Results 1 to 7 of 7
Thread: VA rapidpass
    Senior Member Three Rings Prh's Avatar
    Mar 28 2015
    Q5, Land Cruiser 200, John Deere
    Northern VA
    VA rapidpass
    I recently noticed some emission testing equipment on some of the on ramps near Fairfax County Parkway in Reston. Did a little research and it's the RAPIDPASS program. They setup in various locations around the area. You can go to the to their site, they are posted a week in advance.
    https://www.rapidpass.org/VaPublic/Locations
    My vehicle inspection is coming due in April and my emissions test. Anyway, I have not had my emissions tested after getting APR downpipes and aftermarket exhausts. I'm wondering if this is a safer router to go then going into a state testing center? If you fail during the inspection, you get that nasty sticker on the windshield and 30 days to resolve, right? If I fail with this RAPIDPASS I guess it buys one a little more time to get the issue resolved?
    Anyone used this method?
    2014 S6 Black - APR Stage 2 ECU+TCU, APR DP, AWE Exhaust, HRE-FF01, Black Optics, P3, ALP, Escort Redline 360, Blackvue, 034, carbon diffuser, carbon mirror covers, Roc-Euro intake, ECS Tuning sways, H&R lowering module
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    The sticker on the middle lower part of the windshield is for the safety inspection. Unless they have changed something recently there is no sticker for emissions that goes on the windshield.
    The Rapidpass systems have been set up by me around Rt 50 and 495 usually. If your car has cats then you should be fine to drive by and it will hopefully say that you don't have to go through an emissions test to renew for your tags and registration.
    For me however whenever I drive past one of those Rapidpass setups I push the clutch in and roll by it because some of my cars have high flow cats or are catless at times. It is easier for me to pass an emissions test at a gas station with those cars than go by a Rapidpass setup. By the way, if a Rapidpass station detects that you are excessively polluting then they will send you a letter stating that you have to pass an emissions inspection at a shop within a period of time.
    Mar 28 2015
    Northern VA
    Good to know. Thanks
    Dec 19 2016
    Northern VA
    Quote Originally Posted by Prh View Post
    The sticker on the lower center windshield is the annual state inspection, not emissions. Emissions is the one you complete every two years when renewing tags. Driven through it in the past, it sends you a letter in the mail and tells you if you passed or failed. If you pass, you have the option to pay the fee and your emissions will be valid for 2 years. Idk what happens if you fail it.
    SOLD - 15' SQ5 -Sepang Blue - Technology + Black Optics + OEM 21" + CF + (winter mode RS6 Reps)
    Jan 10 2007
    VA
    You cannot renew your registration, aka tags, until you've been re-inspected and pass.
    Quote Originally Posted by SQ5Nva View Post
    Mar 28 2015
    Northern VA
    Makes sense. I guess when I first moved to VA I was doing tag renewals, emission and state inspection on the same month for years.
    Will get inspection done this month and then in a few months I will go for emissions when renewing the tags. Thx
    Veteran Member Four Rings TFSI's Avatar
    Dec 16 2009
    Some car
    MD
    Follow-up question regarding VA emission test in general. How strict is it? I'm coming from Maryland. My car's exhaust isn't modified, but I plan to do some work in the near future.
