Last weekend when I was replacing my passenger side from o2 sensor (worst job ever, btw), both my rear camshaft sensors broke. I taped them on for now, but I want to replacement. Thing is, the part number I recorded is only for the straight portion of the connector, not the elbow. Can I just use these anyway and not have the 90 degree bend? Should I buy the connector and re-pin the existing whiles, or cut and crimp new pig tails? P/N btw is "1J0 973 703", which ends up being just a 2 pin, but the sensor is a 3 pin. Here's the sensor in reference. I need 2 (likely 4) of the connectors that plug into this. Will this connector work if I de-pin the old connector?
Sensor in question:
