Results 1 to 29 of 29
    Dec 04 2016
    Ranson WV
    Question about TSW Bathurst wheels
    Has anybody tried the TSW Bathurst wheel in 20x10 et40 on an S7 or an S6? I know that it will work in basically every dimension except one; does it clear the brakes? The only real way of knowing is to find out from someone who has done it. Anyway, I want to fit these with Michelin PS4S 265/35R20 tires. Thanks.
    Veteran Member Four Rings Gonzoe11's Avatar
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    This will clear the brakes on an S7. Keep in mind, S7 vs. S6 fitment varies slightly.
    2015 Q5 3.0 TDI Ibis White | Premium Plus | Black Optics | S-Line + | Ray's Volk G25 | Continental CrossContact |
    2014 Q5 3.0T Glacier | Premium Plus | Eurocode F&R Sway Bars | BBS CX-R | Continental DWS -06 | StopTech |
    Dec 04 2016
    Ranson WV
    Cool, thanks! My main concern is with the offset of 40mm. I know most of the people running the 10-inch wide Bathursts on the S7 are running the 25mm offset. But there is no way that would work for an S6! I would definitely rub. Anyway, I think it's worth trying.
    Veteran Member Four Rings cobrario's Avatar
    Oct 28 2014
    2015 Q5 3.0T, 2019 Toyota Tundra CM Limited , 87 Buick Grand National
    Northern VA
    maybe you've seen this but it helped me with my wheel decision:
    https://www.wheel-size.com/calc/?whe....1875in&sr=0in
    2018 Ara Blue RS3
    IG @cobrario_rs & @audivstheworld
    Dec 04 2016
    Ranson WV
    I have, thanks though, it's an invaluable tool. Between that calculator and case history from a couple of other C7 S6s I can say that the Bathursts will probably work. That is, if they clear the brakes. I hope so. It's a VERY good wheel for the price.
    Senior Member Three Rings JoeCaMotto's Avatar
    May 06 2014
    Chitown
    Quote Originally Posted by cobrario View Post
    +1 this is very helpful
    14 White S7 Loaded
    14 HD white demin V-rod muscle
    10 White Ford Raptor 6.2 Loaded
    09 Red GT-R sold
    Established Member Two Rings jagata's Avatar
    Apr 14 2014
    So. Cal
    I have 21x10.5 on my S6 clears with no spacers, but I used the recommended offsets.
    Established Member Two Rings BlewBuyou66's Avatar
    Aug 06 2016
    Clifton, NJ
    Maybe some other guys running 20" tsw Bathurst can chime in with what offset and tire size they went with and how it worked out
    Jan 22 2017
    New York
    Another concern which hasn't been mentioned is clearance with the steering knuckle. These pics are of a TSW interlagos 19x9.5 with ET41.
    You will ~.250 closer to the knuckle, but the extra .50 radius should save you as the clearance increases with larger diameter. I tried a Bathurst 19x9.5 ET39 and the spokes interfered with the caliper.
    Moral of the story, test fit before mounting the tires.
    Oct 28 2014
    Northern VA
    Quote Originally Posted by BlewBuyou66 View Post
    The guy I got my wheels from was really knowledgeable about what would and wouldn't work on my car as he's fit many before and knew what worked. I'd check with him [email protected] @ Need4Speed as it looks like they carry the TSW's as well.
    2018 Ara Blue RS3
    Sep 04 2011
    Central NJ
    I have 20x9 et35 TSW Bathursts sitting in my garage and plan to put them on this spring. Initially I'm planning to mount the 255/35R20 OEM Pirelli tires but eventually I'd like to get 265/35R20 Michelins. I was leaning towards the PS4S but noticed that they only have a 95 load index vs 99 of the PSS or OEM Pirellis. Is it save to go with 95 on a heavy car like the S6?
    2016 Audi S6 Prestige
    2015 Audi Q7 S line Prestige
    Mar 11 2017
    Houston, TX
    Ya on an A7 I been debating whether to go with 20's or 21's ..... the 21's look clean but the sidewall is at 30 vs 35 and I wonder about the ride quality as well. On the 20's I have no idea what to get as far as tire size and offsets. Set on the the Bathursts though! ;-) ...... if anyone has any suggestions or input that would be great!
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Quote Originally Posted by BASEC7 View Post
    I ran the Continental SportContact ContiSilent tires in 275/30/21. The ContiSilent line has an extra insulation lining in the tire and found the ride pretty smooth and quiet. I had the Michelin PSS in 275/30/20 on my S5 and found them noisier.
    Mar 11 2017
    Houston, TX
    Quote Originally Posted by Gonzoe11 View Post
    Thanks for the info! Will definitely look into that tire as well ...... if I were to go with 20's .... anyone know what a good setup would be?
    Dec 20 2006
    CAN
    Agree with the contisilents, they reduce noise quite well but that's also because they have much less tread on the pavement than you would expect. ie., the tread is much more round in terms of a contact patch. The reason i noticed this is because my new pss have a much flatter profile for the contact patch and even though the new rubber is 295 which is only 2cm wider, they LOOK like a helluva lot wider due to the round contact patch of the conti's.
    PSS left, Conti's right.
    [IMG][/IMG]
    emilyPay.com - Payment Processing for Professionals
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Headliner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Mar 11 2017
    Houston, TX
    I am thinking if I go with the 20x10.5 Bathursts and then 275/35/20 all the way around on the stock sport suspension it may work? What you all think? When you go 20x10.5 all the way around does it mess with the fuel economy or MMI drive settings?
    Dec 04 2016
    Ranson WV
    Very helpful! Thank you
    - - - Updated - - -
    Quote Originally Posted by low-profile View Post
    Dec 04 2016
    Ranson WV
    Thanks to everyone for chiming in. This has been a helpful discussion all the way around.
    Dec 04 2016
    Ranson WV
    deleted
    Dec 04 2016
    Ranson WV
    Quote Originally Posted by hmuller View Post
    I answered this question in another thread, but the short answer is yes. 95 gives you the ability to carry 6042lbs between the 4 tires. That's more than our car can weigh according to Audi. Our max gross vehicle weight should never exceed 5500lbs.
    Veteran Member Four Rings sirmium's Avatar
    Feb 10 2011
    MotorCity
    where did you find 20x10 et40 bathhurst with cb66? all cb66 bathhurst that fit our cars on the TSW inventory are 21" . Am I missing something?
    '23 Tesla Model X | '17 Ducati Supersport S
    Feb 25 2010
    magimmeMVE
    Usa
    I tried Stance 20x10 et42 on my BiTdi and could not get them to fit despite being told 'oh yes they will fit.. no issues' Could not clear the brake calipers. It has the 356mm discs which are still smaller than the 400mm S6 ones but maybe the profile of the caliper was the issue.
    Just check they fit and clear the brakes and dont protrude outside of the fender.
    Dec 04 2016
    Ranson WV
    The center bore is larger than 66.56 therefore a centering ring can be used. It's very common.
    Feb 10 2011
    MotorCity
    Quote Originally Posted by -Eric- View Post
    i knew you could use adapter, i was just curious if there was configuration that i missed on the site. Can you link me which ring you are considering? Im was also looking at this fitment for my car, so i'm curious
    Sep 04 2011
    Central NJ
    Quote Originally Posted by sirmium View Post
    When I bought my TSWs they came with the hub centric rings to match my car.
    Dec 04 2016
    Ranson WV
    I think they are available on n4sm.com?
    Feb 10 2011
    MotorCity
    Thank you. I would think they would be made out of metal, not plastic. Any concerns because it's plastic?
    Sent from my keyfob
    Dec 04 2016
    Ranson WV
    Honestly IDK, I would probably prefer metal too. But plastic seems to be what everyone offers. I guess it's mostly to make sure the wheel gets located correctly during installation. After that the bolts are holding the wheel in place. Should be ok.
