I bet the cluster says 'recharge' as a warning that the signal is weak, and then, says 'replace' when the car is not receiving any signal from the fob. Theoretically, if you had a LIR2032, you could pull it and recharge it though.
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
    Apr 26 2014
    DFW
    FWIW -- The CR2032 on your computer's motherboard gets recharged.
    Mine only said replace, and it did so for a week before I finally got around to changing it, but it worked fine during that week.
